wrapping bars with campy non-aero levers
Old 09-24-15, 05:24 PM
eschlwc
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 3 Times in 3 Posts
q1: do you wrap merely over the lever clamp (without the lever in place) or over the lever body (with the clamp nut already tightened down on the body)?
q2: do you always do it the same way? does it matter if the lever hood can only be mounted from the rear of the lever body (like with campy non-aeros)?
backstory ... i haven't wrapped too many bars with campy or dura ace non-aeros where the hood cannot be installed after the lever is mounted on the bars. i've found these hoods can only be installed on the lever from behind (and it's a helluvan ordeal that way as well). the last time i wrapped bars with campy non-aeros, i wrapped over the clamp only without the lever in place, and i did kind of a crappy job where the wrap wasn't tight enough in a couple places. so i think i discovered it's easier to wrap with the lever in place even though it's more difficult to wrap over a lever with its hood mounted. the dia-compe 204 hoods i use are really firm and don't rollup atop the lever body to allow wrapping over the body.
this isn't an issue when the lever doesn't have such a high, fixed barrel (like with most dia-compes and weinmanns i've had), and the hood can be installed after the lever and tape are already on the bars (fitting the hood from the front).
i'm in the process of removing the scr-5 aero levers of my two '70s bikes and returning them to their more vintage form. i'm stoked. i found some really nice campy levers, but only have a couple experiences wrapping tape over them. both times i wrapped over the clamp only, and the second time didn't go so well.
eschlwc is offline
Old 09-24-15, 05:33 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6917 Post(s)
Liked 244 Times in 202 Posts
I generally peel the rubber hood back, left in place. bar tape packs include a short piece to cover the mounting band.
though being a black tape Guy , any black tape will do..
fietsbob is offline
Old 09-24-15, 05:36 PM
eschlwc
Quoted: 59 Post(s)
here are a couple pics. the record levers are going on the '76 grand record, and the drilled ones are now on the '73 falcon. i got both for $20 each, which seemed like a bargain. i met a guy in town that hoards campy gear, and he let a few items go. btw, what are these drilled ones? victory? the drilled levers just have the shield emblem.
File Type: jpg
File Type: jpg
File Type: jpg
eschlwc is offline
Old 09-24-15, 05:44 PM
gaucho777
gaucho777's Avatar
Bikes: '72 Cilo Pacer, '72 Peugeot PX10, '73 Speedwell Ti, '74 Nishiki Competition, '74 Peugeot UE-8, '85 De Rosa Pro, '86 Look Equipe 753, '86 Look KG86, '89 Parkpre Team, '90 Parkpre Team MTB, '90 Merlin
Quoted: 413 Post(s)
Liked 23 Times in 19 Posts
EDIT: I think you may be right about Victory levers.
I set the brakes where I like them, mark the spot on the bars, remove the levers but keep the clamp in place (sometimes using a small piece of masking tape to keep the clamp from sliding until the handlebar tape secures it in place), then wrap the bars over the clamp, then install the levers on the clamp.
Some brake levers such as the Weinmann levers have a clamp that is joined by a nut, rather than a post at the end like Campagnolo levers. These Weinmann levers won't stay in place without the levers attached, so I mount the levers as loose as possible, wrap under the lever, and then tighten the lever onto the clamp.
I know it's a perfectly acceptable practice, even employed by pros BITD, but I've never been a fan of the look of handlebar tape over lever bodies.
gaucho777 is offline
Old 09-24-15, 06:11 PM
randyjawa
randyjawa's Avatar
Bikes: 1958 Rabeneick 120D, 1968 Legnano Gran Premio, Rocky Mountain Cardiac
Quoted: 649 Post(s)
Liked 100 Times in 80 Posts
This is How I Wrap the Handlebar...
I usually just locate the levers, snug them up and then push the hoods up enough to get the tape under the hoods.
You can also position the levers, then tape them into place with electrician's tape, the PVC kind. Once temporarily secured into place, remove the levers, hoods and all and tape away. Then, when done taping, secure the levers back in place, trapping and compressing the tape, under the lever body, in the process. That is how I had to do these Universal levers which sported less than pliable hoods material...
"98% of the bikes I buy are projects". Learn how to find, restore and maintain vintage road bicycles at... MY "TEN SPEEDS"
randyjawa is offline
Old 09-24-15, 06:28 PM
eschlwc
Quoted: 59 Post(s)
i didn't think of using electrical tape over the clamp then removing the lever bodies before wrapping.
i only have two experiences with these kind of levers. and i usually use cane creek hoods that are sort of easy to roll up on the lever body to allow you to wrap the bars.
but these dia-compe 204 hoods fit and look way better than the cane creeks. but they're so firm, you can't roll them up without risking a tear.
they seem to be getting hard to find too. velo orange has them, but i don't like paying so much for shipping. i had an lbs (freerange cycles in seattle) order these for me for $12/ea.
i don't really care for the repro campy hoods.
eschlwc is offline
Old 09-24-15, 06:35 PM
eschlwc
Quoted: 59 Post(s)
randy,
the black chang-star hoods in your first pic look like they would fit these levers too. i've never seen those before. and they look long (and easy to roll up), which is sometimes a problem with the cane creeks that are sometimes too short to fit perfectly on some dia-compe lever bodies. i hate that.
eschlwc is offline
WGB
Bicycle Mechanics
4
04-29-18 04:06 PM
Relaxin
Classic & Vintage
40
07-27-15 12:31 PM
SJX426
Classic & Vintage
19
05-07-13 12:49 PM
tek336
Singlespeed & Fixed Gear
25
06-09-10 10:30 PM
