woman's 3-speed gear cable slipping
Cant seem to make the 'hose clamp' tight enough, and occasionally when I go to switch the gears, the cable slips through.
Not sure if I need to replace the gear gable, as it is worn some at that clamp point, and also has some gashes slightly higher up. Reason I woudn't want to replace it is that I don't know where to find the right color to match the brake cables (slightly yellow patina from age).
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
As teetime said, you need a fulcrum sleeve (the metal band) and the fulcum which is a plastic or metal insert the stops the cable housing but allows the cable to move. You can get them at any bicycle shop worth its salt, or on line. The picture below is from the Gentleman Cyclist who is an oline sell and has both.
Quoted: 789 Post(s)
Liked 1,739 Times
I have fixed this problem on a couple of older 3speeds by replacing this setup with Suntour cable guide like this one.
https://www.ebay.com/itm/Vintage-ORiG...item2ec22b76e0
You can pick these up for a couple of bucks at just about any bike shop or coop for a couple of bucks and they work better than the original setup with the clamp and sleeve. There is probably someone here who has a extra one they would let you have for basically shipping cost, I dont have one in parts bin right now or would offer it to you.
tommywpg
Classic & Vintage
8
06-23-17 01:12 PM
bartturner
Tandem Cycling
10
11-04-12 03:10 PM
