Help with buying correct tire
Hello, i have a question I currently have the following rims
Alex rims
AL-VP15F
6061-T6
They are on my 19 inch fram Technique Expert size
Tioga Tires size 20 X 1 3/8
My question is , if i buy a 20 X 1.75 size tire, will it fit or work for a short fix so i am able to ride today ?
Alex rims
AL-VP15F
6061-T6
Quoted: 1074 Post(s)
Liked 295 Times
Inch sizes are tricky. There is often several non-interchangeable ones lurking under the same - or very similar - designations.
It’s safer if you can find the ISO/ETRTO millimeter size.
You HAVE to match the Bead Seat Diameter - where rim and tire overlap.
20x1 3/8” comes up as a BSD of 451 mm, while a 20x1.75” is likely to be a
406 mm BSD.
There may be others.
Read here for more:https://www.sheldonbrown.com/tire-sizing.html
406 mm BSD.
406 mm BSD.
406 mm BSD.
useful , ty
