Small hatchbacks for hauling a bike or two..
Old 08-09-19, 08:28 AM
northbend
northbend's Avatar
Quoted: 261 Post(s)
Liked 102 Times in 36 Posts
Another very satisfied Honda Fit owner here. Owned since new in 2011, I've done many road trips with bikes in it to Montana, Oregon, Arizona, and California.
Super reliable, fun to drive, and economical.
(2) 60cm sized bikes w/o fenders, front wheels removed fit upright in the back with seats folded flat. A 3rd bike will fit upside down in between the two if you remove both wheels from the bike.
Fold down rear seats for 2 bikes by NBend, on Flickr
(1) bike fits upright behind the drivers seat with back seat folded up. (Preserves trunk space)
Fold up rear seats for 1 bike by NBend, on Flickr
One fendered bike will squeeze in the back with rear seats folded down but usually if I travel with fendered bikes, I'll take our 2018 Honda CRV. I can lay 60 cm fendered bikes flat in the back with the seats folded down. Blankets between bikes to protect their finishes.
northbend is offline
Old 08-09-19, 09:43 AM
seypat
Quoted: 1108 Post(s)
Liked 167 Times in 125 Posts
If looking for a used car, a Mazda 5 minivan will hold a bike inside with the rear seats folded down. It's a Japanese/Euro sized minivan with 4 cylinder engine, not an American sized minivan.
I have a 2013 model and have carried 4 different bicycles inside of it one at a time. You could lay two inside by removing front wheels, etc. and separating them with padded moving blankets.
EDIT:
(Interior view with rear 4 seats folded down and homemade cargo board added)
Probably the best of the used options. I have 2 2008s. On mine you can stow the 2nd row console, remove a 2nd row headrest and put 1 bike in without folding any seats or taking wheels off.(at least up to 56cm) It goes in at an angle with the front wheel between the 2nd row seats. Nothing beats having the sliding glass doors either. I actually hauled some 96" T12 bulbs last night without folding anything.
seypat is offline
Likes For seypat:
Old 08-09-19, 09:50 AM
seypat
Originally Posted by Kent T View Post
Ford Transit Connect minivan. Basically a tall small car. Enough room with a first generation to haul several bikes without issues, no removal of front wheels needed, and plenty of front seat room. Can be had with a tall enough roof easily.
These seem like the obvious choice. They have a 1000lb payload capacity. They are aimed at the empty nester and entrepreneur market. But, they have been plagued with transmission problems that start around 60k. They got a new 8 speed transmission this year. Maybe it will prove reliable. I plan on replacing one of the 5s with one of these. Just waiting for the shifting problems to be worked out as well as a more powerful engine. That's a Ford for you. You know the old sayings. FORD stands for:
Found On Road Dead
Fixed Or Repaired Dodge
Of course the Ford fans say:
First On Race Day
seypat is offline
Old 08-09-19, 09:58 AM
Jicafold
Jicafold's Avatar
Bikes: 1999 Schwinn Circuit, Mystery Bianchi 1985?, 1973 Raleigh Competition, 2005 Specialized Roubaix, Cinelli Centurion, My mom's 1980 Motobecane Mixte
Quoted: 123 Post(s)
Liked 7 Times in 6 Posts
With more space than a Golf or GTI, and cheaper than the newer Golf Sportwagen in the the Jetta Sportwagen. Made from 2009 to like 2014. Holds most any size bike with the wheels on. Plus there is that roof rack.
Jicafold is offline
Old 08-09-19, 10:15 AM
seypat
A couple of issues on the 2nd gen 2004-20010 Mazda 5 if you are looking. Both are relatively easily solved.
They had problems around 2008-9 with the passenger side liquid filled motor mount breaking. Both of mine had this problem. The one with higher mileage did break. I replaced the part on both at the same time. The mount on the 2nd one was beginning to break at 72k when I replaced it. A replacement can be bought for around $30 on the A-Mo-zon. The replacement is easy with no special tools needed. Takes about 10 minutes. There are videos online.
They also had tire mileage/durability issues due to the camber settings on the rear suspension. The factory camber arms were not adjustable. Replace the arms with an adjustable set, realign and the problem is solved. The parts are less than $100 and the job is easy. Videos are online. Other than that, a good vehicle.
seypat is offline
Old 08-09-19, 10:31 AM
kingston
Jedi Master
kingston's Avatar
Bikes: http://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1193 Post(s)
Liked 66 Times in 54 Posts
My 2007 Prius will hold two bikes if I take the wheels off and it gets 50 miles to the gallon.
kingston is offline
Old 08-09-19, 11:01 AM
FiftySix
I'm the anecdote.
FiftySix's Avatar
Bikes: Norco CityGlide, Schwinn Willy
Quoted: 401 Post(s)
Liked 221 Times in 168 Posts
I've got 103,000 miles on my 2013 Mazda 5 with the original motor mounts, so Mazda must have made some changes.
My wife's (now stepdaughter's) 2008 Honda Civic coupe is a motor mount busting machine. I've replaced the upper mount with torque link at least 5 times, and the transmission mount 2 times and the car has 150,000 miles on it. Just three weeks ago, I changed the upper mount, lower mount, transmission mount, and torque link all at the same time.
Back to the Mazda 5, I did replace the rear upper control arms with the adjustable variety just over two years ago. Mazda should have done that, or put in stronger rear springs from the factory, but they didn't.
FiftySix is offline
Old 08-09-19, 11:18 AM
seypat
When I replaced the motor mount on the 5's, I replaced all 3 mounts as well. Now I keep a watch on the passenger side mount. The 5s are really versatile vehicles and fun to drive. They do need more power. I was so disappointed when they were discontinued. If they would have offered it with the Speed 3 engine, what a sleeper it would have been! I have 131k miles on one and 82k on the other. The high mileage one is used as a delivery vehicle at my business. I'll keep driving it until they get the transmission problems worked out with the little Ford Transit Connect.
seypat is offline
Old 08-09-19, 11:49 AM
katsup
katsup's Avatar
Bikes: 1991 Fuji Sundance , 2017 Salsa Vaya
Quoted: 256 Post(s)
Liked 46 Times in 26 Posts
I currently just use my Accord sedan and take the wheels off.
I can easily fit 2 like this and 3 should be easy enough as there is still room on the seat. Drop bars are a little more difficult to fit, but they can be tetris'ed in. Plus there is the trunk space. For 1 bike, I usually just put the back seat down and only remove the front wheel.
I am planning on a hatchback to replace it, but their is no reason at the moment. I was looking at a Civic or Impreza hatch, will likely get the Civic as this Accord has no major issues in the last 16 years.
katsup is offline
Old 08-09-19, 12:44 PM
noobinsf
noobinsf's Avatar
Bikes: '82 Univega Competizione, '72 Motobecane Grand Record, '74 Campania Professional, '83 Mercian KOM Touring
Quoted: 373 Post(s)
Liked 67 Times in 51 Posts
I haven't seen mention of the Nissan Cube yet, so I'll mention it. I can fit a couple of bikes in there with the front wheel off. I now have a strappy hanger on the back, so bikes stay out, but it's cavernous inside. I once got a full size door home with it packed inside. When we lived in San Francisco, it was ideal for city parking. I see now that it's been discontinued in the US, not sure what the used market is like. We got the ultra-cheapo version with the manual transmission, and I plan to drive it till it dies.
noobinsf is online now
Old 08-09-19, 04:06 PM
jiangshi
Quoted: 276 Post(s)
Liked 5 Times in 4 Posts
Honda Element, if you can find a nice one. I have an SC, love it. Two bikes upright with little effort.
jiangshi is offline
Likes For jiangshi:
Old 08-09-19, 04:19 PM
iab
iab's Avatar
Quoted: 1443 Post(s)
Liked 160 Times in 109 Posts
Hot commodity around these parts. Over 200K miles will still get you $4K. 100K miles will get you $8K.
iab is offline
Likes For iab:
Old 08-09-19, 04:24 PM
verktyg
verktyg
verktyg's Avatar
Quoted: 557 Post(s)
Liked 117 Times in 84 Posts
Going a little far afield, in the 70's we had a Ford Econoline stretched body w/o side windows that we used for our shop van. We could fit 7-8 bikes standing upright in the rear plus 7 riders uncomfortably, 8 for a short trip.
verktyg
verktyg is offline
Old 08-09-19, 04:26 PM
2cam16
2cam16's Avatar
Bikes: TOO MANY
Quoted: 659 Post(s)
Liked 92 Times in 74 Posts
2001 Forester. Two on top and I still have tons of space inside with the rear seat folded. Easily carry a couple of bikes even with both wheels on.
IMG_4394 by 2cam16, on Flickr
2cam16 is offline
Likes For 2cam16:
Old 08-09-19, 05:43 PM
verktyg
verktyg
verktyg's Avatar
Quoted: 557 Post(s)
Volvo 940T vs. Subaru Forester
Nice rig. Is that a Specialized bike rack?
@Brad L too.
I had over 250k on my 1992 Volvo 940T wagon. I used it primarily for schlepping bikes around. Could easily fit 2 with the wheels on and the back seat down.
One afternoon about 3 years ago, my neighbor called and said she just saw my Volvo roll down the street. Apparently some idiot broke in and tried to steal the radio out of a 24 year old car.
When they released the parking brake and forced the shift lever out of park to get to the radio, the car started drifting backwards down the hill. They must have jumped out leaving the right side door open. It came to a stop when it ran into another neighbors car. The door was bent back over 120° and the door frame was twisted too. Time to put old Paint down...
The reason I mention this is while the Volvo was a much bigger car than my 1999 Subaru Forester, the rear cargo space with the seats down is the same. Optical illusion!
Several nice things about having bikes inside a car is they are less likely to be stolen by a thief in a hurry plus you don't have to worry about them getting wet if it starts to rain.
verktyg
verktyg is offline
Old 08-09-19, 06:23 PM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 357 Post(s)
Liked 412 Times in 269 Posts
Originally Posted by gomango View Post
Yes, they are cool.
I went through a string of these in the late 70's, as well as TR-6s.
In fact, our neighbor owns one of my GTs. Pale yellow, wire wheels etc.
However, I must also note that these were among the least reliable autos I've yet to own.
Just miserable little beasts. They loved to strand me in the middle of nowhere on a regular basis.
Luckily they were light and easy to push start. I always tried to park on hills where possible.
Been there, done that.
Blue with white stripes and top.
$2500 in 1980.
$2500 more and it still wouldn't go into reverse.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 08-09-19, 09:27 PM
2cam16
2cam16's Avatar
Bikes: TOO MANY
Quoted: 659 Post(s)
verktyg
Thanks! Don't get me started on the mods of my car.
Actually more like a Yakima with Specialized decals.
2cam16 is offline
Old 08-10-19, 12:16 AM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1381 Post(s)
Liked 88 Times in 59 Posts
I'm actually thinking of tracking down a first-generation Honda Odyssey. Crazy cheap, easy to find in good shape, 25+ MPG and built on the early 90's Honda Accord platform, probably the most reliable car in automotive history. I'll have to check one out, to make sure there's enough room for me to car-camp comfortably (sleeping on the floor with middle and back seats removed). I think it'd be a pretty spacious bike hauler, too.
Problem is, I'd then have to get rid of my early 90's Accord, and it's barely broken in with 304,000 miles.
● 1971 Grandis SL ● 1972 Lambert Grand Prix frankenbike ● 1972 Raleigh Super Course fixie ● 1973 Nishiki Semi-Pro ● 1980 Apollo "Legnano" ● 1981 Miyata 1000 ● 1984 Bianchi Limited ● 1984 Nishiki Landau ● 1984 Peugeot Vagabond ● 1985 Shogun Prairie Breaker ● 1986 Univega Nuovo Sport ● 1986 Merckx Super Corsa ● 1987 Schwinn Tempo ● 1988 Schwinn Voyageur ● 1989 Trek 400 ● 1989 Bottechia Team ADR replica ● 1990 Cannondale ST600 ● 1993 Technium RT600 ● 1996 Kona Lava Dome ●
Lascauxcaveman is online now
Likes For Lascauxcaveman:
Old 08-10-19, 04:49 AM
smontanaro
Bikes: many
Quoted: 478 Post(s)
Liked 34 Times in 26 Posts
Originally Posted by Lascauxcaveman View Post
1967 MGB GT. Sure, you’ll have to get a roof rack to haul bikes, but just look at that thing. Dang.
Runner-up: 1973 Volvo P1800 ES “Sport Wagon.”
I agree, though I'd reverse the order.
smontanaro is offline
Old 08-10-19, 04:51 AM
smontanaro
Bikes: many
Quoted: 478 Post(s)
Ellen has been on the lookout for awhile. Still no joy in Mudville.
Old 08-10-19, 04:54 AM
Stormsedge
Stormsedge's Avatar
Bikes: 2017 Trek Domane SL6 Disc, 1990 Schwinn Crosscut Frankenroadbike, 2015 KHS Team 29 FS *NEW BIKE*, 2000 Gary Fisher Tassajara--gone but not forgotten
Quoted: 140 Post(s)
Liked 18 Times in 10 Posts
The dreaded (and unsexy) minivans can hold two plus bikes inside with the front wheels off...use a fork/axle rack mounted on a piece of 8x10 the width of the rear shelf. I carry one of my bikes on trips in this manner all the time. Lots of extra interior room for luggage and gear too.
Stormsedge is offline
Likes For Stormsedge:
Old 08-10-19, 05:42 AM
gomango
Quoted: 703 Post(s)
Liked 28 Times in 22 Posts
I'd take one of those in a heartbeat for our youngest son if I could find one.
Honda should return this model to the market with a similar design. I wonder what their sales numbers looked like when it was discontinued?
Bikes and stuff
https://www.flickr.com/photos/36270004@N06/
gomango is offline
Likes For gomango:
Old 08-10-19, 05:44 AM
verktyg
verktyg
verktyg's Avatar
Quoted: 557 Post(s)
Brit Beasts
$2500 in 1980.
You guys are SICK!
I have just what you need for getting Brit cars running in tip top shape:
verktyg
verktyg is offline
Likes For verktyg:
Old 08-10-19, 06:04 AM
smontanaro
Bikes: many
Quoted: 478 Post(s)
Particularly in this day of "we only sell trucks and SUVs."
Old 08-10-19, 06:36 AM
cb400bill
Moderator
cb400bill's Avatar
Bikes: Fuji SL 2.1, Schwinn Voyageur, Cannondale Synapse
Quoted: 1373 Post(s)
Liked 163 Times in 103 Posts
cb400bill is offline
