A newer Peugeot?
A newer Peugeot?
well, newer for me. I've restored a lot of Peugeots, maybe a dozen, and a couple of Motobecanes. Most of them were from the 70's, and two from the 80's.
I bought a mostly stripped frame recently that I cannot date.
It has the "Record du Monde" decal. Is this essentially the same model as the old U-08?
It has some updates like the rear dropouts and RD hanger. Also, an interesting seatpost and set screw (back of seat tube). The post has a groove down the back for the screw. I've never seen that! Braze-ons for one water bottle on the downtube, and possibly one for the FD, although it came with a Simplex clamp-on FD. Suntour RD, but that may not be original. It has a nice Stronglight crank (mis-matched left arm, unfortunately) and a Stronglight headset. It did not come with brakes or even the hangers for centerpulls, so it must have had sidepulls. It takes 700c wheels.
Any idea the year? I'm especially interested in what tubing (no decal).
I can't find serial numbers anywhere. Strange. There is a plastic cable guide under the BB, so maybe under that?
Quoted: 5888 Post(s)
Liked 3,471 Times
I like this style of simplex deraileur as it works with a suntour or campy derailleur (as well as a simplex derailleur). This could be a PBN 10 which is made of hi tensile steel and was a "racing" bike model. It could be a PKN 10 as well which has a 531 main triangle but I don't see any stickers so I'm guessing a PBN 10 but the chrome fork suggests a little nicer model.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,481 Times
Is the bb cable guide riveted? You can usually make out some of the serial around the plastic guide.
Paint looks so nice, I'd assume repaint or powder. Looks thick on the rear drops. And the fork looks like a replacement.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
1983-84 Mid Range Peugeot Frame
It's about a 1984 mid range Peugeot with creatively misapplied early 70's decals and heavy powder coat paint.
Peugeot only used that stupide set screw design for clamping the seatpost in the rear of the seat tube for a year or two! Problem is that the set screw mungs the seatpost so that it becomes difficult to adjust the height!
Then they came out with a plus stipide ATAX seat post with an internal expander to clamp the seatpost in the seat tube much like a stem! The expander plug can cause the thin wall seat tube to bulge. They only used those for a few years too.
Peugeot also used and equally stupide brazed in front derailleur mount made for a special Simplex derailleur. I've seen pictures of a Huret FD to fit this too.
IS IT WRONG OR JUST FRENCH?
Those Simplex dropouts were good. They came out in the late 70's and were used up to the late 80's. They have an industry standard Campy style derailleur hanger.
The headset is a standard Peugeot model not a Stronglight. They were pretty good too and I never saw any that needed to be replaced.
Most of the frames with those "features" were decent quality and made of Reynolds, Vitus or Super Vitus tubing.
Should be a nice riding bike.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 4722 Post(s)
Liked 3,036 Times
As noted, this should be a 1984 model. Peugeot eliminated the traditional cinch bolt from some modes for 1984 and 1985 but the 1985 models used an internally expanding seat post as opposed to the grub screw. of 1984.
This feature was only found of three steel frames in the USA market: PZ10, PSV10 and PGN10. Of these three, only the PGN10 had fender eyelets on the rear dropouts. However, that is not a positive ID, as these could have been added by the previous owner, given the repaint and addition of rack bosses on the upper stays. Still, it doesn't appear to be designed for recessed brake bolts, which also has me leaning towards a PGN10 with Reynolds 501.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
T-Mar -
You are likely right on the PGN 10 id. The rear Simplex dropouts have the OEM machined relief in the back for a retaining nut and are not add-ons like the seatstay rack bolts.
Liked 3,036 Times
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
Just a couple observations since everyone already pointed out the one-year 1984 seat post braze-on which gives you an exact date. T-Mar listed off the models it could be.
1) Bike has been stripped and powder-coated, you can tell by the lug joints and the "SIMPLEX" being muddied up.
2) Bike is re-decal'd to look like an earlier model than it is
3) Peugeot never used a red that saturated on any of the 70s year bikes, one of the first uses of that red color I recall is the Peugeot Nice
4) That's a gnarly little ding in the TT, drive side
5) It's entirely possible there are other modifications (or repairs) to the frame not visible under the powdercoat
6) My trusty PGN10 has a braze-on to hold the FD onto the tube, so if this is a PGN10, that's been removed.
Edit for 7) TT cable guides removed also, so maybe (6) isn't impossible ... curious, what's the seat tube diameter?
Still cool looking, though. Interesting choices were made. Also curious, what numbers are embossed/stamped on the bottom bracket?
thanks for all the great info. Lots of experience on this sub-forum, and lots of eagle eyes.
To respond to the various points people mentioned here is additional info:
I see it has a "lightrace" headset, not "stronglight" like I first thought.
The fork does not appear to support a recessed brake bolt.
The rack mounts on the seat stays appear to have been tacked on later, as someone mentioned.
The seatpost is 26.4mm and the stem is the French 22.0mm.
The BB is a sealed shimano unit. Don't know if Peugeot shipped it that way or if it was changed later.
From the Peugeot catalog, it wasn't shipped with the Stronglight crank.
I'm guessing it's an '85 because the '84 didn't come in 58cm.
Catalog entry: 1984 Peugeot PGN 10
And now I know why that paint with those decals looked so unique. Judging from the original decals in the catalog, my son had a Peugeot from that era and it was a nice bike. I also see that "Record du Monde" was a red herring since the decals were changed. The power coating explains why the touched up areas are a perfect match. The seller and I were both surprised by that.
A few more pix:
A few more pix:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
I presume the seat tube outer diameter is hard metric 28.0mm. What diameter seat post does it take? This will help separate a higher-quality butted frame from one of its more humble brethren.
PM me your cotters
Liked 590 Times
That's one of the JPR (J.P. Routens) Extra Legere seat posts. @sunburst if you find at the minimum insertion line designated with ///////////////////////////////////// marks, you'll see faint engraved markings with pertinent info. You may need to take a crayon across it to really make the letters pop. Or maybe take a little ultrafine bronze wool to clean up some rust.
I don't remember what the one directly below the insertion marks is, but below that you'll see MADE IN FRANCE and just below that, even fainter is Ø 26.x (where X is the 1st decimal place of the seat post diameter). If your main three tubes are Reynolds 531, I expect Ø 26.4 to be on the post.
Interesting tidbit: If you look closer to the bottom, a centimeter or two below the seatpost diameter Ø markings, you should find a pair of two-digit markings giving the month and date of manufacture on that seat post. Like .... 03 84 would be March 1984.
Seatpost = 26.4mm
Date code 12 83
Seat tube outer dia = 28.6mm
Date code 12 83
PM me your cotters
Liked 590 Times
The highest likelihood here is you've got a 1984 PGN10 that's been significantly (but not radically) modified. I say this because I don't think the Vitus tubing would have same seat tube diameter (can't remember offhand) and I can't imagine anyone doing this to a PZ/PX/PY.
Reynolds 501 frame and fork for that model. Specs here.
Modifications I can clearly see are the removal of the top tube cable guides, the derailleur provision on the seat tube (probably removed and filled), thick red powdercoat, repaint on the fork, decals from 8-10 years (and earlier) prior applied.
It's still attractive. I own one and won't lie: I know it's a mid-level bike but I've owned it longer than just about any other bike I've got, I've rebuilt it twice now and it's on round three, I absolutely loved riding it over the years. I think a couple others here (Chombi, at least?) also have one they keep around.
I did find it was easier to mark the seat post pinch point and drill an indent there to prevent slippage though.
Hmm, so I need some top tube clamp-on cable guides. I wonder if this had been a fixie for a while. Why else would anyone remove the guides? Fashion?
So, how do you measure frame size, because the '84 catalog does not show 58cm? I measure center of crank to center of top tube. My local bike coop measures to the top of top tube. If that's the correct way, maybe this is a 60.
One last question, my main grocery hauler is a mid-80s (I'm guessing) Peugeot with 103 tubing (and looong chainstays!). How does 103 compare to the Reynolds 501? Last time I searched I don't remember finding any definitive info on 103. Now that I think about, I've got two frames with 103.
PM me your cotters
Liked 590 Times
This seatpost does have a couple of indents, so someone else knew this trick.
And yes, as far as the removals, probably multi-purpose: Help the bike look older than it actually is, make it sleeker for fixie use. The circular gouges where the rear wheel sides in drive side dropout would suggest the kind of pressure/wear you'd see from a fixed rear wheel vs. something wheel with a QR.
CTT measure (vs. CTC) would be what you'd see in the catalog.
Carbolite 103 tubing (aka Carbolite+ in some places) is a thicker,walled heavier tubing used on cheaper bikes. Per catalog specs, you'll find most of the Carbolite tubed bikes weigh at least 2-3 pounds more than any Reynolds 501 or better frames. There is also a model one level below this - I think the PH501? - that uses a Reynolds 501 main triangle, but Carbolite 103 fork, if I recall.
Liked 3,036 Times
During this era, Peugeot measured their frames from the centre of the bottom braclet shell to the top of the seat tube. Consequently, it's probaly a 60cm frame.
It's definitely not a 1985 model. As noted in my early post, the grub/set screw on the back of the seat tube was dropped at the end of the 1984 model year, in favour of an internally expanding seat post for the 1985 model year. The grub/set screw as seen on your frame, was only used for the 1984 model year.
Quoted: 346 Post(s)
Liked 266 Times
sunburst -
Reynolds 501 has butted main tubes of .9/.6 mm and stays of .9 mm. Peugeot 103 has plain gauge 1.2 mm thickness and stays of about 1.0 mm. Detailed 103 measurement info here: https://peugeotcoursepb12.wordpress....-assessment-3/ I have found a 1 lb 10 oz to 1 lb 14 oz difference between full 531 framesets and 103 built framesets.
Liked 3,036 Times
The highest likelihood here is you've got a 1984 PGN10 that's been significantly (but not radically) modified. I say this because I don't think the Vitus tubing would have same seat tube diameter (can't remember offhand) and I can't imagine anyone doing this to a PZ/PX/PY...
Liked 3,036 Times
A PH501 can be easily eliminated as a candidate, as it employed lugless construction. The fork could be be either Carbolite 103 (1985) or Reynolds 501 (1986-1987) but the stays were always Carbolite 103. The lugless construction eliminated most of the weight penalty of the heavier Carbolite 103, as well as being less expensive to manufacture.
PM me your cotters
Liked 590 Times
PH501 always stood out to me as a sort of "brackish water" bike. Not totally Reynolds ("salt of the earth") but also not totally Carbolite ("ordinary as fresh water").
(PS - thanks for the clarification on V/SV tubing ID)
OK then, it's a 60cm 1984 PGN 10. I'm very impressed to get this detailed info. Thx everybody!
I justed checked out my grocery hauler, same frame size, but the top tube and chainstays are about 1" longer. Not sure if the PGN 10 frame will be very rack friendly with the shorter stays.
Anyway, here is my 103 frame that I'd like to date and identify. I've got two with this tubing, with and without lugs. And I can't even find a model decal for the white/blue one.
This has been my main utility bike for 15 years or so. It was pretty much a wreck when I got it. It is a very stable and comfortable bike (technically too large for me), and handles rough roads with effortless aplomb.
PM me your cotters
Liked 590 Times
Without seeing the serial number from under the BB on each one, often in format of Y## ##### or B## ##### (if memory serves, that's correct for a lot of the '80s bikes) it will be impossible to nail down an exact year.
But for a WAG, the silver is very low-end model (hence the stamped rear dropout) but I can't recall if the "Course" designation is UO8 or UO9. These and the Grand Sports are everywhere. Approximate year will be 1980 - 81 +/- a year or two.
The pearl white one is a couple years older - talking 1983-85. The seat tube collar is probably a dead giveaway of the exact model, but looks like a P10 variant - P10S, PH10, something along those lines. I don't remember seeing a P6/P8 model with those cheaper forged dropouts. I think that style of Nervar crank showed up around 84?
Btw, WAG?
PM me your cotters
Liked 590 Times
Wild Ass Guess.
PS @sunburst note the silver frame has the more-sought-after Simplex Criterium shift levers. Can't quite tell which FD you've got on there. If Delrin isn't cracked, may be something interesting to another person. Granted, it also may crack the minute the buyer installs it, too ... That's one of those parts I like to toss up in the "pay-it-forward" thread that's randomly floating around or in the "ISO-trade" thread that's stickied to the top of the forum list.
