Suspension Fork Tubes ?
Hello.
So question. I am going to replace the fork tubes with longer, about 3 feet, maybe less.
Tubes are 1" with .065 wall. I would like to get stainless, would I get the same size wall. Seamless or Welded?
Yes, I know I need to weld at the bottom to replace. I am good with that.
Thanks.
Thanks.
Quoted: 714 Post(s)
Liked 800 Times
Online metals https://www.onlinemetals.com/en/buy/...eel-round-tube
Quoted: 4201 Post(s)
Liked 3,856 Times
While one could just duplicate the current wall thicknesses I would suggest the added leverage of the longer reach will want somewhat thicker walls. I suggest using seamless DOM 4130 cro moly. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I agree with Andy, and would add this: a butt weld between two tubes leaves the existing tube thickness at the joint. I'd go for thicker walls, and turning the ends of the tube on a lathe to insert the new, thicker tube some distance (a few inches) into the existing tube before welding.
Likes For WizardOfBoz:
The angle to the ground will not be extreme. Tubes are being replaced completely. Just welding at the bottom to facilitate the suspension part install.
So my dad has some 1” pipe. I am going for a sort of cafe race. Maybe shorter.
The pipe he had is too thin, so probably make handle bars if I cannot find what I want.
