Suggestions for a dumb trainer?
So, last year, I was really starting to make some progress outside. Better endurance, faster riding, etc. Then it got cold and wet and life got busy. Now, I feel like I'm going to be starting from square one come spring.
I just want something to keep in shape during the winter that I can put my bike on in the basement and ride a few times per week. What route would you go? Magnetic? Fluid? I would like to find something under $100 if possible. Not super urgent as it's starting to warm up here and I'll be able to get out in the next month. Probably something to look into next fall.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
craigslist or ebay, you should find something for $100. For your budget probably magnetic. If I lived near you I'd sell you mine for 50
Likes For Flip Flop Rider:
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Another suggestion for a decent magnetic trainer. They work fine, and with a wheel speed sensor, cadence sensor and heart rate monitor and a few good GCN training videos you can get some serious work done.
Likes For AdkMtnMonster:
Good idea on used. Any particular reason to go magnetic over fluid? I've read that the fan based ones are the most realistic in resistance but NOISY. I took a quick look on Facebook marketplace and there's a few in my area. Might try Craigslist too but find it tends to be filled with flaky people.
While looking at used, anything I should be looking for in particular?
Quoted: 398 Post(s)
Liked 788 Times
CycleOps or Saris make good trainers. Mag is quieter than a fan, and usually cheaper than a fluid trainer, even used. Mag trainers typically have a straight linear power curve vs fluid trainers, which have increasing resistance as speed increases. They’re all good for indoor training, whether wind, fluid or magnetic. Trainers provide the earth, wind or water... you provide the fire.
Quoted: 550 Post(s)
Liked 325 Times
The increased inertia feels better, and may make indoor power numbers closer to outdoor. The resistance is more stable with temperature, leakage is less likely with a magnetic coupling to the fluid resistance unit not a shaft with a seal that can leak, and it's more stable.
Kurt Kinetic Pro on left with 18 pounds (6 standard +12 pro upgrade) of flywheel, 3000W maximum resistance, 5.2 cm roller to limit slippage.
Performance Travel Trac right with 3 pounds and 1000W maximum, 3 cm roller.
Likes For Drew Eckhardt:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
Watch the local ads, craigslist and such. You can get a great deal on a trainer. Kurt are really nice or any name brand will be good too.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Kurt Kinetic. Buy a used one on Craigslist for $50-$100.
I have one of these. Bought it new in 2013 and used it to rehab after an ankle break. Still works fine. If you don't mind a dumb trainer, their fluid trainer is in many ways ideal. As an additional merit, it doesn't leak. I've also seen them listed used for $50.
Figured I would give an update. Found a used CycleOps magnetic trainer for $50 on Facebook last week. Thought about getting the proper skewer but it looks like the one on the bike fits on the trainer fine. Any thoughts on whether this might become a problem later?
Likes For clasher:
What I've been using
Have an old Performance fluid trainer with adjustable tension. Mounted a fixed gear ride I built up from an old Schwinn sports tourer. Trainer at least 20 years old and frame easily fifty. Have a long wire cateye set up and wear a heart rate monitor. This works for me and I didn't have to get a reverse mortgage to pay for it.
[QUOTE=Madmonk1;21605757]Have an old Performance fluid trainer with adjustable tension. Mounted a fixed gear ride I built up from an old Schwinn sports tourer. Trainer at least 20 years old and frame easily fifty. Have a long wire cateye set up and wear a heart rate monitor. This works for me and I didn't have to get a reverse mortgage to pay for it. I keep a logbook the old school way. Pen and notebook.
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
I have an older Cyclops Magneto trainer that I started using to see if I liked indoor training. I started watching the GCN spin videos which were great and then bought a couple of sensors and an ANT USB dongle and started Zwifting Was hooked and went out and bought a smart trainer and have been Zwifting for nearly 3 years and love it.
Any relatively new (as in 2000 and up) bike will mount with no problems. I did find an older 10 speed style bike was a bit more tricky as the widths of the rear forks are very different.
