Post pictures of your Hybrid
#4776
My little wife's new bike....it's the extra small I believe it's a 13" Schwinn Sporterra NX8
After a nice ride on Sunday the seat had to go & I added the old Bontrager Crivitz bars off my Sawyer & the old seat off my Motobecane Jubilee.
I'll probably steal them tires for my Kona...get her something around 2".
#4777
S'Cruzer
#4778
Here's my Motebecane Jubilee with a few needed changes.
I probably ride this bike more since I have it at work for 28 days...some guy borrowed it to go to the store and stripped out the crappy twist nexus shifter. I upgraded to the Alfine 8 speed shifter and couldn't be more happier!
Also I replaced the grips with original ones that came with my Sawyer and the saddle came from my Schwinn Tempo. It is really comfortable and fun now!
I think I would like to eventually replace the fork with a rigid steel one.
#4780
Bikes: Cannondale Quick 4
Nice Jubilee. I've always been interested by the alfine integrated hub. I was even looking into the belt drive bikes with alfine for a low maintanence commuter bike. How is the gear range? Low enough for climbs? High enough to hit high speeds?
#4781
The Nexus & Alfine 8 spd I believe to be the same except the Alfine is set up for Disc Brakes. So far the 8 speed has been the most reliable and you can set it up for speed or hills depending on the rear cog & chainring you use. I'm running 42X18 =(2.4:1 ratio) on my Kona for a little more speed than my Motobecane at 42X20 =(2.1:1) My Sawyer being a 11 speed I have at 36X20 (1.8:1) set up more for hills but still has plenty of speed. I have 34t chainring I can change out if I travel to a real hilly area.
#4782
Since I had my old Sawyer 29er rear tire I put it on to see. Bontrager 29.3....says it 29x2" (44-50) measured by my calipers barely 44mm & almost 10mm still left between chainstay and tire.
Also those Continental Double Fighter 2s (37-622) only measured 34mm.
#4784
Bikes: Road/Race: 2012 Breezer Venturi; Trail: 2016 Scott Scale 720 Plus
Quoted: 12 Post(s)
-Ed
#4785
Bikes: 2009 Salsa Pistola | 2010 Stop Cycles Proletariat | 2010 Novara Buzz | 2002 Jamis Dakar Comp | 2007 Giant Revive | 1999 Kona Jake The Snake
Bikes: 2011 ICE Sprint Special Edition
Quoted: 35 Post(s)
Liked 101 Times
Well, it's a, Hybrid in the making so to speak. I've picked up a 1995 Research Dynamics Coyote 2 in great shape, it's a 90's low end MTB but I'll be changing bit's and pieces to turn it into my hybrid "utility/trailer tugger"! Not a bad start for the measly sum of, $45.00!
Take Care, Ride Safe, have FUN! :)
Jo: 2009 ICE Trice T
BJ: 2011 ICE Sprint Special Edition
#4789
My 2012 Sirrus on a local jaunt
#4793
Bikes: 2014 Surly Straggler (Loretta Martin)
Here is my completely custom Cannondale hybrid. The frame/forks were originally white, I stripped/repainted/decal. Completely custom built from the frame up.
full Sram Apex drivetrain with Sram 8speed trigger shifters. Velomax Circuit wheelset, Continental Grand Prix 4000s tires. Selle Italia saddle with a Bontrager carbon post.
20lbs even
20lbs even
#4800
New to the forum and just getting into cycling. On account of work I'm a bit of a road warrior so I traded some Hilton points for a bicycle and this is what I came up with:
For riding trails in the Philly metro area and seeing where it takes me. So far, so good. I have a few other accessories and a repair kit mounted on the bike now not pictured but it's doing the trick so far. Hopefully we'll see some of you on the trails.
