Official Giant Roam Owners Thread
#151
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
I use these. My only comment, besides that I like them a lot, is their shape tends to "square" your wrist up to the handlebar. Thus these aren't quite as comfortable on wide and straight bars because your wrists will feel almost like they're being turned in toward the center (though they're really not). I'd like to try a bar with some back sweep with these grips.
I'm beginning to have some second thoughts on my Roam in general, though. My daughter and I have gotten into mountain biking. No weird stuff like you see on YouTube, but just going more off the road on rutty and moderately rocky single track. I'm trying to be careful to not pound the poor 63mm fork into the ground (it's an NEX hybrid fork). I'm starting to think that something like a Giant Talon or Raleigh Tokul (or similar) would be better for my use. I have a very comfortable Trek 750 for hybrid duty.
Do I keep using the Roam until parts break, and just upgrade as I go? Or sell it while it's still pristine and buy something better optimized for trails? Hmm...
#152
Bikes: 2013 Trek 4.7 Flatbar Madone, 2018 Giant Roam 2
Quoted: 103 Post(s)
#153
Quoted: 1581 Post(s)
Liked 1,189 Times
On the other hand, if you want to get into mtb proper, then yes ... if you don't need the Roam for pavement/hardpack riding, get a full-on mtb.
BTW
#154
Liked 762 Times
It all depends! If you like the genuinely 'cross-terrain' nature of the Roam, and want to be able to crossover between pavement/hardpack on the one hand, and up to moderately technical singletrack on the other, then why not simply change the fork to https://www.sram.com/rockshox/products/paragon-gold-rl if and when the NEX packs it in, or even before!
BTW
https://www.youtube.com/watch?v=itj3E1z29CU
BTW
I've also considered swapping to 27.5" wheels to lower the bike a bit.
But then I would question spending hundreds of dollars trying to make a bike fit a need for which it wasn't really designed. I love the color and style, though. I go back and forth.
#155
Liked 1,189 Times
I think my biggest mistake, in terms of using the Roam off the road is buying a large frame when I was right in the middle of large and medium. I can barely stand over the large frame, which is generally fine for roads and paths. A little more standover clearance is usually recommended for trail riding, which may have off-camber situations or other oddities. A smaller frame would probably set me up better for installing a longer fork in the future, if the NEX fork fails (like a 100mm mountain bike fork for example). A longer fork should set the bike up taller, and I can't really go any taller with it.
Re. forks: fwiw I wouldn't consider putting a 100mm fork on a Roam. The frame is simply not designed for it; much better to switch out to a dedicated hardtail mtb. That said, that's why I pointed to the Paragon: that fork, while still only having 60 and a bit mm travel, is based on a previous generation of RockShox full-on mtb forks. So provided one isn't planning a lot of six-foot-drops-to-flat kind of stuff, it would work very well indeed off-road.
#156
Liked 762 Times
This is a good example of how frame charts don't really tell the whole story. On paper, my large Roam has the shortest stand-over (30.7") of any of my "main" bikes, the others being a 20" Trek Verve (31.1" stand over) and a 21" Trek 750 (30.9" stand over). In practice, I seem to have the most stand over clearance on my 750, despite it being the "tallest" bike on paper. My Verve feels a little "closer", but the Roam feels the tallest. Of course, swapping the 38mm tires for 50mm tires only adds to the height (6mm nominal increase). I agree with you...Giants do seem to "feel big" for their size.
My local Giant dealer has my identical bike in stock, but in a medium size (Roam 2, Satin Grey color). Half of me wants to go check it out, but I haven't yet. The other half of me wants to sell the Roam and buy something like a Raleigh Tokul 2 (unbeatable value in a MTB). The third half of me (I said I was torn!) wants to keep my Roam and consider 27.5" wheels and tires. I feel that it's too tall as it is...I just have to decide the best approach from here.
There are worse choices to have to make in life, right?
#157
Liked 1,189 Times
#158
Liked 762 Times
I was at the Giant dealer tonight, and they had a Talon 2 in medium that I sat on -- it felt good. I'd certainly have to ride it to be sure. Stand over was still "snug". I wouldn't say that it's significantly different than my large Roam. When I got home, I rode my '15 Verve 3, and I would also call its stand over "snug". Maybe I'm feeling that the Giant is taller than it really is -- when I compare it directly with other bikes, even my own Verve, it's not a ton different.
I came away with potentially a different plan, though. I really don't ride my Verve 3 much any more. I really should sell *that* bike, and replace it with a dedicated mountain bike. Then I'd have the Roam for most riding, and a mountain bike for actual single track. The Verve is such a pretty bike (a beautiful combo of medium blue with pearl black) that it would be hard for me to part with it, but I like *having* that particular Verve (in that colorway) more than I like *riding* it
The bike shop owner wasn't too hot on the idea of replacing the Roam's wheels with 27.5". He said the geometry might end up being different and it'd lower the bottom bracket. All true.
#159
Quoted: 103 Post(s)
Did an evening ride last night with the Roam. I noticed that I've been doing only leisurely rides with the Roam, so for last night's ride I decided to ride a bit more aggressively. Locked the front fork and tried to keep my speeds above 10 mph the whole ride. Did a little over 5 miles in less than 30 minutes which was an improvement for me.
My takeaways:
My takeaways:
- You can actually push the Roam on pavement and it is a fun ride because it is so comfy.
- The WTB Speed saddle I have on the Roam seems to be a good improvement over the stock saddle. It also seems to feel better if I'm pushing it and trying to bend down to get a little more aero on the bike. Like the saddle is encouraging me to bend forward more.
- I would like narrower handlebars and bar ends.
#160
Liked 762 Times
I'm a lot faster on the Roam than I thought I'd be. Something with the geometry on it -- it just feels efficient to pedal. I've been running with the fork locked more than I used to. Maybe I'll eventually change out the fork to a rigid carbon fork, especially if I buy a dedicated MTB for single track.
#161
Quoted: 103 Post(s)
So I spent some time looking for a US based online retailer that sells the Spirgrips bar ends and I cannot seem to find one. There's a European store, Rosebikes, that sells them, but having it shipped here I think makes it pretty expensive, for just bar ends. Even on ebay, the cheapest I could find was like $50 for the bar ends, but shipping was like $22-$23. At that point it is more expensive than buying separate grips and SQ Lab inner bar ends. It even cost as much as the Bontrager Isozone handlebars, that already includes the isozone grips.
On a positive note, I found that some online stores do sell the Giant Connect MAX Ergo grips with bar ends. These are the grips with integrated bar ends that come on the Giant Fastroad bikes.
#162
Bikes: Giant Roam 2
Quoted: 11 Post(s)
#165
Quoted: 103 Post(s)
Do you know if the angle of the bar ends are adjustable, independent of the angle of the grips? Kinda like how the Ergon grips are?
#166
Bikes: Giant Roam 2
Quoted: 11 Post(s)
Within reason? I've never owned the Ergon grips. Obviously you can rotate the grips 360 degrees, but not the bar ends.
#167
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
Rose Bikes usually have pretty good prices on all their stuff and their postage costs will be the same or only marginally more if you were to add some other items you want/need, like brake pads, tubes, tyres, various accessories etc.
I pretty much buy everything bike related from German online retailers, I just have to wait till I have multiple things to order, to reduce the postage hit.
#168
Quoted: 103 Post(s)
Why do you like buying from German online retailers?
#169
Liked 312 Times
Whilst there are many examples I could give, probably the best example is the Racktime range of racks and baskets, which I believe are a clear level above Topeak.
Also the Schwalbe tyres are also so much cheaper than elsewhere.
They are so much better than ChainReaction, it is no longer funny.
#170
Quoted: 103 Post(s)
I was very close to going that route myself and I may still do so in the future, but I decided to get a set of Surly Moloko bars(not yet in use).
For me in Australia, I just don't have the local choices or Amazon options someone in the USA has, so the German retailers have an incredible range of items and pretty much the best price on just about everything I am after.
#171
2016 Giant roam 2 disc
My first big boy bike. My roommate got it and decided he didn’t want it so sold it to me for cheap. I’ve been riding it to work in the morning.. I work on snowmass co mountain so I bike up and down the back side of the hill. Decent climb. The bike is growing on me. I put a more aggressive angled stem and wider handle bars on it as well as some 70x 50mm tires. I went with more of a mountain bike go anywhere direction and love it. Handles downhill and turns insanely better with those tires. Handles help with stance not feeling like a tourist. Fun bike. Looking forward to upgrading even more maybe to a xc type fork and brakes and drive train.
#172
Hi guys, new here, good Giant Roam chat. I just bought a Roam 2 Disc 2018 a few months back, love it. Just interested to here what sort of upgrades or mods anyone has done with theirs?
I'm considering a few things. 1) Getting clipless pedals for it, look forward to that, just ordered from wiggle.
2) Has anyone considered lowering the handlebars? I've only just noticed the Roam has a few spacers under the handle bars to be lowered. I also have a road bike where I've taken some spacers out to give it a more aero dynamic position, however I've never really thought about this for the more mountain bike influenced Roam. Has anyone considered or done this? Will it be sacrificing the comfort unnecessarily?
3) Tyres are probably the only other thing I'd consider upgrading. It seeems pretty good as is to be honest, and I'm still relatively new to cycling so not sure if this is needed. How are the stock Roam tyres rated? I mean they seem fine so far though.
Also upgraded to 70x50mm tires makes it way way sturdier on bumby fast turny terrain. It was okay before. I took it downhilling on some greens with stock tires but popped a tube on the forth lap. Surprised it lasted that long honestly. Now it’s ceiling is much higher.
#174
they are the Kenda kwick journeys. Not the biggest tread in fact the tread is integrated into the tires which may help the tire fit in the rear it’s pretty narrow back there.
Makes we wonder if I could eventually get 29in wheels with real treaded tires even if they’re only 2 in wide.
#175
Liked 762 Times
Cool -- I'd love to see some pictures of them!
I ask because I have Schwalbe Hurricanes on mine, also in 50-622 size (also marked 29x2"). The casings themselves on the Schwalbes are about 48mm and small knobs are about 51-52mm edge to edge. And there's still room.
IMG_20180530_170340334 by jnjadcock, on Flickr
Those Kenda Kwick Journeys look nice. I have the Kwick Tendrils on one of my bikes and I like them. Somewhat heavy for their size (due to the puncture protection), but they are very smooth.
