Where do you carry tubes and CO2?
Do you all prefer to carry extra tubes in a bag attached to the seat or in a back pocket of your jersey?
pan y agua
Quoted: 1441 Post(s)
Liked 709 Times
small seat bag.
Put a tube 2 Co2 cartridges, tire iron, patch kit, mini tool and tire boot in it, and you don't have to worry about it.
In a jersey pocket, you've got to grab the stuff every ride.
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 709 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
I've also seen nice bottle cage storage solutions. Makes for a cleaner look, but if you plan on riding long enough to need 2 bottles it becomes less useful.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Bikes: Steel 1x's
Quoted: 632 Post(s)
I used to carry it under the saddle, but I found myself buying extras for each bike. Not to mention, the bag would interfere with whatever gadget I had on the seatpost (light, Varia, Fly6)
Recently, I found a small mesh bag about the size of a jersey pocket and tuck everything in there. So no matter which bike I'm on, I just slip it into my middle pocket and I have all my stuff with plenty of free space on the seatpost. The other two jersey pockets are free for other things.
Bikes: 2015 Storck Scenero G3 (Force 22)
Quoted: 125 Post(s)
Quoted: 125 Post(s)
The Arundel Dual Holds 2 tubes, 2 tire levers, and a multi-tool. Lezyne pump is Velcro-ed to the frame bottle cage. Prefer to keep my pockets free for comfort and other layers depending on the weather.
If you're carrying CO2 and not a pump, better be sure you know how to use it!
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Bike stuff goes on the bike. Rider stuff stays with the rider. It's easier that way.
Water bottles are the obvious exception.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Since we're talking saddle bags in here, anyone find any difference between bag shapes? The Arundel bag linked here is a taller, skinnier bag, whereas the one I use is a wider, shorter bag. The reason I like mine is it doesn't move around under the saddle. I imagine the taller ones might flop around a bit more, but I don't know that. I do have one that is more tall, and it has an additional strap that goes around the seatpost. That one is the most secure of my bags, but it's bulkier and not as tidy as the wider one I use primarily. BTW, I don't have any issues with the wider one rubbing on my thighs, but could see how if it was much bigger, that would be an issue.
@PepeM has a nice bike purse that would work. Would love his input on this.
CO2, inflator, multi-tool, chain breaker, extra chain links, money, latex gloves, and tire levers go in the small bike purse:
During the winter, stuff like food, extra gloves/warmers, phone, mini pump, the small bike purse, and other assorted items go in the big bike purse:
Hope this helps.
Liked 3,106 Times
pan y agua
Liked 709 Times
Bike purse is easier than reassembling everything each ride, but you still have to remember to grab it.
Easier for me if its always on the bike.
Quoted: 125 Post(s)
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Quoted: 6556 Post(s)
Liked 58 Times
Here we go again. If you have access to an amenities kit such as given out in 1st and Business Classes of overseas airline flights, I highly recommend those for keeping your ride maintenance kit in your back jersey pocket. I used to travel in Business Class a lot and have several of them. If you don't, try to find a friend or work colleague who does or who can get you one. They are perfect for the job. I carry so much stuff in mine, it is too much to list here given my outrageous lazinenss.
Quoted: 3241 Post(s)
Liked 2,512 Times
After having some Ziplocs fail on a wet day, everything I want to keep dry goes in a small dry bag...in the middle jersey pocket. Stuff that can get wet goes in the saddle bag.
