klein quantum ii - steering wheel problem
Hi I just bought my klein quantum ii however, I have a problem with setting him under me.
steering wheel is too low I tried the standard knock up but it did not help.
I wanted to ask if there is some "special" thing I need to do? or maybe I have to hit harder ?
GATC
Good luck...
Seized Seatposts and Stems | Park Tool
It can be useful to apply a light lubrication into the stem/column joint. It can also help to loosen the headset locknut. The headset locknut may have a seal and prevent any fluids from getting to the column. The bond material is typically of an alkaline base. It can help to use a mild acid to weaken the bond, such as lemon juice or some soda pops. Allow some time for the acid to work.
You Know!? For Kids!
Can you post a picture? The Quantum ii could be either threaded or threadless headset depending on the year it was made. The adjustment procedure is very different between the two types.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
