What is the speed advantage of a modern steel bike?
Old 08-07-19, 10:36 AM
bruce19
bruce19's Avatar
Quoted: 959 Post(s)
Liked 163 Times in 104 Posts
I will guarantee you that my mid-80's MAZA (Not MASI) Prestige TSX frame was heavier than my current Guru Sidero. That counts for something when climbing. Whether it's significant enough to cause a recreational rider to spent a bunch of money is up to you.
bruce19 is offline
Old 08-07-19, 10:57 AM
Quoted: 9242 Post(s)
Liked 810 Times in 507 Posts
Originally Posted by dugla View Post
Hah. Maybe it's engine.
Can't resist. It is all about the Engin...
Likes For indyfabz:
Old 08-07-19, 11:09 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2302 Post(s)
Liked 263 Times in 198 Posts
@Ironfish653's post made me think a little: if you are not using the full range of your 11-28 cassette, you could install a tighter one so that you are closer to optimal gearing most of the time. I, for example, have no use for a 50/11 top gear. Just switching to a 12-28 would bring the top three gears down and into the range where I do my riding. (In fact, a 13-28 would be even more to my liking. )
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 08-07-19, 11:12 AM
TiHabanero
Quoted: 825 Post(s)
Liked 95 Times in 64 Posts
Dugla, I just went through this at the start of summer. I ride a frame that I built in 2001 from Reynolds 531. Had friction 5, 6 and 7 speed on it all this time and was happy with it, but now need lower gearing. I had to rebuild the rear end due to hitting it with the car so I built it with 135mm spacing for reasons other than gear choices. Installed my first ever indexed shifting in the form of Record brifters with Chorus derailleurs, but kept the Superbe Pro crank on it. The rear gears are Shimano 11-32, and there is not a doubt in my mind that I am able to climb faster and seated more often. Top speed is the same as always, but I can get up the hills better because I have lower gear ratios to work with.
In addition to this, at the end of hard rides like I did this morning I am fresher, dead, but not beat up.
One thing to note, my friend Paul rides an old Fuji Roubaix aluminum frame with beat up 105 on it and can stick with anyone any time. He is an old cuss, too. Work on your motor and get more appropriate gearing, and just maybe you will feel the speed.
The frame is unlikely to help. Aero tubing and design will only make a real difference at higher speeds and over a long distance.
TiHabanero is offline
Likes For TiHabanero:
Old 08-07-19, 11:16 AM
MattTheHat
MattTheHat's Avatar
Bikes: '20 Specialized Roubaix Expert, '18 Specialized Diverge Comp
Quoted: 249 Post(s)
Liked 136 Times in 98 Posts
Alas, that's what we're trying to tell you.
If getting a new bike or upgrading the old one inspires you to upgrade the engine, then it could be worth it, but it's not going to be a quick fix to move you up a couple MPH.
I was going to say much the same. New go fast goodies might make you want to ride more.
-Matt
MattTheHat is offline
Old 08-07-19, 11:29 AM
Caliper
Bikes: Many
Quoted: 308 Post(s)
Liked 15 Times in 12 Posts
I am fit and - due to limited time - ride hills for about an hour every other day during the week. On weekends I do a longer (32mi.) ride. I occasionally try riding with a local group ride but I am routinely dropped early in the ride. Average pace is about 17mph. It drives me nuts! The other riders are not exactly studs and do not look super fit. What I do notice is everyone is on a modern bike. Carbon mostly. Some titanium. Some steel.
You refer to 32 miles as a "longer" ride, what is your pace on this ride? How long is this training ride you are joining? Around here, our weekday group rides are in the 30-40 mile range. Many people I know routinely go double that on the weekends.
Honestly, 17mph doesn't sound like a blistering pace for a group ride on pavement unless you are in a very hilly area. It sounds like your current training is 2.5hr during the week + 32 miles on the weekend? While you may be fit in a general sense, it is possible that the ride you are joining is made up of people more fit than you are and you could benefit from more training. Or, consider finding a different group ride that holds a slightly lower pace if you are happy with your current training volume.
Caliper is offline
Old 08-07-19, 11:39 AM
Kedosto
Ambulophobic
Quoted: 445 Post(s)
Liked 135 Times in 83 Posts
It's never the engine. It's always the bike. I could be a gold medaling, TdF superstar, mega-millionaire if only I had a better bike. Heck, I'd even be more handsome and charming too.
-Kedosto
"nice personality"
Kedosto is offline
Likes For Kedosto:
Old 08-07-19, 11:46 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6822 Post(s)
Liked 651 Times in 409 Posts
This is a lucid and well thought out post.
-Tim-
TimothyH is offline
Old 08-07-19, 01:16 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1807 Post(s)
Liked 140 Times in 102 Posts
Hi,
I am trying to get a definitive, fact based answer to the question: what makes a modern steel frame road bike faster than my vintage - 20 years old - custom steel frame?
The rider.
/thread
JohnDThompson is offline
Likes For JohnDThompson:
Old 08-07-19, 01:22 PM
Kovkov
Kovkov's Avatar
Bikes: 1957 Alpa Special, 1963 Condor Delta, 1967 Tigra Sprint, 1977 Oltenia, 1987 Mondia, 1965 Staco de luxe, 1969 Amberg
Quoted: 91 Post(s)
Liked 32 Times in 16 Posts
Hi,
I would say it‘s not „what“ but „who“. Someone who spins the same gear ratio with a faster cadence.
Kovkov is online now
Old 08-07-19, 01:45 PM
Koyote
Quoted: 457 Post(s)
Liked 165 Times in 96 Posts
I like what I'm hearing. My Fuso is all set for a modern groupset as the spacing is wide enough for a 10/11 speed cassette.
Put on a new Shimano 11 speed groupset -- 105 level is very good, Ultegra is even better. I know you just bought a new rear wheel, so add a new front wheel -- or better yet, buy a nice new lightweight wheelset. Replace a few other key components -- go for best bang for buck by removing relatively heavy components if you can replace them with newer lighter parts at reasonable cost.
Most important part is to ride more, perhaps do some interval training. That will make the biggest difference in allowing you to keep up on the group ride.
Koyote is offline
Likes For Koyote:
Old 08-07-19, 01:58 PM
rosefarts
Quoted: 304 Post(s)
Liked 58 Times in 27 Posts
If your bike has 130mm spacing and you don't feel the need to get disc brakes, you're probably fine just upgrading components.
I ride 2 steel bikes, both "modern" but also 20ish years old.
The road bike is set up with 10speed Campy Chorus that I upgraded cranks to a carbon compact UT. I switched to a carbon fork for fit issues too. On the nice wheels, I'm just at 17.5 lbs. Add a pound for my Open Pro workhorses. I am an ok climber, I drop more people than I get dropped by. This early aught bike rides modern and fast and certainly doesn't slow me down. It has never been the reason I've crushed souls or been crushed.
The gravel bike is a different story. It's a cross bike that takes wider tires. It's a bit of a Frankenstein build. It works super well but it has toe rub. For gravel, I'd prefer disc brakes. If I damage my tank of a fork, there isn't anything with a 1" steerer tube to replace it with. If I were to do that build again, I'd probably go a lot more modern.
rosefarts is offline
Likes For rosefarts:
Old 08-07-19, 02:48 PM
TimothyH
- Soli Deo Gloria -
I'm going to put this out there...
Modern Steel Road Bike Appreciation Thread
IIRC the thread got very contentious, especially regarding the semantics of the word "Modern", but it does contain some very nice steel bikes.
-Tim-
TimothyH is offline
Likes For TimothyH:
Old 08-07-19, 07:24 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 861 Post(s)
Liked 85 Times in 70 Posts
I'm still riding the steel frame I built around 1982. It's a Franken-bike now, with Campy Centaur 10 speed, mixed with some original bits.
Just grunt a bit when spreading the dropouts to insert a 130 mm rear wheel.
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 08-07-19, 07:56 PM
02Giant
Home School Valedictorian
02Giant's Avatar
Bikes: 13 Orbea Orca 02 Giant Cypress 88 Mongoose ATB 79 frame-built to 80 spec. Schwinn Traveller
Quoted: 851 Post(s)
Liked 63 Times in 43 Posts
Spend some $$ on that old frame. A new, lighter wheelset. New tires. Shimano 105 11spd. Then ride the snot out of it.
Excuse me if I, have some place in my mind,
Where I go time to time
I ain't broke and I ain't hungry but I'm close enough to care
Tom 2020
02Giant is offline
Old 08-08-19, 12:22 AM
ironwood
Bikes: 1984 Bridgestone 400 1985Univega nouevo sport 650b conversion 1993b'stone RBT 1985 Schwinn Tempo
Quoted: 426 Post(s)
Liked 29 Times in 17 Posts
Unfortunately, one of the best modern steel tubing, True Temper XO Platinum, is no longer available. Some of the Japanese makers have moved production to Taiwan. Maybe someone on the Framebuilding forum would know what is the best modern steel. A lot of them miss XO Platinum.
ironwood is offline
Old 08-08-19, 03:32 AM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1676 Post(s)
Liked 146 Times in 130 Posts
Ain't nothin' fast if you ain't fast.
I'm H.R Huffnpuff myself. The ride is fine though.
Our streets are paved with onions...the drivers aren't tarping
Rollfast is offline
Likes For Rollfast:
Old 08-08-19, 04:39 AM
bruce19
bruce19's Avatar
Quoted: 959 Post(s)
I always seeing this bike. Thanks.
bruce19 is offline
Old 08-08-19, 04:41 AM
bruce19
bruce19's Avatar
Quoted: 959 Post(s)
My Guru is Columbus Spirit. I'd love to know what frame builders think of the material. I love my Guru.
bruce19 is offline
Old 08-08-19, 06:50 AM
dugla
Quoted: 18 Post(s)
Liked 2 Times in 1 Post
Ok,
Thanks for the tons of useful input. Very cool.
If I try and distill responses down I think I have a punch list.
First, more context:
- My Fuso is at130mm and this was key to some of the changes I made. I had the local shop build me a wheel. Hub: Shimano 105 5800 36 hole 11-Speed rear hub. Cassette: Shimano 7-Speed 11/28. Rim: Mavic Open Sport 700c. So out with the old freewheel in with the cassette/freehub basically.
My todo list:
- upgrade to the latest Shimano 105 11-speed groupset
- (maybe) replace my front wheel with some Mavic coolness
- more hills
My goals are rather modest: ride comfortably at 17-18mph in the local group ride which is 36 miles-ish. A key aspect of this is "solving" riding on the rolling hills here in Mass. (Lexington/Concord/etc.). This is where the 11-speeds should pay dividends. I think I will get there. My weekday hill loops - 3 1-hour sessions per week - are getting faster and longer. Around 1400 ft of elevation in an hour, typically. I don't really have the time to do 40/50/60 mile rides.
dugla is offline
Old 08-08-19, 08:18 AM
superpletch
faster downhill
superpletch's Avatar
Bikes: more than my wife can keep track of
Quoted: 144 Post(s)
Liked 3 Times in 3 Posts
ride more to get faster.
best upgrade to go faster is a good wheel set with great tires that have low rolling resistance
superpletch is offline
Old 08-08-19, 08:52 AM
ironwood
Quoted: 426 Post(s)
"Fast" Eddy Merckx said the way to get fast is to "Ride lots.".
ironwood is offline
Old 08-08-19, 08:56 AM
ksryder
Bikes: yes
Quoted: 954 Post(s)
Liked 243 Times in 144 Posts
I mean I know plenty of people who ride thousands of miles a year who are slow. Literally every training program I've ever seen is basically variations on high intensity intervals. I didn't start getting faster until I did some targeted training.
Riding with other fast people also helps.
ksryder is offline
Likes For ksryder:
Old 08-08-19, 09:18 AM
Bandera
Quoted: 1109 Post(s)
Liked 144 Times in 93 Posts
"Fast" Eddie Mertz said the way to get fastis "Ride lots.".
Isn't that Fred Mertz, Ethyl's husband?
'74 Raleigh Internat'l. '77 Trek TX900 FG. '90 Vitus 979. '10 Merckx EMX3. '13 Soma Stanyan
Bandera is offline
Likes For Bandera:
Old 08-08-19, 09:37 AM
Brocephus
Professional amateur
Brocephus's Avatar
Bikes: Does a Big Wheel count ?
Quoted: 273 Post(s)
Liked 103 Times in 68 Posts
...or "Fast" Eddie Felson, from The Hustler ?
Brocephus is offline
