Created Some Problems
So my 40lb. beast, the Schwinn city runner, was making some noise at the cog. I decided to tackle it today. I figured I could handle tacking the wheel off and tear it down to a point I could clean it, maybe tighten it as it had some play. It was sort of grinding when I was in a coast. It got worse over the past couple or 3 days so something had to be done.
Ended up taking the skure, the axle out and the bearings just started dropping out. lol. So, I ended up taking all the bearings out and God only knows how anyone could get them back in place.
And now I'm at a point where I need the special tool to get the cog apart. I'm screwed. Now I'm not even sure which way the axle feeds through the hub and a washer feel out too. I might be able to piece it back together but I think I'm over my head.
The bearings... omg... laughing. My bike... omg.... crying. ....Ha.!! Can anyone tell me where I'm at and where I went wrong.??
Quoted: 4204 Post(s)
Liked 3,861 Times
Let's see, you tried to do something you had little idea how to do or the possible complications and rapidly fell behind of the situation.
Some here will try to talk you through the possible repairs and you might struggle through them. Of course some tools and parts will be needed and if you can't assess the condition of certain parts your results will be sub par. So I suggest you will be better off by letting a LBS help you out. I suspect a replacement wheel will be the likely estimate. Broken axles (for how long? we don't really know) can be replaced but other potential wheel conditions (rim, spokes, hub bearing cups) often make a complete wheel replacement the best long term investment. Andy
AndrewRStewart
AndrewRStewart
Liked 3,861 Times
Or as I like to say- "I see" Said the blind man to the deaf woman. Andy (hoping I haven't just done a PC no no)
AndrewRStewart
AndrewRStewart
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Did you actually unthread a locknut and cone? I'm guessing 'no' and that your axle is broken. If so, collect the loose parts and take them with the wheel to a bike shop and ask them to install a new axle and bearings.
I think I'll bring the parts to the LBS, see what they say. Worst case I can get close to the same bike at Walmart for $200.
I use the bike for local errands and appointments in combination with public transportation. It's a city runner.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
You can get a replacement wheel on Amazon for < $50-. If you tell us the size of the wheel and tire and share some pictures, we will be able to be more specific.
Certainly a learning project for me, which is great. You'd think a bicycle is basic mechanics but inside that wheel, the hub, there's a lot going on. I'll pay closer attention next time.
I took on a schwinn coaster hub before. Then took it to the lbs. it still had drag. I s wapped the hub with a cheap $10 China one and then the steel hoop was not circular anymore lol I ended up buying a $10 bc just for the wheels
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Just a followup...Trollheim is the place that is meant to be refreshing and to get refreshed.
Jm2c's, Ben
Voltaire
Voltaire
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
When you say a wheel replacement, would that wheel come with the cassette and axle in a way I could simply put it on my bike and ride.?? Rider ready, so to speak.??
Liked 3,861 Times
For the best plug and play have the shop do all. For the least cost (at the risk of the least result) do it yourself. Andy
AndrewRStewart
AndrewRStewart
