Official Giant Roam Owners Thread
#176
My nephew just bought a used (but like new) Roam 3 Disc 2018 off craisglist for me. He paid $250, which is about half of what it retails for. I'll be using it mostly for grocery runs with a Schwinn Cargo trailer attached to it. Right now I'm using a Malboro Fuji Folding horror from the mid 90s that must weigh a ton, has a severely faulty left shifter and brakes that would take the length of a football field to stop if I was coming a'down the mountain. I'm assuming the Roam 3 Disc will be quite an upgrade from that. Ironically, that same nephew won the Fuji Folding bike when he was a mid-teen with Malboro cigarette coupons and within a day of acquiring it he bent the back axle because he started doing crazy stunts on it. He's in his 40s now. I wonder if I'll like my new Roam 3 bike. Haven't even seen it yet.
#177
Not much traffic in this topic but I got my new Giant Roam 3 2018 off Craigslist yesterday. It needs work but thanks to this forum I have already fixed an issue with the front wheel not being able to free spin due to the disc brake caliper being out of whack.
#180
It's overcast today but I'll try to get a pic for tomorrow. I still need to do some work on that front derailleur which is not as smooth as it should be. Hopefully it can be tuned properly regardless of the entry level components for its price range ($500). Waiting for my repair stand and some quality hex wrenches I ordered to be delivered.
#181
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times
Here's my 2018 Roam 2, with newest addition: Topeak MTX DXP trunk bag (thanks to Santa). I was out for a new year's morning ride, and stopped by a small pond for a couple of pictures. I'm glad that I moved the fenders over from my Trek Verve (which I don't really ride anymore): I've benefited from them on a number of rides now (wet surfaces with puddles). These are the 40mm Schwalbe Little Big Ben tires, which are a nice balance between tough durability and good ride quality (they're a reasonable weight -- 590g). They have Schwalbe's "RaceGuard" level of tread protection (4 out of a best of 6 on their scale), which includes two layers of fabric under tread.
The Topeak MTX DXP trunk bag is reviewed pretty thoroughly on the internet. It's a durable bag with zip-out panniers on each side (denoted by the "P" in the nomenclature). The DXP has a zip-expandable main section also, for larger capacity (vs. the EXP, which does not have an expandable main section). I like that I can slide this out and I've already got a Topeak Explorer Disc rack on order for my MTB, so I can run the bag on either one.
IMG_20190101_100211784 by jnjadcock, on Flickr
IMG_20190101_100200331 by jnjadcock, on Flickr
I have about 300 miles on my Roam now...have owned it since last summer.
#182
Mostly Harmless
That's a nice looking bike. I think you will enjoy it.
I've put 7,900 miles on my 2017 Roam 1. I even rode a full century ride on it, in addition to many metric centuries.
I've since bought a road bike that was twice as expensive as the Roam. I like the lightness of the road bike,
but even after 3,900 miles on the road bike, I still find the Roam to be faster and much more confidence
inspiring on fast (paved) downhills. Both for straight roads and curvy ones. And the Roam rides like a
Cadillac compared to the road bike.
I'm looking forward to snow, when I'll leave the road bike at home and the Roam will earn its keep.
#183
Liked 759 Times
I have many times looked at and considered replacing the suspension fork with something else (like a carbon or chrome-moly steel rigid fork). But then I ride it, and remember why I really like this genre of bicycle. I have a good number of bikes, many with rigid forks, but the Roam gets the most of my limited bike-riding time. It's just a really comfortable bike.
#184
Quoted: 5 Post(s)
Hi. I’m considering on buying the 2019 Giant Roam 1 disc but I’m on the fence when it comes to size. I’m 170cm with a 68-69 inseam. My height overlaps between Small and Medium but I think my inseam is ideal for a Small frame (based on my calculation) and I were to based on the stand over height specs of this bike. Likewise my torso and arm length is 120 combined which I’m not sure will fall on which size or length of top tube?
I hope im making the right choice in getting this bike over Trek DS or FX3. I’m after for a good Groupset at least Deore to start with hence the reason of going for this model. My main purpose is commuting to work and occasional weekend rides with my kids in the neighborhood. I do have a dedicated road bike SWorks Tarmac but I think it’s not ideal for commuting since it has 25 tyres on it and the type of road here in New Zealand isn’t full tarmac.
Lastly, what type of specifications of fenders and pannier should I buy for this model? Any recommendations?
CHeers
CHeers
#185
Liked 759 Times
Welcome, mavericg. As far as size, if you feel more comfortable on a small regarding stand-over, then I'd probably buy the small. If you feel a little too upright on it, you can always adjust the saddle rearward and/or install a longer stem, which would move the handlebar forward. But you can't make a frame that's too tall for you (stand-over) shorter, unless you install shorter wheels and tires, which bring other compromises.
As far as fenders, any set of fenders designed for 700c/29" wheels should work. It's generally recommended to use fenders that are 10mm wider than your tires, for good coverage. I, however, have 45mm wide fenders with 40mm wide tires on my Roam, and I find that works good. I wouldn't want to go much tighter than that (5mm difference), but I think 45mm fenders work well. If you stick with the stock 38mm tires, 45mm fenders should be good. The fork does not have lower eyelets for mounting fenders, but have rear-facing mounting points a few inches up from the bottom that work for mounting fenders. You may need a small L-bracket to mount them, depending on how your fenders mount to the fork. You can see that on my Roam a few posts up. I can take more detailed pictures of the front mount if you like. I have Planet Bike Cascadia fenders on mine. They have great coverage with long rubber flaps that hang down. I stay completely dry on wet roads with these. I also have a Planet Bike Blinky 3 rear light and I've come to like Planet Bike stuff -- they seem to be well-made products at reasonable cost.
As far as panniers, rear ones would probably work best (there are no mid-fork rack mounts on the suspension fork). You could fabricate a mount using P-straps or similar, but a rear rack fits great. I have a Topeak Explorer rack on mine, which fits the Topeak MTX QuickTrack bags. You can get Topeak rack bags with fold-out panniers, or you could also certainly hang standard panniers from the rack as well. I like the flexibility of the Topeak system because I have a few bikes that I regularly ride and, with a Topeak rack on each one, I can just click the rack bag into whichever bike I'm riding that day.
#186
Quoted: 5 Post(s)
CHeers
CHeers
Thanks for the advice on panniers and mudguards. I might explore the topeak versions and will look for a compatible mudguards.
#187
Liked 759 Times
Failing that...if you think you'll always question if medium is too large (if you're torn now), then order in the small and have the shop install a longer stem or even a set-back seat post if necessary. I think it's easier to "make a bike larger" than it is to "make a bike smaller".
#188
Quoted: 5 Post(s)
Okay after so many test ride of different brands such as Trek, Scott, Avanti, I’ve finally ordered the 2019 Giant Roam 1. I actually liked the built of Giant ToughRoad, In fact I was torn between Roam and ToughRoad at the last minute and it all comes down to price point and preference. I think the ToughRoad Is leaning more to the mtb side while the Roam is a good example of a hybrid bike. 50 on the road and 50 light off-road.
Now the the next step is accessories..! Any links or a good reference to model with as I’ll be using this bike for commuting about 50-60kms a day 2-way from home to work.
#189
Liked 759 Times
The ToughRoad frustrates me because it's a great bike, but Giant doesn't offer a more moderately-priced one. They used to have the ARX, which was sort of like a budget ToughRoad with 27.5" wheels. It had entry level components and was priced at 500 bucks. Then there's the ToughRoad...a very nice bike with carbon fork and nice frame, for about 1000 bucks. But there's nothing in between. I'd like Giant to offer something like a cross between the ToughRoad and the Roam -- use a frame similar to the frame on the Roam 2 (priced at $610), add a carbon fork with the correct geometry, and come out around $700-750. They can do it...they have the Escape 1 with a carbon fork, hyd disc brakes, and $790 price tag. I'd like like to see a ToughRoad SLR 3 or something, or a non-SLR ToughRoad (SLR seems to be a better frame quality).
Anyway, I digress. You'll enjoy the Roam 1. It's a super comfortable bike.
#190
Quoted: 5 Post(s)
#191
Liked 759 Times
You should be able to get Topeak Defender TX fenders to work well. In fact, Topeak's website shows a Scott bike with a Suntour suspension fork with these fenders mounted.
https://www.topeak.com/us/en/product...8-defender--tx
They'll work on the Roam exactly the same as you see on the website. There are three rear mounting points for racks/fenders on each side, so you have plenty of options in the rear. I have fenders with the Topeak MTX rack on mine and they work well together.
#192
Quoted: 5 Post(s)
There are so many Topeak Rear version, did you buy the Super Tourist DX version for disc? Also for the trunk bag, is it the MTX bag with side panniers? Cheers
#193
Liked 759 Times
The rack is just a basic Explorer non-disc without spring. This one. You don't need the disc version for our bikes because of where the rear brake calipers are. The ones with the "QuickTrack" channel are compatible with their bags that slide and click into place.
The bag is an MTX Trunkbag DXP. This one. The DXP (with a P) means it has the fold-out panniers. You can leave them folded into the side panels if you wish. But they have tons of bags (click here). If you want the type that slide into the rack and click into place, just look for any bag with the "MTX" or "MTX QuickTrack" designator.
#194
Quoted: 5 Post(s)
Just collected my 2019 Giant Roam Disc 1. loved the smooth ride and geometry (as i've been riding road bike for years now). basically, this year will use this bike as a commuter / weekend rides in the neighborhood. ive chosen this bike over the Toughroad 1. It's not as heavy as I expected just a few lbs heavier than TR 1 but it's manageable. Will post some pictures soon
Upcoming add-ons will be:
- Topeak Defender TX Fenders
- Topeak Rear Rack
- Topeak Trunk Bag
- Shimano Gr500 pedals
- Wahoo Speed and Cadence sensors
- Bike lights
- Garmin 820 (this is my spare one)
- Giant Ergo Max Grips with Bar end (on order in ebay)
- Looking for a good commuter saddle (recommendations?)
- Topeak Rear Rack
- Topeak Trunk Bag
- Bike lights
#195
Liked 759 Times
Yes, I think we look forward to pictures. Saddles are so personal -- you really need to find what fits you. And I find that saddle fit even varies by the day for me. Sometimes I like a narrower/firmer saddle and sometimes I like a wider/softer saddle. All of my bikes either use a 27.2mm seatpost, or are shimmed to use a 27.2mm seatpost, so I have a few saddles that I like on seat posts and I swap them around as I desire. You'll notice that my pictures earlier in this thread show a large gel saddle on a suspension seat post on my Roam. I usually use a narrower Specialized saddle on a rigid seatpost, but I find that I like the softer saddles in the off season like now when I'm not riding as often or as far.
#197
Liked 759 Times
Hey, that looks great! Say, is that a chain stay protector I see on the drive side chain stay? Did that come that way from the factory?
#198
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
That's a nice color to the new Roam! BikeTiresDirect.com has been having good sales on saddles lately, although not at moment. Every couple of weeks they discount different items and they may have saddles on sale again in a week or two.
I bought this Selle SMP saddle on sale for $63 (originally $80) a few weeks ago:
Selle SMP TRK Medium
#199
Quoted: 5 Post(s)
yes, there's a chain stay protector at the drive side. Also the x-defender in the front is opened up like a wing similar to Toughroad which also act as a mudguard.
#200
Liked 759 Times
Many thanks.
