Your nomination for worst C&V parts/components
Old 07-17-14, 07:03 AM
Chrome Molly
Chrome Molly's Avatar
Bikes: Yes
Quoted: 300 Post(s)
Liked 8 Times in 8 Posts
Apologize if this has been done before, but I have just found my nomination for this combined category:
Most non-functional
Almost good enough ideas that became an actual part
Least reliable...
You get the picture.
I'll go first. My nomination is Sugino Autex crank bolts. These were intended to be self extracting crank bolts, but they use a relatively small allen size and you can't seem to get needed leverage for anything that becomes stubborn. Get a key that has the leverage and they will strip relatively easily. They probably work fine on well greased and relatively new cranks (you know, the ones you wouldn't need to extract outside a shop environment). I get it as a relatively good idea, but have determined this was probably in support of Sugino's secret joint venture with EZ Out. All is well, and the bolts were drilled out, the aluminum housing spun out very carefully, and the crank extracted with a normal puller.
Your turn...
Chrome Molly is offline
Old 07-17-14, 07:17 AM
SJX426
SJX426's Avatar
Quoted: 520 Post(s)
Liked 48 Times in 36 Posts
I think there is a thread on this already, but old. My vote would be the Campagnolo seat post pinch bolt. If one fails and you must have Campagnolo, buy in bulk and break the bank!
Another one that is irritating is the bicycle wireless computers. Two batteries to replace and possible RFI with your computer wireless hub.
Lawyer lips on forks is a forking waste of thought and a constant irritant.
Left lever/front brake. I grew up with right lever/front brake and then motorcycles are the same. I really don’t like the left lever/front brake set up. I change them all and the routing of the cable is problematic, specifically for aero brake levers.
Why is the RD relaxed position aligned with the smallest cog and the FD the same way? Why not have them both relaxed in the outward most position? It is tough to align the FD to clear the outside ring when attaching to the frame and then getting the cable the right tension.
Oh, this was about parts not design or both? Can you really separate them?
SJX426 is offline
Old 07-17-14, 07:26 AM
BradH
Catching Smallmouth
BradH's Avatar
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 38 Post(s)
Liked 5 Times in 4 Posts
I'm not sure when it took place, but at some point fork design necessitated unscrewing the front QR skewer in order to remove the wheel. Annoying design.
Compact double and 39/53 cranksets paired with DT shifters. Obviously a conspiracy to sell STI shifters. With STIs you can make double shifts when jumping from the big to small ring, shifting the rear at the same time so as not to go outside your preferred cadence range. With DT shifters a 42/52 seems to keep me much happier.
BradH is offline
Old 07-17-14, 07:27 AM
rootboy
rootboy's Avatar
Quoted: 533 Post(s)
Liked 52 Times in 37 Posts
I've never broken a Campagnolo seat post bolt. Knock on wood. But I don't cinch them down all that tightly.
Watch. Now that I've said it …..
rootboy is offline
Old 07-17-14, 08:14 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1910 Post(s)
Liked 240 Times in 172 Posts
I've broken several, and I now carry a spare with me when I ride. I've tried not cinching them down firmly, but then the post slides down while I'm riding. And due to the breakage risk, I became reluctant to re-secure it while on the road. So now I tighten as much as I dare, and carry a spare so I can re-secure on the road if necessary.
JohnDThompson is offline
Old 07-17-14, 08:57 AM
rootboy
rootboy's Avatar
Quoted: 533 Post(s)
Probably a good policy, JDT. And, as I remember, you have piles of them. :>
I think I have one spare so I might as well throw it in the saddle bag when I ride.
Again, knock on wood.
I've never noticed the post slipping but that may be because I'm a scrawny lightweight. Don't know.
I feel like I'm definitely jinxing myself writing about it.
rootboy is offline
Old 07-17-14, 09:02 AM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 141 Post(s)
Silva "laminated" leather/plastic toe straps. The factory in Italy must have used gradeschool Paste to "laminate" the strap layers together. After one ride, they are totally trashed.... looks nice in their box brand new though.....
Chombi is offline
Old 07-17-14, 09:34 AM
sloar
Bikes: they change so much I'm tired of updating this
Quoted: 789 Post(s)
Liked 64 Times in 30 Posts
I really hate messing with the front bolt on the nuovo record seatpost. Other than that small issue, no other complaints. Now modern components, I really hate the removal of the new campy cranks.
Semper fi
sloar is offline
Old 07-17-14, 09:41 AM
Velognome
Get off my lawn!
Velognome's Avatar
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 70 Post(s)
Liked 10 Times in 7 Posts
Velognome is offline
Old 07-17-14, 09:54 AM
John E
feros ferio
John E's Avatar
Quoted: 762 Post(s)
Liked 90 Times in 77 Posts
Early 1970s HiE front QR skewer, a minimalist aluminum design which occasionally failed in use.
John E is offline
Old 07-17-14, 09:58 AM
Narhay
Narhay's Avatar
Quoted: 605 Post(s)
Liked 20 Times in 19 Posts
Suntour barcons.
Just kidding...they're the best way to shift anything 5-6-7 speeds.
Narhay is offline
Old 07-17-14, 10:19 AM
SJX426
SJX426's Avatar
Quoted: 520 Post(s)
Campy pinch bolt. With the last purchase, decided I could only get two, I started using anti-seize on the threads. I found that with a greased post and my weight, the torque required is near the limit of the bolt. Due to the design of the clamp, the bolt head surface has more force on the rear of the tang than the front next to the seat lug, with higher, uneven force causing the shaft to bend. My hope is that with the added lubrication, the threads will not gall as much and actually unscrew instead of "ripping" the shaft. It is only hope because the physics and mechanics don't provide anything but indication of eminent failure!
SJX426 is offline
Old 07-17-14, 10:20 AM
Pompiere
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T
Quoted: 235 Post(s)
Liked 26 Times in 23 Posts
Steel rims with dimples, supposedly to make them work better in the rain. They don't work any better wet, and make an annoying buzz when dry.
I have a Simplex derailleur with a broken frame clamp in the junk box.
Pompiere is offline
Old 07-17-14, 11:35 AM
kunsunoke
spondylitis.org
kunsunoke's Avatar
Bikes: '90 Bridgestone MB-1; '85 Trek 600; '01 Cinelli Supercorsa; '89 Bridgestone RADAC 3100; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special
Quoted: 65 Post(s)
Liked 7 Times in 7 Posts
Shimano Positron II derailleur (DG-200)
Shimano Positron FH derailleur (PF20)
The horror that was Shimano Positron / Front Freewheel System.
600 ARABESQUE AND THE VELO SPORT "CRITERIUM"
Shimano "one-key release".
I need a mallet to install and secure my crankset? Really?
VeloBase.com - View Group
The "yeeccchhh" that was the Euclid group.
VeloBase.com - Component: Aerospoke (composite 650C)
...And hipsters deserve them.
VeloBase.com - Component: AVA
Fix it, Pierre - I happen to like the teeth and skull I already have.
VeloBase.com - Bicycle Model
They have their fans, but these bikes launched a trend towards bone-rattling ride characteristics.
VeloBase.com - Component: Selle Italia Sprint suede
VeloBase.com - Component: Cinelli Unicanitor #2 suede
Suede has no place on a bike saddle, IMO.
kunsunoke is offline
Old 07-17-14, 12:17 PM
BluesDaddy
I got 99 projects
BluesDaddy's Avatar
Quoted: 42 Post(s)
Shimano Z401 Friction[less] Shifters
BluesDaddy is offline
Old 07-17-14, 12:24 PM
SJX426
SJX426's Avatar
Quoted: 520 Post(s)
Originally Posted by kunsunoke View Post
I forgot about that one! If you like them, I have one I would happily sell you!
SJX426 is offline
Old 07-17-14, 12:30 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1163 Post(s)
Liked 155 Times in 112 Posts
Peugeot steel seat posts that slowly slipped through the seat clamp up and into the leather Adga saddle, until the day you find you are firmly impaled on your bike. Say no more, move along.
clubman is offline
Old 07-17-14, 12:38 PM
acoffin
acoffin's Avatar
Bikes: 72 Lygie (SS conv), 87 Ironman Expert, 94 Allez Sport, 16 Black Mountain Cycles Monstercross
Quoted: 17 Post(s)
Raleigh "Self Adjusting" brakes.
acoffin is offline
Old 07-17-14, 12:49 PM
SJX426
SJX426's Avatar
Quoted: 520 Post(s)
LOL Italian paint and decals! Durability is not an attribute!
SJX426 is offline
Old 07-17-14, 01:27 PM
Wildwood
Veteran/Pacifist/Resister
Wildwood's Avatar
Quoted: 2024 Post(s)
Liked 307 Times in 221 Posts
IMHO, Campy Delta brakes are sub-standard - from a stopping-the-bike-quickly perspective
Wildwood is offline
Old 07-17-14, 01:52 PM
1987's Avatar
Bikes: Cinelli SC 1971, Daccordi 1985
Quoted: 50 Post(s)
If we are talking high rated vintage stuff. Then I would say that the weakest part of the Campagnolo Record Group is Nuovo Record rear derailleurs gear cable fastening. If you tighten the steel bolt to hard it will shred the threads in the aluminium derailleur if you tighten it to loose you can't change gears as the gear cable just slides.
1987 is offline
Old 07-17-14, 02:16 PM
rootboy
rootboy's Avatar
Quoted: 533 Post(s)
Ditto. Funky design. And the wrench they designed for it is nearly useless, imo.
rootboy is offline
Old 07-17-14, 02:20 PM
1987's Avatar
Quoted: 50 Post(s)
The original wrench is completely useless. I use a ratchet wrench and that makes it easy to set the position of the micro adjust system.
1987 is offline
Old 07-17-14, 02:37 PM
Chombi
Chombi's Avatar
Quoted: 141 Post(s)
Castelli branded lycra backed cycling gloves sold in the 80's.....
Bought a pair back in the 80's from my LBS as they looked delicious waiting for me in my LBS display case with their black and bright yellow Renault/Gitane style striping on their lycra backs and very soft and luxurious feeling goatskin palms,...... so, I slowly put aside some college food money till I can afford to buy them.............Now they still sit in my dresser drawer sitll unused to this day.....because the stitching on the gloves started unraveling all over after using it on just one ride back from the LBS that day I bought it almost 3 decades ago....
Beautiful....but junk in the end.....
Chombi is offline
Old 07-17-14, 02:41 PM
bconneraz
bconneraz's Avatar
Bikes: Cimarrons 1835, 0836, 1767, 3517, 0768, 3408, a LHT, and a couple others
Cannondale velcro water bottle/holder combo. Seemed cool until you used them for a while, and the velcro wore out.
bconneraz is offline
