Orfos Flarepro bike light, good or bad?
Old 08-26-18, 06:56 PM
angerdan
Quoted: 126 Post(s)
Liked 7 Times in 7 Posts
Don't you think about how to put your USB power source out of water before you'd buy the FlarePro?
I'd recommend an top tube bag.
topeak.com/us/en/products/waterproof-bags/365-tri-drybag
topeak.com/us/en/products/bags
angerdan is offline
Old 08-27-18, 06:24 PM
RidingMatthew
Let's Ride!
RidingMatthew's Avatar
Quoted: 327 Post(s)
Liked 37 Times in 24 Posts
@angerdan I did but I didn't think it all the way through. I forgot how much I disliked the look and functionality of a light with a separate battery pack.
RidingMatthew is offline
Old 08-28-18, 02:11 AM
angerdan
Quoted: 126 Post(s)
Then maybe you'll find at least a new owner here for your OrfosPro.
angerdan is offline
Old 08-31-18, 12:56 PM
01 CAt Man Do
01 CAt Man Do's Avatar
Bikes: Mountain bike & Hybrid tour bike
Quoted: 183 Post(s)
Liked 7 Times in 6 Posts
@angerdan....Just a question about the OrfosPro's that I thought you might be able to answer. When you connect the unit to a micro (?) USB plug...Is there some sort of protection there to protect the port from water/rain ingress if it were to rain while on a ride/commute? This is a worry for almost any type of lamp that either charges or runs with a wire plugged or unplugged into a micro USB port. I own several of the Raveman lamps which can run with a remote control button plugged into the micro USB port. Now if it started to rain while using the lamp / remote I would have no choice but to unplug the remote and close the rubber flap. How does the Orfos products handle this situation or is it not addressed.(?)
01 CAt Man Do is offline
Old 09-02-18, 08:04 PM
thebellmont
Quoted: 5 Post(s)
On my casual rides I have used a zipper top tube bag to protect the battery for my front light --it's a full-sized (not micro) usb connection.
Orfos didn't design any specific rubber gasket or any other specifically waterproof attachment method to protect your battery more. I think their usb cord and connection is waterproof by design if I remember from videos…as for the battery you use for power ymmv.
Personally, I haven't had any issues with waterproofing using an aftermarket top tube bag and an Anker lipstick tube battery. But I have had two Orfos lights fail at the plastic shroud, essentially the plastic silver shroud that protects the actually usb connection pulls away (exposing metal and wiring) after some use. Nothing has shorted out electrically…it was just glue failure. Depending on my riding (commute or touring) I have also kept my rear light attached a backpack and my front attached to the front pocket of a handlebar bag. @RidingMatthew I agree re: cost, time and ghetto-ness of Velcro.
thebellmont is offline
Old 09-03-18, 07:13 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
The thought of rain in the electrical connector is bothersome, but rain water actually has negligible impact on the low voltage circuitry of a bike light. You can disassemble and reassemble a 2 battery D-cell maglight completely under water and it will still work fine, though full of water (I have done it). The issue you really need to worry about is if the water gets inside the LED circuitry and causes longer-term corrosion. That is where the Orfos 'shines.' Everything behind the electrical port contacts is waterproof sealed, so water cannot get into the internals, even though it can get between the contacts of the exposed plug. Put your Orfos in a sink full of water (it is waterproof) and plug in the USB power supply, It will work fine, just shake out the water after you are done.
My flare gets water on the exposed port all of the time, but it never gets past the waterproofing to harm the light internals.
dwmckee is offline
Old 09-03-18, 09:29 PM
01 CAt Man Do
Quoted: 183 Post(s)
Okay....but will it short out the battery? There's a reasons why the connectors on most bike lights that use external batteries have rubber sleeves that cover the connectors. If your battery shorts out most bike batteries ( the non-USB type ) have a circuit built in that will cut the juice. Personally I've never had a battery short out but once and it was so long ago I forgot why it happened. I'll take your word that it will still work if you've actually done this.
Old 09-04-18, 11:45 AM
angerdan
Quoted: 126 Post(s)
Lightbulb
  1. When you connect the unit to a micro (?) USB plug...Is there some sort of protection there to protect the port from water/rain ingress if it were to rain while on a ride/commute?
  2. This is a worry for almost any type of lamp that either charges or runs with a wire plugged or unplugged into a micro USB port.
  3. I own several of the Raveman lamps which can run with a remote control button plugged into the micro USB port.
  4. Now if it started to rain while using the lamp / remote I would have no choice but to unplug the remote and close the rubber flap.
  5. How does the Orfos products handle this situation or is it not addressed.(?)
  1. It's an classical USB A plug. No protection on the plug, since the cable and the whole light itself are complete watersealed.
  2. When the cable is fixed to the light, it should be water resistant. So no problem with an water resistant top tube bag.
  3. It's a nice feature, known by the Fenic BC30 and BC30R.
  4. A poor design flaw, with a good rubber sealing around the plug it would be safe(r).
  5. Since there are no waterproof Powerbanks, it's not an issue. The USB power plug has to been protected anyway.
angerdan is offline
Falchoon
5
10-02-17 12:13 PM
Mickey2
7
04-26-17 10:44 AM
spectastic
36
02-24-14 12:32 AM
stedanrac
2
11-26-12 02:10 PM
Raptor1956
7
08-09-10 06:09 AM
