Go Back  Bike Forums > Bike Forums > Framebuilders
Flat Mount disc jig
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Flat Mount disc jig
Old 11-19-19, 03:46 PM
BigPoser
BigPoser's Avatar
Bikes: BAHL Giro, BAHL Uno, BAHL GVL, Cuevas
Quoted: 250 Post(s)
Liked 13 Times in 9 Posts
Flat Mount disc jig
Just wondering who else is making a flat mount disc jig. I know that Anvil was, and Incepi was also, but their site is down or they're down for the count.
I'm not all that familiar with tool makers just yet.
Thanks.
Brandon
BigPoser is offline
Old 11-19-19, 04:56 PM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
The Anvil only worked on rear mounts anyway. Only one I have ever seen for forks was incepi
unterhausen is offline
Old 11-19-19, 06:40 PM
wsteve464
Quoted: 161 Post(s)
Liked 71 Times in 62 Posts
I looked for a flat mount jig a couple of months ago and came up with the same as you did no Anvil and no Incepi to be found. I did not find anything else.
If you have better luck please let us know.
wsteve464 is offline
Old 11-20-19, 06:01 AM
dsaul
Quoted: 713 Post(s)
Liked 796 Times in 473 Posts
I'm sure someone, possibly Joe at Cobra, will step in to fill the void left by Anvil. In the meantime, I'll work on making something and post it here. My work schedule is a little hectic right now, so I don't know when that will happen.
dsaul is offline
Old 11-20-19, 07:34 AM
unterhausen
Randomhead
I know Don didn't make any money on the Anvil fixture, but I wasn't a big fan of it. It relies on some little spacers that are a pain to keep track of. Since it's an adapter, it's inelegant. I was never sure how the Incepi worked, I think you had to get it on the axle at the right place somehow that was not obvious. Could be wrong though.
Old 11-21-19, 09:00 PM
duanedr
Quoted: 103 Post(s)
Liked 144 Times in 88 Posts
I recently saw somewhere that Joe is working on a frame fixture otherwise he would take on the brake fixture. I also saw that PVD is working on one with some other folks.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
duanedr is offline
Old 11-22-19, 09:50 AM
unterhausen
Randomhead
Alex Meade posted a survey about this on FB today, so he's probably going to make one
Old 11-22-19, 05:45 PM
BigPoser
BigPoser's Avatar
Quoted: 250 Post(s)
Thanks guys.
Yup, I saw the same poll from Alex. Verdone is working on one as well from what I saw the other day.
BigPoser is offline
Old 11-27-19, 06:39 PM
dsaul
Quoted: 713 Post(s)
Prototype Flat Mount rear fixture. That means this one will be mine. If I make any more, they will probably be all one piece. The original idea was to make interchangeable inserts for front and rear, but they are too different to make that practical.
dsaul is offline
Old 11-27-19, 10:12 PM
niknak
Quoted: 120 Post(s)
Liked 43 Times in 35 Posts
Nice work on your fixture! I imagine it slides onto an Anvil dummy axle. How do you phase the flat mount bosses so their slots are parallel to each other and the rear axle? I think Anvil's fixture had oval shoulders that fit into the bosses to keep them aligned, but I could be wrong.
niknak is offline
Old 11-28-19, 05:07 AM
dsaul
Quoted: 713 Post(s)
That is something that I thought about, but I didn't want to add that level of complexity to this manual machining project. I will probably be using one piece mounts that have both slots already phased. This was designed to push the mount fully outboard when bolting it to the fixture. I don't think it will be too much of an issue to make another insert with a shoulder, if necessary. Although that shoulder will be a rectangle and not an oval.
dsaul is offline
Old 12-04-19, 10:57 AM
BigPoser
BigPoser's Avatar
Quoted: 250 Post(s)
Very cool! Keep me posted on how well it works and if you make more.
BigPoser is offline
Old 12-04-19, 02:10 PM
dsaul
Quoted: 713 Post(s)
I actually made an adapter for my Feng Shui that should work well for the rear brake. I think the other fixture I made will work for the front with a fork mount adapter plate.
dsaul is offline
Old 12-04-19, 09:14 PM
unterhausen
Randomhead
someone posted some designs on FB, and I was impressed about how much better an adapter works on an ISO fixture than it does on a post mount fixture.
Old 12-05-19, 05:00 AM
dsaul
Quoted: 713 Post(s)
Those designs are what inspired me to make the Feng Shui adapter. After making the adapter, I can tell you that the design posted for this purpose will be problematic. He has not taken the standoffs into account on the Feng Shui and therefore you would need to space the fixture about 17mm away from the dropout face to have the flat mount holes in the right place. At that distance away from the dropout face, the fixture is almost falling off the 19mm part of the dummy axle. I appreciate his sentiment in trying to find an inexpensive solution and sharing it, but he should have done some real world testing of the concept.
dsaul is offline
Old 12-05-19, 12:53 PM
BigPoser
BigPoser's Avatar
Quoted: 250 Post(s)
Looking great!
BigPoser is offline
Old 03-01-20, 10:10 PM
incepi
After an absence from the market, incepi disc mount fixtures are available. ISO and Post Mount fixtures are in stock, and Flat Mount fixtures are on order and expected soon.
incepi is offline
Old 03-02-20, 06:22 AM
ksisler
Quoted: 25 Post(s)
Those look fantastic and the costs are quite reasonable, imho.
ksisler is offline
ksisler
Quoted: 25 Post(s)
ksisler is offline
