German City bike with a derailleur and internal hub!Hi Low range
Quoted: 147 Post(s)
Liked 331 Times
My brother in law spotted this German city bike in a junk place and picked it up for me.Aluminum tubes,Cute little tool box,lock,dynamo, a derailleur and an internal hub! Hi Low range
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Broken ESGE rack. Had one on a Koga Miyata that was wired and soldered together to fix the plastic. Is that a woods valve tube?
Sachs Commander RD. According to Mike Sweatman's Disraeli Gears listing, that RD and shifting system actually preceeded Shimano's SIS. Indexing was based on a rotating stepped cam. It's paired with what's very likely a Sachs 2-speed rear hub to eliminate the FD.
I'd guess there's a good reason it didn't catch on. Two come to mind: weight and function. I'd guess the RD's shifting simply didn't work as well as SIS - especially since the RD didn't have a slant parallelogram.
But I could be wrong.
Likes For Hondo6:
feros ferio
Quoted: 1393 Post(s)
Liked 1,330 Times
I like hybrid transmissions. My personal favorite was a 14-16-18-20 cog cluster on an otherwise standard Sturmey-Archer AW hub with an elongated rear axle. 10 unique ratios out of 12, with useful redundancies at LOW 14 / MID 20 and at MID14 / HIGH 20. With the S-A trigger mounted right under the left brake lever and a standard downtube lever for the derailleur, double shifts were a breeze. Easy to downshift while stopped for easy restart, without having to plan a downshift in advance. Heavy and klunky, but fun.
Likes For John E:
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
Cool setup. Sachs had a 7 cassette hub like that I really needed at one time.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Example: https://www.sturmey-archer.com/en/pr.../cs-rf3-silver
Specifications: https://www.sturmey-archer.com/files...0IGH%20F30.pdf
The product link is to the silver rim brake version; black is also available. They also have disc brake versions.
Provided for info; I haven't used one. But I've considered it.
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
I'd like to see what model freewheel this system is running (my assumption is that they didn't use a 5-speed cassette). It looks to be approximately 13T or 14T by 24T, which is narrow range gearing for a city bike.
BTW, I've been riding a SRAM Dual Drive system since 2003 on my Cannondale. It's a 3-speed IGA and a 9-speed cassette (spaced 130mm). It evolved from this Sachs system, which is a new variation that I've not seen before. Is the RD branded "Sachs?"
Bob
Bob
feros ferio
Liked 1,330 Times
Sturmey-Archer still makes one - 3x internal with 8/9 speed Shimano-type freehub and 135mm rear OLD. (I've read elsewhere that they can be respaced down to at least 130mm.) ... I believe the IG part requires an indexed front shifter and doesn't "play nice" with friction shifting, though.
Further: in the documents page for this entry, Sweatman alludes to a Sachs-only-branded ("Sachs Commander") version. I'd guess this example to be one of those.
Sweatman's website also says there was an earlier Huret version of the Commander produced before Sachs bought Huret. But the photo of the Huret Commander on his site shows the word "Huret" spelled out before the "Commander" on the outer parallelogram plate, and that doesn't seem to be the case here.
Strong Walker
Patria WKC is a brand with a lot of Pedigree, they were among the very few larger german makers of high end racing bikes after WW2.
a 1949 lugless design:
The frame of the thread creator is not Aluminum though, it is lugged steel. The rest of the bits on it (like the notoriously bendy pressed Thun "Aero Coronado" crank) are lower middle class. A Workhorse.
Likes For martl:
Quoted: 3814 Post(s)
Liked 3,345 Times
thanks so much for this post!
a couple years prior to the Sachs acquisition of Freres Huret a Huret branded hybrid gearing system launched under the name Orbita
recall reading a review of it in BICYCLING! magazine about 1976 (estimate date from an imperfect memory)
Sachs did a hybrid gearing system called Orbit
IIRC its launch was subsequent to the launch of the Huret Orbita system
Liked 3,345 Times
Strong Walker
Liked 3,345 Times
...would think it simple eno' to check the three main tubes with a magnet...
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
One can sort of see the first four letters, A, L, U, M, wonder what else it could refer to (?).
Quoted: 811 Post(s)
Liked 1,024 Times
Very nice and functional looking bike. I am a fan of hybrid gearing. I like three speed plenty, but always think that I need some in-between nowadays now that I have gotten used to be able to match my cadence to the gears so well. Back when I was younger, I thought three speeds are all you really need.
This looks like a great city bike. Being able to shift while stopped is great plus. You never know when you will be cut-off or obstructed when riding in urban areas. This also had a chainguard originally, which is another plus with hybrid gearing and use as a commuter. Dynamo lighting adds to the commuter functionality. I used to prefer the bottom bracket dynamos, but these bottle dynamos work well and being located on the front wheel allows you to keep an eye on it if the alignment shifts.
Thanks for showing it off here @garryg . Not a fancy Italian exotic, but a good and unusual bike for North America. We don't get to see stuff like this too often.
Strong Walker
Bianchi Goddess
Liked 2,934 Times
Sturmey-Archer still makes one - 3x internal with 8/9 speed Shimano-type freehub and 135mm rear OLD. (I've read elsewhere that they can be respaced down to at least 130mm.) SA also says they're "MTB/ATB" front/rear shifter compatible (Shimano, presumably). I assume they'd take a 10-speed cassette too with proper spacer, but then you'd have to run mismatched shifters (MTB front, road 10-speed rear). I believe the IG part requires an indexed front shifter and doesn't "play nice" with friction shifting, though.
Strong Walker
you may be right and I may be wrong. This may just be a highly unusual very special design... I'll Inquire!
Edit: found it. They actually marketed this very strange design as "unique aluminum glued". I assume the alu tubes are glued to steel stubs, which are then brazed to lugs traditional style. Talk about making things complicated for minimal gains
https://velopedia.online/Document/Show/845
Freewheel Medic
Liked 2,197 Times
@juvela , thanks for posting the technical brochure and the link. Very interesting system.
Bob
Bob
Liked 3,345 Times
garryg -
in case you are curious as to date it is possible the Weinmann 605 calipers may carry a marking on the backside of the caliper arms
if present, it will be in the form of a clock face -
if not present it just means cycle manufactured prior to introduction of this marking system
thank you so much for sharing this most interesting cycle with the forum
garryg -
Consider that the headtube and "lugs" may be a single piece with no brazing, just made to look like conventional bike construction. Trek did that too.
