Recommend me a foam roller por favor...
Bikes: Motobecane
I have no idea what to look for in a foam roller for a cyclist. As a matter of fact, I had never really considered one until this year. I'm having some SI joint pain. Additionally, after using my trainer all winter, I'm continually pulling muscles (quad and calf) when running/playing soccer. After some research, I understand that ONLY cycling will cause issues with tight muscles when performing other athletic activities and that a post-ride stretch routine along with said roller will be of some benefit.
I'm looking at some on Amazon but I just don't know what to look for, what size, does it need ridges/texture, etc...
I saw the following at a marathon expo yesterday and it looked extremely easy to use on my lower back. Would this work?
https://www.amazon.com/Tiger-Tail-Rol...ds=foam+roller
This one (wooden) for the back and a high-density foam roller like this one for the legs come recommended by friends and family members who are cyclists.
Mr. Sparkle
Bikes: 08 Specialized Allez Elite
Liked 5 Times
I have an item like that called The Stick which I like for my calves and achilles. But it's no replacement for a true foam roller. You just can't get the same pressure with that as you can laying directly on a foam roller.
I love my Grid 2.0, it's pricey, but can be had for about $55 online. There is a shorter one that's significantly cheaper, but the longer one feels more stable and is more user friendly. Although I don't really buy the different zones having any real benefit, it's more firm than traditional foam rollers. You can also make your own by getting some large diameter PVC pipe and wrapping a cheap yoga mat around it.
Bikes: 2012 Scott CR1 Comp
Honestly, I would start with the soft white foam roller and go from there. If you aren't used to it, it will be quite painful at first, and a softer roller helps with this. Eventually you need to move to a harder roller, but I would not want to start with a very hard roller or it will be so painful you won't want to stick with doing it on a regular basis, and doing it with regularity is key.
Bikes: Specialized S-Works Tarmac SL3, Bianchi Cafe Milano
+1 for "The Stick".
I have a Rumble Roller that I use once or twice a week. I got the higher density foam (harder) and it hurts sooo good.
You blink and it's gone.
Bikes: Race bike, training bike, go fast bike and a trainer slave.
^^^That Rumble Roller is a true pain making machine, but it cuts through the crude and loosens up my glutes like nobody's business...
Reminds me, after a 6.5hr weekend of training I need me some foam roller!
Bikes: 2014 FUJI Roubaix
I have the black foam roller from Perform Better. It gets the job done. I also have "The Stick" and that works very well for loosening up the legs.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
I find "The Stick" virtually worthless.
Underwhelming
Bikes: Lynskey R330 Ti, Dean El Vado Ti, Trek 4300
Bikes: Haro Escape Hardtail, 80's SR, 90's KHS Flite 500, Raleigh Revenio Aluminum 3.0, Raleigh Revenio Carbon 3.0
A 12 lbs medicine ball like this
https://www.amazon.com/Valeo-Medicine...ef=pd_sbs_sg_1
Works great when laying my legs out and rolling the ball over my quads.
Makes a nice workout weight, too!
[IMG]https://i4.photobucke
Quoted: 5 Post(s)
Walmart has one that I bought, really cheap and works just fine. Used it when having IT band issues.
Bikes: Cannondale Slate 105 and T2 tandem, 2008 Scott Addict R4, Raleigh SC drop bar tandem
Quoted: 22 Post(s)
I have struggled with SI Joint pain and even complete immobilization of my SI Joints and have a foam roller and worked with a Dr. several times along with PT, exercise, etc...
I have had a miraculous recovery in only 13 days, no kidding. I hurt my collarbone and have been forced to sleep on my back for the last two weeks. I am normally a stomach sleeper and that is my go to position but I will never sleep on my stomach again. It apparently puts super stress on the SI Joints and causes all sorts of issues. No kidding, I went from barely being able to bend at the waist and failing the SI Joint test to now almost being able to touch my toes! I still have tight hamstrings but am working on those.
Bikes: 2007 Bianchi Via Nirone 7 and Azonic DS-1
