how the !@#$ do you get a chain pin back in?
Old 03-27-11, 07:17 PM
  #76
scruggle
Originally Posted by martinus
Smart.
It's even smarter to know the basics of chain installation before trying one's hand on a $50 chain. Failing that, one can still be part of the smart kids' crowd by buying a masterlink instead of Rube-Goldberging a pin back in.
All things seem fine until they don't; 'seems fine' isn't a great metric for what I'd put my safety on when there are cheap and easy alternative solutions. Also, a chain doesn't care whether you're commuting or racing. Even in the commuting case I'd just as soon not be late to work or stranded even if I didn't get hurt.
scruggle is offline
Old 03-27-11, 11:10 PM
  #77
macnab
macnab's Avatar
Bikes: Litton, Gunnar, Iro
I pushed a pin out two nights ago, on my one and only half-link. It was the last half-link at the LBS.
After the requite foul-mouthing, I took "ye old skateboard tool".
Why? Because the screwdriver blade side had a nice taper and fit between the two sides of the outer chain link.
I pinched the skate tool in the vice laying flat, used needle-nosed pliers to hold the link, and tapped it in with a tiny hammer.
Something like this:
[not the actual link in question, this is just a hired stand-in link]
macnab is offline
Old 03-29-11, 08:38 AM
  #78
tristen
i've witnessed my brother do it without a chain tool. i recall it involved a hammer and nail-punch and shocking amounts of foul language.
WHACK &*^%@$# WHACK &**&@#&*^ WHACK *(!Q@#$&* (ad nauseum.)
Last edited by tristen; 03-29-11 at 08:45 AM. Reason: i regurgitated what everyone has already said.
tristen is offline
Old 03-29-11, 09:14 AM
  #79
scroca
commuter and barbarian
scroca's Avatar
Liked 3 Times in 3 Posts
Especially when the punch slips and slices open a finger. Mine is still sore from the adventure last Sunday.
And to the earlier poster who thinks chain tools prevent the pin from pushing all the way out -- not all of them (if any).
scroca is offline
Old 03-29-11, 05:59 PM
  #80
meangreen
meangreen's Avatar
Bikes: Schwin Twin, Rayleigh sports (1968), Bianchi (dont know year or type), Green fixed - built to my own desires, Cannondale CAAD9, Schwinn ss build, Fugi something-or-other.
I found that it was a little less infuriating if I pushed the pin in from an old chain or from the extra piece of chain left over. The other method I found is to out the pin into the center section (where you should just be able to slide it through) then take the junction that has the two little dohickies that will go on the outside (try to stay with me and my technical language) and only worry about ONE of the little dohickies! Use the chain tool to push the pin from the inner section through one of the outer sections (like almost all the way through). Then move the inner section to its correct position, sandwiched between the two dohickies, and put the side of the chain up that has the peg sticking out. Now you should be able to use the chain tool to push the pin back through all sections of the connector as long as you go slowly and softly. If you try to angrily jam it through the other sections you will likely miss and have to start all over. Let me know if you want me to make a diagram.
meangreen is offline
Old 03-31-11, 05:42 AM
  #81
martinus
martinus's Avatar
Liked 6 Times in 6 Posts
Originally Posted by cc700
because you are the weakest link, goodbye.
and because it's a wear item and would have to be replaced eventually anyway so why worry when you can replace it cheaply?
Is it possible, someone has NOT heard :
" A chain, is only as strong as its weakest link. " ?
...or it somehow, does not apply to bike chains ???
martinus is offline
Old 03-31-11, 05:48 AM
  #82
martinus
martinus's Avatar
Originally Posted by wjphillips
No, No, No. Do not re-use chain pins! If you remove the chain pin with a chain tool you must buy a replacement pin. If you reuse the pin, you will compromise the integrity of the pin/chain and it will likely snap. I hope you you won't be out of the saddle pedaling when it breaks.
How do I know this? I did it and it happened to me. Luckily I wasn't pedaling too hard but nonetheless, I messed up my knees and elbows pretty bad.
Are you talking about multi-speed shimano pins ... 8, 9, 10 ?
martinus is offline
Old 03-31-11, 05:53 AM
  #83
martinus
martinus's Avatar
Originally Posted by TejanoTrackie
This whole discussion makes no sense to me. If you buy a new chain, it will have extra links that you can remove and save for a rainy day. If there is a problem such as described above, you can simply discard the faulty link set (one inner + one outer), and replace it with another set that is in good condition.
Now, that IS the correct answer .
( nice to see, someone weigh all the factors, time, wear, etc ... even budget... to come up with the *easy* solution. )
martinus is offline
Old 03-31-11, 06:06 AM
  #84
martinus
martinus's Avatar
I *think* he wants to "cheat" the system ... he did something dumb, now he wants to fix it, quickly and cheaply. ( Can't blame him tooo much, we all been there... )
martinus is offline
Old 12-06-11, 10:08 AM
  #85
mysorecyclist
Phew!!! I finally got the pin inside. The toughest part was to hold the pin in place! This is what I did. I dipped the tip of the pin in puncture glue and placed it on the hole, left it for few seconds. Then placed the chain in the chain tool, rotate and there it was
What a relief
mysorecyclist is offline
Old 12-06-11, 01:04 PM
  #86
solipsist716
Magnets, how do they work
solipsist716's Avatar
Hey, guy, stop putting those dots at the end of your posts. It's really ****ing annoying.
Carry on y'all.
solipsist716 is offline
Old 12-06-11, 02:58 PM
  #87
motobeCarnage
rue the whirl
motobeCarnage's Avatar
Use grease to hold the pin in line with the hole then carefully use the chain tool and make sure the pin stays in line.
Originally Posted by Mumonkan
i prefer anal beads
motobeCarnage is offline
Old 08-31-23, 07:09 AM
  #88
BikerTrainerRon
Originally Posted by rustang
seriously...there has to be some sort of magical secret. anyone?
kmc chain.
Take superglue, put a little droplet on table or countertop or something that you don't mind they're being super glue on, and roll one edge of the PIN in the super glue droplet. Then, place with the super glue on it right on the Chain hole where it needs to be inserted and hold it there for 30 seconds or so to let it dry in place. Then, when dry, you want to place the chain with the PIN that's super glued back into the tool that you used to remove the PIN and tighten the tool to close the pin back in.
BikerTrainerRon is offline
Likes For BikerTrainerRon:
Old 09-02-23, 07:34 AM
  #89
Speedway2
Speedway2's Avatar
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 406 Times in 246 Posts
I hope rustang fixed his problem.....
Speedway2 is offline
