Mavic brake set up help needed
Quoted: 46 Post(s)
Liked 112 Times
Hi Guys, trying to set up the brakes on ex RMO 1992 Gitane, fitted with Mavic brakes which I believe are re-branded Dia-Compe? Anyway, adjust the centering via the main rear bolt, brake a couple of times and they then go off center - what do I need to do?
Thanks, Dan.
Thanks, Dan.
Quoted: 834 Post(s)
Liked 2,127 Times
That's a very cool bike!
Take a look at this diagram of a Mavic brake. Mavic Technical Manual Update! ~ tears for gears
The main post (part no. 451 015) has two faces or flat sides. Once the brakes have been tightened, use a flat cone wrench (probably 13mm) and center the brakes. The brakes should also have a washer with knurled edges between that post and the brake bridge/fork.
The Mavic brakes were rebadged Modolos. There were a few types. Can't remember what came with the starfish cranks. Could you post a close up?
First, verify that the star washer is there. That bites into the fork and brake and keeps the post centered in position. Second, make sure all pivot points and spring contact points are lubed.
Without further info, I'd guess that either the main pivot bolt is too tight, or the star washer is missing.
To adjust the conventional sidepull type with a lock nut and adjuster nut (as in diagram above), you adjust it kind of like hub bearings so that the caliper arms move freely but with no play. Then make sure the adjuster nut and outer locknut are locked (tightened against each other).
If this is one of those Modolo/Mavic brakes with a single adjusting nut, those can be a PITA to adjust, and this could be the problem. Easy to make them tight and bind. I can't recall the exact procedure since I haven't adjusted one in decades, but IIRC you kind of have to factor in the actual fastening nut on the back as part of the adjustment of the pivot bolt. Perhaps someone who's worked on these more recently than me can fill in the details. Basically the goal is the same as before; the caliper arms should move freely, but with no play.
Starting to come back to me. If it's this type, there's a flat I think behind the spring mount block. This essentially becomes the adjusting nut. Jiggle/adjust with this flat and the front allen bolt. When you tighten the brake onto the frame ithe mounting bolt locks it down. This may make it bind, in which case you have to go back and forth till everything is tight but still moves freely.,
Quoted: 1610 Post(s)
Liked 2,593 Times
Quoted: 1641 Post(s)
Liked 831 Times
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Here's a link for those if that's the case. They are a little different since they use an internal spring. Mavic 451/Suntour Superbe Pro/Dia Compe BRS500 Instructions ~ tears for gears
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
One more thing that can affect the pad's centering about the rim would be the cable housing length going from any cable housing stop point on the toptube.
From the photo I'd say it looks normal though.
Quoted: 46 Post(s)
Liked 112 Times
Maybe they are the Dia Compe / Mavic 451. Aren't these the ones that come with the ZAP stuff? I can't tell from that pic. VeloBase.com - Component: Mavic 451
Thanks, Dan.
