Rim swap, spoke question...
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
I'm switching rims, but re-using the hub and spokes.
Currently, where the spokes cross, there is some slight wear.
When re-lacing the wheel, should I reverse the way the spokes cross, so they don't continue to wear?
Quoted: 3814 Post(s)
Liked 3,345 Times
moot
reuse of spokes increases likelihood of spoke breakages
some enthusiasts do it all the time
some enthusiasts would na'er do it
moot
Likes For juvela:
Addressing only the reuse of old spokes I find it best to keep them in the same position as before. Not having seen your spokes I’d be hesitant to reuse them if it looks like material is missing from corrosion where they intersect.
Likes For Nwvlvtnr:
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
Leave the crossings alone.
If the spokes are the cheap kind (plated steel) you're not likely to extend their lifespans by any appreciable degree.
If the spokes are stainless, it won't make that much of a difference anyway.
Likes For kunsunoke:
Quoted: 1106 Post(s)
Liked 1,328 Times
Spokes which are interlaced at their crossings deviate from a straight
line.
The forces resulting from this situation can be calculated.
Assume the following:
a) spoke diameter of 2mm;
b) flange thickness of 3mm;
c) spoke length of 300mm;
d) crossing at 200mm from the rim;
e) spoke tension of 100kgf
f) Young's modulus of 200*10e9 N/m^2
The centre-line of an uncrossed spoke lies at an angle to the line
between the flange centre and the spoke hole at the rim, such angle
having a height at the flange of half the flange thickness plus half the
spoke thickness; given the figures above this is 2.5mm and the angle is
0.48 degrees.
The centre-line of a crossed spoke deviates from the straight line
between the flange centre and the spoke hole (in the rim) at the crossing
point by the spoke thickness plus an amount proportional to half the
thickness of the flange (in this case 2/3rds as the crossing point is at
2/3rds of the spoke length); given the figures above we have a deviation
of 3mm total and an angle of 1.72 degrees at the flange. There is a
second angle calculable from the crossing point between the centre-line
of the spoke to the spoke hole in the rim and the line joining the flange
centre and the spoke hole; given the figures above it is 0.29 degrees.
So we have a triangle; taking the centre-line of an uncrossed spoke as a
reference the angle A (at the flange end) of a crossed spoke is
(1.72-0.48 = 1.24) degrees and angle B at the rim end is (0.48+0.29 =
0.77) degrees.
The orthogonal force at the crossing point can now be calculated as (t
sin A + t sin B); given the figures above it is roughly 3.5kgf.
The difference in length between the centre-line of an uncrossed and a
crossed spoke, given the figures above, is 100 * 1/cos(1.24) plus 200 * 1/
cos(0.77) giving a new length of 300.04 mm.
The proportion of the tension in the crossed spokes due to their crossing
is calculable: t=(a*e*dl)/l, which given the figures above is about 8.5
kgf.
The point loading at the crossing for perfectly round and incompressible
spokes is infinite, but the actual degree of osculation at the pressure
found above can be estimated. The yield strength of stainless steels can
vary tremendously depending on the alloy and manufacturing; cycle spokes
are typically 314 or similar steel and are cold-worked; a not-
unreasonable estimate for yield strength is 300 MPa, which is about 3000
kgf per cm^2. The load of 3.5kgf found above can therefore be supported
by an area of 1/10 mm^2, which if circular would show on the spoke as a
bright spot 0.05mm in diameter.
The crossing point of the spokes may move as the spokes are unloaded at
the bottom of the wheel. This effect is greatest for lacing patterns of
high cross values, as the spokes join to the rim at points far enough
apart that one spoke is unloaded preferentially. Taking the extreme case
where one spoke is unloaded such that is assumes the line taken by an
uncrossed spoke and given the figures above, the bright spot will move
towards the flange by .0234 mm; this means that should such excursions be
common the bright spot would approximate an ellipse of minor diameter
0.05mm and major diameter 0.0734mm.
line.
0.48 degrees.
0.77) degrees.
kgf.
Quoted: 1830 Post(s)
Liked 3,383 Times
re: reversing the spokes... is that even possible? The only way I can think of to change where the spokes rub would be to change the number of crossings, such as going from 3x to 2x. However, that would require shorter spokes.
As far as reducing wear... one option would be tying and soldering the spokes. Sounds like a good excuse to try something different!
Steve in Peoria
Industry guy
Rims have a specific ERD(effective rim diameter).
If the original rim and the new rim have significantly different ERD measurement, the spokes
might not/will not work. They could be either to long or to short when laced with the same cross
pattern.
IE- a lower end, flat rim vs a box section rim with eyelets or even more noticeable would be
anything compared to a Weinmann Concave!
rusty
pattern.
rusty
Likes For 100bikes:
Quoted: 209 Post(s)
Liked 175 Times
Spokes are stainless, and I'm going from an Open Pro ceramic to an Open Pro alloy.
What I originally thought was wear turns out to be slight rust rather than grooves.
When I considered switching the crossing spots, I meant reversing the crossing closest to the rim, so that any wear spots would now NOT be rubbing on each other.
After reading the comments, I see now that it probably will not matter.
Thanks for the help!
(oneclick, great information...trouble is, you lost me after "calculated"!)
Quoted: 1609 Post(s)
Liked 2,216 Times
@67tony - Rust on stainless spokes? Must be dirt. Pics or it isn't true.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
Liked 1,328 Times
And of course "stainless" covers a wide variety of alloys, which vary in their corrosion resistance. Spokes commonly use an alloy with a high percentage of chromium and nickel - iron may be as little as 50%; and so are quite resistant to corrosion, but it does not conquer, it just resists:
Likes For oneclick:
Quoted: 964 Post(s)
Liked 1,451 Times
I reuse the spokes in the same positions. I have a different reason though. My reason is that it takes much longer to relace the whole wheel than it is to just tape the two rims side by side and switch the spokes over one by one. Your time is worth something! I've never had a problem doing this.
Likes For scarlson:
Death fork? Naaaah!!
Top
Likes For top506:
Quoted: 209 Post(s)
Liked 175 Times
With that said, though, I still feel that some of the crossings have a tiny groove worn in, as evidenced by a slight clicking sound.
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
Line up the valve holes and have hole offsets equal on both old and new rims, tape together in 3 spots, then transfer spokes one at a time as many have said. Any spoke that spooks you, just replace that one.
Likes For gkamieneski:
Quoted: 209 Post(s)
Liked 175 Times
Any clever ideas on how to best accomplish that task?
Quoted: 167 Post(s)
Liked 92 Times
Yes. That is what I am suggesting you do by my instructions. Old hub, old spokes, new rim. Used to have to do this frequently in the days of Mavic MA40, MA3 rims etc. These rims would often “splinter” at a spoke hole and when you caught it and realized it, you would do a “rim lace over”. Fortunately those Mavic rims never cost very much. Used to do so with Mavic tubular rims as well, such as GEL330s and Reflexes but not as often was it needed.
Quoted: 1821 Post(s)
Liked 1,697 Times
Tape the 2 rims together with the spoke holes lined up with each other. Then, one by one unscrew the spoke nipples and move them from the old rim to the new one. This will be easier to do if you loosen all the nipples a couple to turns before you start the transfer process. Once all the spokes have been transferred you can start to true the wheel and tension the spokes
Likes For alcjphil:
Liked 1,328 Times
Likes For oneclick:
Quoted: 2364 Post(s)
Liked 1,751 Times
And make sure you select a rim that's "handed" in the same direction as the existing one.
Likes For madpogue:
Likes For 67tony:
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
When I strip a rim to clean the hub and/or rim keeping the spoke in the right order is difficult so I have made these mk1 spoke position holders! A chef I know was having a deep fat fryer replaced and these were the fat traps (this is why it has so many holes) that go inside the business part. I fixed them to the wood to test it. I will route out a trough so they do not need to hang over an edge, and probably make it hold oil so the spokes are lubricated when building a wheel. You could, if you want put the spokes in the holes in the order they come out, I think head in/out L/R F/R is enough personally.
So much easier than elastic bands, it works well for me.
Used spoke holder
Used spoke holder
Likes For awac:
Quoted: 964 Post(s)
Liked 1,451 Times
Whoa! And I thought I was fancy for using tape or rubber bands!
Likes For scarlson:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Most of this is new to me.
Whenever I have to mess about with swapping parts of used wheels, I always start by drinking heavily, so that I won't notice how much time that I'll be wasting and so can feel much better about the job completed.
Likes For dddd:
