10th Annual Storming of Thunder Ridge
Old 03-07-19, 08:53 PM
  #76
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1096 Post(s)
Liked 70 Times in 52 Posts
So I need to make the meal reservation. Preferred time is around 4:30 give or take 30 minutes either way?
Whatever, whenever. I'll be there, ready for food and beer!
rccardr is offline
Old 03-07-19, 10:29 PM
  #77
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 357 Post(s)
Liked 415 Times in 271 Posts
We'll figure something out. To drive from KY and IN may require some real planning.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 03-08-19, 09:15 PM
  #78
conspiratemus1
Used to be Conspiratemus
Quoted: 125 Post(s)
Liked 66 Times in 44 Posts
Yes, we (two) would love to join you all for dinner. 4:30 is great, especially being that one of us will be officially a Senior Citizen by then -- Early-Bird Special, here we come.
conspiratemus1 is offline
Old 03-09-19, 09:56 PM
  #79
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
What, no coupons?
Robbie ♪♫♪...☻
Old 04-11-19, 07:46 AM
  #80
seedsbelize
necessary illusions
seedsbelize's Avatar
Quoted: 4886 Post(s)
Liked 62 Times in 47 Posts
Reviving the thread.
My personal journey begins in three weeks, with a tour across Ohio. If I make it to Lynchburg, I may be in search of a ride, for me and my bike, to, or near Charlottesville.
I am still interested in a compact double to borrow. Just for the SOTR. After that you can have it back. I generally ride 170mm, but I will not be picky. I will be carrying removal tools.
I'm currently reviving my fitness level, after a week of the flu. I was in great shape two weeks ago.
Hadley will be joining us again this year.
That is all.
seedsbelize is offline
Old 04-11-19, 08:47 AM
  #81
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
Sounds good. I have a modern compact double, English thread, with cups/BB. I can bring it, and tools. In fact, you may be able to swap it during the drive to Lynchburg, if you want to try it in the back of a moving truck....
Chain-wise, you're on your own....I have nothing for a long wheelbase like you giants use.
I have my Raleigh ready, but am working on the Bob Jackson (bolt holding a bottle cage is stuck and reamed; slow going with drill bit and ez-out).
Robbie ♪♫♪...☻
Old 04-11-19, 09:51 AM
  #82
seedsbelize
necessary illusions
Can't I just put the crank on my current bb? Why get all fancy schmancy?
Old 04-11-19, 09:59 AM
  #83
seypat
Quoted: 1108 Post(s)
Liked 167 Times in 125 Posts
Tell us what kind of bike/crank you will be switching out. Maybe we can just switch out the rings or switch out the crank. Or maybe we need a different spindle as well.
seypat is offline
Old 04-11-19, 10:04 AM
  #84
seypat
Update on Rivermont Pizza for Saturday night. They do not take reservations on the 2 college graduation weekends. They start serving at 5. The lady told me to show up at 4:45 and I should be okay getting a table for the group.
seypat is offline
Old 04-11-19, 10:06 AM
  #85
seedsbelize
necessary illusions
1980 Trek 414, original. The crank is 84? 86? Bcd. I can look that up.
All that said, I like the back of the moving truck idea.
Old 04-11-19, 10:14 AM
  #86
seedsbelize
necessary illusions
Currently 52/40, with .34 granny. Robbie says sotr can't be done with that granny. I tried to find a bigger cog in a seven speed, but couldn't. I could bring a triple with me, but doubt it will fit the current bb length. And I'd rather not pull the whole thing apart. I could always be the old man on the old bike who had to walk the hills.... . ...
Old 04-11-19, 10:15 AM
  #87
seypat
I have an 82 Trek that needs a ST and tubing decals. I will bring it on Saturday so the re-decaling experts can assist me with the task. I'm on Velocals looking to order the ST decal. Lots of options. I need to know what to order.
1 or 2 mil vinyl, or waterside ultra thin film?
Glossy UV laminate, low gloss UV laminate, or Heavy Duty clear Matte UV laminate? Or no UV laminate at all?
Someone help me out, pleeaassee!
seypat is offline
Old 04-11-19, 10:20 AM
  #88
seypat
I'm the one always walking the hills, even with a triple. By golly, it might be your lucky day. I have a bike with a Stronglight 99 which is 86BCD. That bike has done 2 SOTRs. Let me go look at what size granny rings I have. I know I have a 30t.
seypat is offline
Old 04-11-19, 10:56 AM
  #89
seypat
If I am reading this right, you will be running a 52/40 double and a 7 speed cluster with a 34T big cog? Is that right? I have a 32T 86BCD ring. I might have a 30, I have to keep looking. If you think the 32T will work better, I can send it to an address in the US. You can put it on your bike before you start your tour. Tour with it, do SOTR and give it back after the ride. It will give you some needed lower range for the tour.
seypat is offline
Old 04-11-19, 11:51 AM
  #90
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
modern compact double = external cups
Robbie ♪♫♪...☻
Old 04-11-19, 11:53 AM
  #91
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
Since most of my decals go on powder coats or repaints, I use the 2 mil. If you are going to clear, go 1 mil. I'm a cheapskate, get the cheapest.
Robbie ♪♫♪...☻
Old 04-11-19, 11:55 AM
  #92
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
40/34 granny could climb to the ridge, as I've done it on 38/32....BUT...there's not a lot of gas in the tank after grinding that for 13 miles. When you get to the Hills of Otter, the tank is on "reserve" and an extra gear really helps there, then again in town coming out of that private driveway and over to the YMCA, 'cause the legs are a bit wobbly by then.....
Robbie ♪♫♪...☻
Old 04-11-19, 12:03 PM
  #93
rccardr
aka: Dr. Cannondale
rccardr's Avatar
You shouldn't need anything more than a 32/34 combination. In fact, a 32/24 or similar is all you need for The Big Climb. The bigger cogs come in handy 1) just after the first rest stop, when you take that right turn and hit The Wall; and 2) from time to time during The Hills Of Otter, which are slower and quite abrupt.
If you want a whole crankset, I can bring an SR Apex, prolly 50/34, which also looks the part.
rccardr is offline
Old 04-11-19, 12:19 PM
  #94
seypat
I'll go with the cheapest decals. Here is the bike as acquired. It will be ridden at SOTR someday. Check out the brakes! That's why I bought the bike. Cost me $50. If you can't make out the brakes, they are first gen Dura Ace. This bike was bought for the PO's wife. He switched out the saddle and the brakes. He still had the originals parts which I got as well. She didn't take to cycling so it wasn't ridden much. Those rims are a rarity. Trek bought the rim company and it became Matrix, I think.
seypat is offline
Old 04-11-19, 12:54 PM
  #95
seypat
After looking at the brochures, I think this is the crank on Seeds bike. If it was me, I would get the gearing sorted out(whatever that may be) before I started the tour. That could make the difference between a good time and a not so good time.
VeloBase.com - Component: Sakae/Ringyo (SR) SAX-5TG, APEX-5 Touring
seypat is offline
Old 04-11-19, 02:36 PM
  #96
seedsbelize
necessary illusions
It's a six speed, but yes. I will check the bcd, and the fd capacity and get back to you.
Old 04-11-19, 02:41 PM
  #97
seedsbelize
necessary illusions
I do the 47, so the hills of otter are the only real hills I see. If Patrick can walk the hills, I guess I can too. Vamos a ver.
And, no offence intended, but I don't see myself soiling the OEM Trek with an external bb. The line has to be drawn somewhere. In my world view, cartridge bbs are new tech. I'll use them in a pinch, if need be.
Old 04-11-19, 02:51 PM
  #98
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
Robbie ♪♫♪...☻
Old 04-11-19, 02:57 PM
  #99
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
I thought that R-turn to the Wall was before the rest stop. If I've missed a rest stop....
IIRC (which is not always close to a sure thing)… the Preview Wall (which really quiets down all the optimists) is the climb that gets us up and over a small ridge that then descends to the rest stop, past the first photo op, more or less.
IIRC, the first rest stop is where Pat pointed up to the observatory and said "we are going to climb up there." Shortly thereafter, we descend a bit, and make an innocuous L turn, then a switchback R, and then a L and there you go, 7% to 8% for the next 1 to 2 hours, depending on your climbing pace.
At least that's what I've been telling myself....
Robbie ♪♫♪...☻
Old 04-11-19, 02:59 PM
  #100
RobbieTunes
Half drunk? Finish!
Quoted: 357 Post(s)
I have that brakeset. I'm not so sure I'd use them descending Thunder Ridge, but hey, the pro's used them.... That is a sweet bike. Have the calipers got 4mm extra reach in case you go 700c?
Robbie ♪♫♪...☻
