Anyone see this kind of damage before?
Old 09-13-19, 09:37 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 882 Post(s)
Liked 394 Times in 191 Posts
Originally Posted by Noahma View Post
So I guess my next question will change the conversation a bit. So, the wheel is getting replaced. I tend to stick to myself when riding and dont know many of the shops or reputable wheel builders in my area. I know there are some, just dont know which ones.
Does anyone have any recommendations of places around the Boulder / Denver Colorado area I can bring my wheelset to, to have someone look over them and see what may need to be changed?
And a rough idea of what I should be expecting in costs to have someone take a peak?
There's a ton of great options in that area. Some of the shops are legendary and have great talent. I am sure I know wuite a few builders in that are but nothing is ringing a bell at the moment.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 09-13-19, 09:47 AM
Shimagnolo
Shimagnolo's Avatar
Quoted: 2193 Post(s)
Liked 1,344 Times in 728 Posts
Originally Posted by Psimet2001 View Post
2. Given we have established the builder either doesn't know or knows and is more of a "hey, I do what the companies say I can do" then I have a feeling the builder also used Velocity's guideline for the tension on those rims. As a general rule of thumb we don't get to that high of a tension. IMHO their rims have always carried too much of a tension rating for spokes. I believe your builder ran the initial tensions to that limit...assuming they were an actual builder and used a tensiometer. If they are the kind of builder I think they may be then they missed the part about that tension rating from Velocity being a "Max" tension. Instead thinking it should be the mean tension. Example: Speed limits actually mean that is the fastest you should be driving in that ares - not the actual speed that all must be driving at.
I build my own wheels and have been using Velocity rims exclusively on 3 bikes for years. (Synergy, Aerohead, A23).
On this page Velocity says 110kgf to 130kgf for tension: https://www.velocityusa.com/tech/rims/
Well, after getting cracking at spoke holes after 2-3 years use, I've dropped to 100kgf, and haven't had one crack since. Note that all these rims are 32H or 36H, and I am 180#.
Shimagnolo is offline
Old 09-13-19, 09:48 AM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 332 Post(s)
Liked 166 Times in 123 Posts
The rim itself doesn't just assplode. It fails under tension form the spoke. This failure is always caused by spoke tension. Meaning the tension from the spoke is what leads to the plastic deformation and catastrophic failure of the rim.
Clarification: It is the stress cycling of the spoke tension from every revolution of the wheel that leads to fatigue failure of an aluminum rim.
The fatigue failure was always going to happen even at low tensions. It was just a matter of how many loading cycles it would take.
Fatigue failure is a fact for any aluminum part, since aluminum does not have a fatigue limit. Put it through enough stress cycles, and any aluminum part will break. It's the designer's job to make sure it doesn't fail within its expected time of use.
Ride, Rest, Repeat
terrymorse is offline
Old 09-13-19, 09:51 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Quoted: 882 Post(s)
We seldom go up to 110 and are more in the 100 range as well.
Old 09-13-19, 09:57 AM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Quoted: 882 Post(s)
Clarification indeed - my point was that without tension on the spoke there is no cycling of stress. Good to run into you out here. It feels like forever. Hope all is well!
Indeed - that's what I am trying to say in one of the posts a few back. Not just the designed but also the builder understanding this. Also most of the people who build wheels do so from an "instructional" standpoint. They do what they were taught. They don't understand what's going on with the materials and have no appreciation for any aspect of it other than, "uh the rim company told me I could do XYZ".
I remember calling Matt out at Velocity back when they moved the US and were vetting extruders and I had so many problems. "Are you ISO or QS or other quality system certified? If so can you please send me a copy of your resultant corrective actions?"
Likes For Psimet2001:
Old 09-13-19, 09:58 AM
frogmorton
Quoted: 11 Post(s)
Liked 23 Times in 12 Posts
Originally Posted by dmanthree View Post
I did that to my stock wheels on my 2017 Roubaix. The spokes started to pull away at nearly every connection point. Spoke tension may have played a factor, but sometimes it's just the wheel. It will happen to all alloy wheels in time.
I have a 2017 Roubaix and the rear wheel (Axis Elite) broke 3 spokes over the course of two years. At about 5500 miles I just bought new wheels because I wasn't trusting those wheels on a long ride.
frogmorton is offline
Old 09-13-19, 10:06 AM
Shimagnolo
Shimagnolo's Avatar
I'm here in the area, but I've never done work for others before.
I just pinged a couple local guys plugged into the local scene to see if they have recommendations.
Old 09-13-19, 10:14 AM
Noahma
Bikes: 2017 Orbea Avant M40, 2019 Trek Checkpoint ALR
Quoted: 28 Post(s)
Liked 5 Times in 4 Posts
@Shimagnolo , Thanks! I appreciate it!
Noahma is offline
Old 09-13-19, 10:21 AM
ljsense
ljsense's Avatar
Quoted: 213 Post(s)
Liked 88 Times in 49 Posts
No one has mentioned the spokes themselves. I can't tell from the photo for sure, but these look like straight gauge spokes. I'd rather have a spoke break before a rim.
Rims need tension to make a strong wheel. It's like building an arch. If a rim calls for a lot of tension, and it's a light alloy, I think it pairs best with a wispier spoke that's been swaged down or, as most people say, butted. This makes the spokes more elastic. When tension increases, the spokes stretch and the rims encounter less fatigue. As the spokes stretch and unstretch, yes, eventually they'll break.
Anyway, great points by Psimet and others -- but I always look at the spokes themselves as a big part of the wheel building equation.
ljsense is offline
Likes For ljsense:
Old 09-13-19, 10:47 AM
Noahma
Quoted: 28 Post(s)
@ljsense To be honest, I dont remember if they were double butted or not either. I will have to check my paperwork when I get home. In the past I have just ran with the wheels that came with the bike lol. I am learning a whole ton about wheels now that I have had a failure. I enjoy the knowledge. Thanks!
I contacted an acquaintance that is part owner of a shop and asked him for a few names. I think once I get the bike back I will get a second set of eyes on the wheels to see if they were laced up correctly, and get things modified if necessary.
Noahma is offline
Old 09-13-19, 11:20 AM
Shimagnolo
Shimagnolo's Avatar
Grip a spoke between thumb and forefinger, then slide your grip from one end of the spoke to the other.
If it is butted, you will clearly feel the transition areas as you slip over them.
Old 09-13-19, 11:33 AM
Shimagnolo
Shimagnolo's Avatar
OK, I just got a recommendation from one of my friends:
Sunny Waas at Velo-Stop here in my town: https://www.velo-stop.com/
He tells me Sunny is building the wheels for Lennard Zinn's custom bikes.
Embarrassing thing is I ride by this shop every time I ride, and didn't even know it was there.
I think it recently moved here recently, and is located on the back side of a light industrial park.
ETA: The shop just moved to this location a month ago.
Old 09-13-19, 12:41 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Quoted: 882 Post(s)
The spokes are actually a much smaller part of the overall process than many realize. They truly just transmit the tension. Their cross sectional size and material composition determine the amount to which they elongate under the load cycle they see. This doesn't translate into an affect on the rim though in as much as long as the tension is carried to the rim then it matters not what shape that tension member is. Think of the degrees of freedom in the connection. It starts to become clearer that it's really just pulling on it (save for some moments caused by torsion/braking).
I wrote what I thought was a pretty good break down on spokes on my site: https://www.psimet.com/blog/spoke-se...icycle-wheels/
Old 09-13-19, 12:54 PM
ThermionicScott
7-speed cultist
ThermionicScott's Avatar
Quoted: 2788 Post(s)
Liked 716 Times in 503 Posts
You must have missed my post.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 09-13-19, 01:14 PM
Noahma
Quoted: 28 Post(s)
I just heard back from Velocity, they have determined that the rim was defective and is sending me a new rim and nipples.
Just a personal note after looking back at the picture, it is not showing clearly where the crack started. It started in the horizontal area of the wheel and not at the spoke hole.
I will still get a 3rd party to look at the wheels after they are built just for a piece of mind.
Thanks all for your input, I learned quite a great deal through the experience!
Noahma is offline
Old 09-13-19, 02:05 PM
Noahma
Quoted: 28 Post(s)
Thanks! I will check them out. The wheels do have double butted spokes. I was able to verify it with my mechanic who has the bike at the moment. They are actually very close to where I ride frequently!
Noahma is offline
Old 09-13-19, 02:46 PM
ThermionicScott
7-speed cultist
Good on Velocity for making things right.
It looks like the crack occurred where the rim transitions between the thick area at the spoke drillings and the thinner walls. There could be a stress riser at that point if the transition isn't smooth enough. But it very well could not be the rim's fault either way.
RUSA #7498
Old 09-13-19, 02:50 PM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 401 Post(s)
Liked 82 Times in 57 Posts
I took mine back to the LBS who got Specialized to exchange them for a set of Roval SLX 24 wheels.
dmanthree is offline
Old 09-13-19, 03:08 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 184 Post(s)
Liked 31 Times in 24 Posts
My first "Road" bike was a Raleigh Sojourn and the rear factory wheels did exactly that at about 4,000 miles. Not just one place, but multiple places were starting to crack like that.
Raleigh replaced that under warranty with a different wheel with 36 spoke instead of 32 but lesser rim, and it fell apart after about 500 miles.
I had a wheel built up by a local wheelbuilder and rode it thousands and thousands and thousands of miles.
StephenH is offline
Old 09-13-19, 03:38 PM
ljsense
ljsense's Avatar
Quoted: 213 Post(s)
Yeah, I get what you're saying. I know that all a spoke can do is pull.
But if a spoke can stretch a little, be elastic, it won't pull as hard against whatever it's attached to when a force acting on the wheel tries to change its dimensions. You know what I'm saying? Basically, something's gotta give. If the spoke can't stretch, it will try to make the aluminum rim wall stretch.
Some DT Swiss guy said in an interview that their butted spokes -- which they make by forging wire -- have a bit more elastic stretch than straight gauge.
ljsense is offline
Old 09-13-19, 06:32 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 332 Post(s)
That's right. Using a more elastic spoke (a double-butted spoke vs a straight gauge spoke) means that the rim is not put through as large a stress cycle (max stress minus min stress) as the rim flexes under load, then rebounds.
Reducing the stress cycle size increases the life of the rim, even though both spoke types produce the same max tension.
Ride, Rest, Repeat
Old 09-14-19, 03:23 PM
bocobiking
bocobiking
Bikes: 1974 Schwinn Paramount, 1974 Raleigh Super Course, 1984 Columbine, 1979 Richard Sachs, 2003 Serotta Legend Ti, 2005 Serotta Concours
Quoted: 29 Post(s)
Liked 14 Times in 9 Posts
See Jim at Vecchio's in Boulder on Pearl Street. He's the shop owner and he's been building wheels for years, including mine.
bocobiking is offline
Old 09-14-19, 10:15 PM
Chi_Z
Chi_Z's Avatar
Bikes: Niner RLT 9 RDO
Quoted: 249 Post(s)
Liked 50 Times in 39 Posts
that's what happens when they try to squeeze every gram out of the rim, my 480g H Plus Son Hydra is pretty much bombproof
Chi_Z is offline
armybikerider
Bicycle Mechanics
7
07-28-14 10:16 PM
onespeedbiker
Bicycle Mechanics
11
11-01-12 07:33 AM
gearbasher
Classic & Vintage
13
06-07-11 11:25 PM
Freefallman
Bicycle Mechanics
8
09-03-10 04:38 PM
BloomingCyclist
Tandem Cycling
39
03-01-10 02:23 PM
