Tyre pressures
Tyre pressures
Old 08-24-19, 06:21 AM
strumbuddy321
Tyre pressures
whats best tyre pressures
strumbuddy321 is offline
Old 08-24-19, 02:00 PM
adipe
Quoted: 31 Post(s)
Liked 4 Times in 4 Posts
the best psi values are those above 0.
seriously now... this is quite easy to answer.
1. rear wheel is best pressured as to insure best rolling resistance. too high psi or too low increase RR. you should compare looking at the clock for a given wattage and compare psi values by this.
2. front wheel is best pressured as to insure best control of the bike, best grip available dry and wet. RR is very less relevant for the front wheel, control in braking and in turns is much more important when figuring out tire pressure.
so... there are no fixed values because everyone should adapt psi for given actual and possible/probable circumstances.
i'd say i very much like a 50mm rear tire or even a 60 (not yet mounted) with a 40mm front tire. this 50-40 combo is now what i use and somewhere in the future i plan to mount a 60 in the back. a narrow front tire is chosen not for being more aero or anything like that but for better grip when wet and more puncture resistant (a sudden puncture in the front wheel can be very dangerous) because i would not have a wide tire in the front with a low pressure.
so... 88kg bike+rider for this combo (29er) has the same pressure both front and rear: 2.5bar (36 psi).
this combo is useful for an electric bike with a hub motor and a rear rack mounted battery.
why so many started threads in the same day?... 6 total posts... this is very dubious.
anyway, there are many answers you can find to this very question if you search using the search function on this forum...
adipe is offline
Old 08-26-19, 02:48 AM
strumbuddy321
thanks for your reply most helpful
Simple reason why, is because I cant post images, cant do something else cant remember now until I have made so many posts. I think its 12 posts, just seem to be a silly thing, so hence why i have made so many posts
Old 08-26-19, 10:15 AM
MikeyMK
Cycleway town
MikeyMK's Avatar
Bikes: 2.6kw GT LTS e-tandem, 250w Voodoo, 250w solar recumbent trike, 3-speed shopper, Merlin ol/skl mtb, 80cc Ellswick
Quoted: 496 Post(s)
Liked 121 Times in 91 Posts
Depends on the bike and it's tyres. I have a tandem on balloons, heavy rear hub, i'll bet my tyre pressures are a bit different than the next guy's.
MikeyMK is offline
Old 08-26-19, 03:05 PM
restlessswind
Bikes: Surly Cross-Check, 2020 Specialized Turbo Vado 3.0, 1974 Raleigh Sports, 1995 Gary Fisher Hoo Koo E Koo -Grateful Dead Ed, 1999 Univega Tandem Sport, Firmstrong Urban Deluxe, Electra Cruiser 1, Raleigh Special 3
Quoted: 125 Post(s)
Liked 35 Times in 22 Posts
There is a range specified on the sidewall. I start with the max pressure on the rear wheel, and then reduce until it is not too harsh/ hard. Even softer on dirt or loose gravel roads. Inflate the front wheel to same minus 10% pressure. (eg. 60 psi rear, 54psi front) THIS IS JUST THE STARTING POINT. Adjust accordingly.
Different tires and different riding conditions dictate adjusting.
restlessswind is offline
Old 08-26-19, 04:26 PM
slomoshun
slomoshun's Avatar
Bikes: Treks and a Moulton
Quoted: 64 Post(s)
Liked 2 Times in 1 Post
> ..I start with the max pressure on the rear wheel, and then reduce until
Keep in mind when dropping psi that tire pressure is an important factor in the wheel assembly's strength and rigidity.
slomoshun is offline
Old 08-27-19, 09:13 AM
adipe
Quoted: 31 Post(s)
the maximum pressure is the limit beyond which you can damage the casing of the tire. some tires puncture more easily just because the nylon puncture protection (basic one) has it's plies loosened from plastic deformation when you inflated to tire to a certain point.
the maximum pressure is there so that you will know that for a given weight you should just take a larger tire and do not go beyond that pressure limit.
you should reduce pressure not necessarily by feel but by measuring speed or rolling resistance with the clock. rolling resistance can't be accurately discerned by regular people.
you might find that an even lower pressure is best than what you think is ok now - not being harsh enough is not a good enough assessment.
be sure to lower pressure comparing speed only for the rear wheel pressure adjustment and set the pressure on the front just by feel regarding the whole thing being stable in turns, braking, dry and wet. doing so one wheel at a time means more time but more sure results. also, ensure the tire size so that the right pressure for that size makes it possible to have the least risk of flats.
that's one of the reasons i recommend putting a narrower tire upfront especially if you have it on your hands; changing the rim width is not easily done.
a front tire no larger than needed for proper pressure and also not too much sideway flex for a given rim. rear is no big deal if it has more sideway flex.
adipe is offline
Justsomedude
Singlespeed & Fixed Gear
28
01-06-15 08:08 AM
whitemax
Road Cycling
47
04-10-14 01:27 PM
sreten
Folding Bikes
49
02-17-13 07:10 AM
velopaul
General Cycling Discussion
20
07-22-11 11:55 AM
ramjet1953
Bicycle Mechanics
5
07-04-10 10:20 PM
