An affordable 31.8 quill stem
Old 01-16-17, 07:19 PM
icepick_trotsky
Aspiring curmudgeon
icepick_trotsky's Avatar
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 103 Post(s)
I stumbled across this on eBay, and it looks like a way better solution than an adapter. There are other around, but they're all much more expensive.
"Party on comrades" -- Lenin, probably
icepick_trotsky is offline
Old 01-16-17, 08:09 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3590 Post(s)
Liked 528 Times in 367 Posts
Saw those last week when i was trollin thru ebay for stems.
Love the removable faceplate to facilitate easy and clean installation.
mstateglfr is offline
Old 01-16-17, 08:25 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
Liked 5 Times in 3 Posts
Looks very similar to Factory Five, https://wearefactoryfive.com/products/f5-titan-stem
F5 Titan only comes in 90mm and double the price of your ebay find
mongol777 is offline
Old 01-16-17, 08:26 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
Found another one, 90mm,
I wonder how flexy are they. I'd probably risk it on the bike which does not see a lot of spirited riding but for anything else I somehow do not feel re-assured of stem quality. I'd love to hear from someone with first hand experience
Old 01-16-17, 09:41 PM
GTizzy
GTizzy's Avatar
Bikes: Miyata 621 Touring, Dahon Smooth Hound (Demountable)
Quoted: 26 Post(s)
The Factory Five team are good guys. They design original and beautiful products. This is obviously a counterfeit. I know it's tempting to race to the bottom, but please think twice before buying, and maybe read this article in Cycling Tips about the whole counterfeit cycle following the launch of the (awesome) Spur Cycle Bell:
https://cyclingtips.com/2016/08/a-ta...ounterfeiters/
If you want beautiful products, and thoughtful innovation from small manufacturers, support them by buying their products.
Thanks!
GTizzy is offline
Old 01-16-17, 09:48 PM
GTizzy
GTizzy's Avatar
Quoted: 26 Post(s)
Also, all those tempting arguments ("It might come from the same factory!" "I'm bypassing the marketing cost") are thin self-justifications. Sad!
Read the Spur Cycles article.
GTizzy is offline
Old 01-17-17, 05:08 AM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
Thanks!
I like what F5 is doing. I saw F5 Titan stem at LBS and it looks really good. And their Pista frame - oh my:
Old 01-17-17, 07:20 AM
icepick_trotsky
Aspiring curmudgeon
Quoted: 103 Post(s)
Sheesh, do you guys work for Factory Five or something?
Old 01-17-17, 04:51 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
Haha, I know - we look like total shills! No, I don't work for them. I was ready to pull the trigger on the frame though but their sizing chart threw me off, it is odd. They also make very nice chainring and I see it quite often this days posted on various forums
Old 01-17-17, 07:14 PM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 369 Post(s)
Liked 681 Times in 444 Posts
I thought Factory Five was a boy band. I also thought the Factory 5 stem had a "full" clamp with a clamp bolt. The J and L is "open face."
I took delivery of one of those J and L 31.8 quills about a week ago, in silver. Looks pretty good, and will look better when I polish it. Let's look at the pro's and con's from my recent experience:
Pro:
1-Price.
2-Available in silver or black.
3-Big bar capable; I'm running a Deda Big Piega on it, looks great.
4-Simple 2-bolt mounting, standard wedge/steerer setup. Easy to mount any 31.8 bar.
Con:
1-Finish could be better in silver, kind of mottled. Not a Nitto or Cinelli, for sure.
2-2-bolt clamp for a 31.8 bar. Compared to most threadless stems, makes you wonder.
3-The cap didn't fit against the stem very well. I had to file to stop it from binding.
4-Sizing. It could really be .2-.5mm smaller, as it does not grip the 31.8 bar all that well.
5-The two bolts are cheap and ream out quickly under the torque needed to clamp the bar. I replaced them with steel bolts.
Would I buy one again? Yes. The price makes up for the time it takes to "get it right." The flexibility of being able to run modern bars like short/shallows on a C&V frame is worth it.
Is the Factory Five a better stem? Yes. Is it worth 2.5x to 3x as much? No.
I normally pay more for US-made products, but the difference is pretty substantial.
Of course, once I put some serious load on the bars, we'll see how that stem clamp holds up. The two bolt clamp has me a bit nervous. The only 2-bolt clamp threadless stem I've ever used was a Profile Design Forgie, and those bolts were huge. These bolts are the same as bottle cage bolts. I recommend replacing them with steel bolts immediately.
Just my opinion, since I have one.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 01-17-17, 07:26 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
I may be mistaken but Factory Five does not make any products in the US. They are China based brand (Shanghai if I recall correct) and I would assume everything is made either in China or Taiwan.
Old 01-17-17, 07:28 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
Here is close up of F5 stem, does it look different from J&L?
Old 01-17-17, 07:34 PM
RobbieTunes
Half drunk? Finish!
Quoted: 369 Post(s)
Nope, pretty much the same design, I guess. F5 fit and finish look better, bolts definitely look better, more recessed (and look like steel) The cut-outs on the J and L are deeper, but not very precise, and the silver J and L is not polished, more like cloudy satin.
It will take me about 20 minutes to get the finish to be reflective, then another 10 to make it look like chrome, but it will be done. I've already got steel bolts in there. The OEM J and L bolts are OK for water bottle cages, not much else. Next time I get to Fastenal, I'll pick up some stainless bolts.
Robbie ♪♫♪...☻
Old 01-17-17, 07:37 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
Nope, pretty much the same design, I guess. F5 fit and finish look better, bolts definitely look better (and look like steel) The cut-outs on the J and L are not very precise, and the silver J and L is not polished, more like cloudy satin.
Thank you! Will wait to hear your feedback on how it rides. I find some modern quill stems (and some vintage too of course) are a bit on the flexy side.
Old 02-02-17, 09:00 PM
mongol777
Bikes: are all mine
Quoted: 163 Post(s)
No word on pricing yet, fresh off the press The Velo ORANGE Blog: Them Stems
Old 09-05-18, 10:22 PM
Essthreetee
Essthreetee's Avatar
Bikes: 2001 LeMond Nevada City, 92 Merlin Titanium, '84 Torpado Super Strada, 84 Schwinn Tempo, '81 Bianchi Limites, '73 Raleigh Supercourse
Quoted: 141 Post(s)
Liked 24 Times in 18 Posts
I know this is old...but RobbieTunes, What was your final verdict on this? Is it worth the time? Do you think the Factory 5 would be better?
Just wondering.
"They ain't following me, I'm just in front." - Rubber Duck
lol <---- does that look like someone drowning to anyone else?
Essthreetee is offline
Old 09-06-18, 07:29 AM
RobbieTunes
Half drunk? Finish!
Quoted: 369 Post(s)
31.8 quill
Two facets to this, maybe three:
1. Go with the Factory 5 if you must. Just a lot nicer stem.
2. Use steel bolts. I value you here, and there are only two bolts.
3. The Innicycles adapter changed the equation for me but it's $90 plus a stem.
Now, you can PM me and I will send you my 31.8 quill.
I think having it in your mitts is a better way to grasp the variables.
You can always send it back after you give it a go
Old 09-15-19, 11:21 PM
marciexyz
Bikes: Univega, Concorde, GT, LaPierre, Elsworth....
Hey, what is your method of polishing out bike parts such as this. Thanks 👍🏻👊🏻
marciexyz is offline
Narhay
Classic & Vintage
5
05-02-17 01:14 PM
beaconsbeacon
General Cycling Discussion
9
02-03-17 09:38 AM
murrellington
Singlespeed & Fixed Gear
8
02-24-16 12:31 AM
Vonruden
Classic & Vintage
15
12-03-15 06:50 PM
datlas
Road Cycling
28
11-13-15 08:47 PM
