Should I change my gearing?
Old 04-19-19, 08:06 PM
mtnbud
mtnbud's Avatar
Bikes: 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 69 Post(s)
Liked 4 Times in 4 Posts
I picked up a vintage Specialized Epic road bike a couple of months ago and have been enjoying riding the bike. I'm concerned about not having any low climbing gears. The front rings are 52 and 42. The 8 speed rear cassette is a 11 to 25. I have avoided any serious climbing with the bike so far and have found I have been able to handle minor climbs fine. I'm concerned that if I took this bike where any serious climbing was involved, I might go anaerobic before hitting the crest.
I was considering putting a 11 to 28 cassette on the bike and changing the 42 tooth front sprocket to a 39. The rear derailleur is a short change Shimano 600. The front derailleur is Shimano 600 also.
I'm not sure the derailleur would handle the gear inches and if the changes would be worth the cost. It shifts flawlessly right now. I'd hate to mess up a good thing.
What do you guys think?
mtnbud is offline
Old 04-20-19, 03:18 PM
philbob57
Quoted: 300 Post(s)
Liked 54 Times in 41 Posts
I think the changes you're contemplating will give you about a 20% advantage at the low end over what you have now, and IIRC the 600 rder will handle a 28.
But will that get you up Mt. Hood without going anaerobic? I doubt it. Why not a bigger rear cog and a der with a long cage?
20% is nothing to sneeze at, but why not try the hills that you fear now? That might giveyou an idea if 20% is enough.
philbob57 is offline
Old 04-20-19, 03:33 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6921 Post(s)
Liked 246 Times in 204 Posts
Buying a new crankset with a 110 bolt circle lets you drop the chain ring size to 34t
50 - 34 combinations get put on the bikes at a factory level lowering costs .. by having big sales numbers..
fietsbob is offline
Old 04-20-19, 04:45 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2286 Post(s)
Liked 260 Times in 195 Posts
What are your fitness plans? It's early spring. That gearing could work if you're planning to put in a lot of time climbing hills and getting stronger.
Otherwise, I'm with @fietsbob. A compact crank would lower your overall gearing a bunch without needing to swap derailleurs or cassette.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-20-19, 05:55 PM
Rick
Quoted: 155 Post(s)
Liked 35 Times in 30 Posts
IRD has a 13-15-17-21-25-28-34-40t elite cassette. and a 12/13/15/18/21/24/28/34 cassette.
Rick is offline
Old 04-20-19, 06:14 PM
Flip Flop Rider
Flip Flop Rider's Avatar
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 441 Post(s)
Liked 52 Times in 36 Posts
50-34 would be good to try if feasible
Flip Flop Rider is offline
Old 04-20-19, 06:28 PM
VegasTriker
Quoted: 326 Post(s)
Liked 21 Times in 16 Posts
Shimano maintains a library of technical documents for download. If you know the exact model of the FD you can go to the site, look up the document and see what the maximum difference can be. https://si.shimano.com/#/en/search/C...leur&type=ROAD
If you look at this example https://si.shimano.com/pdfs/si/SI-U-109-000-00-ENG.pdf under the heading Specifications you will see this particular FD has a maximum difference of 15 teeth.
VegasTriker is offline
Old 04-20-19, 09:11 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 860 Post(s)
Liked 83 Times in 68 Posts
I picked up a vintage Specialized Epic road bike .......
Your vintage crank probably does not accept a 39 tooth chainring. You could probably find a cheap replacement crankset, new or used, that would work with your current bottom bracket.
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 04-20-19, 09:31 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1214 Post(s)
Liked 67 Times in 52 Posts
A bicycle is a simple machine but the devil is in the details.
Everything on a bicycle works together so you can almost never change just one part without having to change something else to make it work. "Vintage Specialized" tells me that you don't want to spend a ton of money on your proposed changes. New chainrings may require a different crankset. Different crankset may require a different bottom bracket. Bigger cassette cogs may require a different rear derailleur. A different derailleur might not work with your shifters.
Retro Grouch is offline
Old 04-20-19, 10:17 PM
mtnbud
mtnbud's Avatar
Quoted: 69 Post(s)
Thanks guys! I went out on a nice 50 mile ride with the bike today. There were some reasonable climbs with nothing too extreme. There were a couple of 2 mile climbs that were around a 4% average grade and I had no issues with those climbs. I also ran into some short steep pitches that required me to stand up to get past them.
I am not sure how much money I'd want to spend on changing things. Changing to a compact drivetrain is a cool idea. I'm not sure I want to spend that much. I really like the way the bike feels. I may need to just be cautious on which routes I take when using it. If I'm on a ride with serious climbing, I'll have to use my other bike.
Still, I may eventually change the drivetrain on this bike...
mtnbud is offline
Old 04-21-19, 06:36 AM
Canker
Quoted: 176 Post(s)
Liked 8 Times in 7 Posts
Cheap option
Put an old mtn bike RD and cassette on it. Even if you buy brand new they cost $20-30 each since 8-9 speed stuff is worthless. You can go all the way up to 11-42 even with 8 speed though I imagine the gaps on a road bike would be horrifying.
Canker is offline
Robert A
Road Cycling
34
01-09-19 04:39 PM
cdenniston
Touring
3
06-16-17 06:51 AM
rodscot
Bicycle Mechanics
20
09-09-16 03:42 AM
watercamper
Bicycle Mechanics
35
02-26-16 11:16 AM
1bluetrek
9
01-29-16 07:17 PM
