Wahoo Elemnt Bolt
#76
Quoted: 551 Post(s)
Liked 277 Times
Swapping From a Garmin to a BOLT | Wahoo Fitness Blog
#77
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
You may want to ask Wahoo. They love answering questions that get people to move from Garmin to them.
FWIW, I think any ANT+ power meter should work. According to Wahoo, that includes the Vector: https://support.wahoofitness.com/hc/...ith-the-ELEMNT
#80
Quoted: 550 Post(s)
Liked 325 Times
After 2 years they still have data problems with some power meters, and haven't fixed the map issues.
#81
Since so many things on or associated with my bike now have CR2032 batteries, I just replace them all in the spring every year on all of our bikes. It's just easier that way.
J.
#82
Bikes: yes
Liked 643 Times
No. Mine last at least one year and usually almost two. Two things: 1. You have bad batteries which is not at all uncommon or 2. your sensor is consuming too much power.
J.
J.
#83
I returned my ELEMNT because it didn't accurately record data, and the maps didn't work well for cycling. The minor roads used by cyclists disappear when you zoom out, you can't pan the maps to follow them zoomed in, and there are no street names for you to orient yourself.
For mountainbiking it is really bad. The GPS accuracy tells you you are of track and segments don't stop recording until you passed end point with 30-40 meters if you are in the woods. Garmin, Iphones, android phones all work much better.
#84
Quoted: 3238 Post(s)
Liked 2,086 Times
Yes, return it while you can. I did not do it in time which I regret. It might be ok if you only ride road and add a speed sensor. Without speed sensor it reports to low speed.
One advantage in this type of use to a Garmin, is the ability to install different maps that are more useful for other-than-Road trips.
Maybe Wahoo pays attention to this and will change its format. Not likely though.
#86
Ummm. No. I have had this problem with brand name batteries too. It’s inherent to the technology. Testing disposable batteries is like testing firecrackers.
#87
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
#88
Amazon is known to be indifferent to fakes of CR2032 and other std battery sizes. The fakes are so pervasive, and the copying of packaging so perfect at this point, that honestly the only way to be 100% sure of authenticity is to get them directly off the loading dock of Energizer/Duracell etc.
#89
Quoted: 95 Post(s)
Liked 9 Times
Would you think the Bolt be too small a screen size to use for a 54 year old cyclist eyes? If i have to use the GPS i would put on my bi-focal sunnies - dualeyewear. It's got a +1.5 diopter correction at the bottom.
I have the magellan Cyclo 505 - a brilliant piece of navigating GPS unit but it's pretty heavy to be toted around unnecessary. I'm hoping the Bolt could be my go-to GPS unit for not so heavy navigation requirements.
#90
This is precisely why I got the larger Elemnt. They have the same software but the Elemnt has a slightly larger screen. The Bolt is tiny. The Elemnt is not big but bigger.
#91
Liked 406 Times
#92
Quoted: 95 Post(s)
Liked 9 Times
I tired the 505...I found the screen hard to read...the Bolt is monochrome LCD and quite readable in direct light. How many data fields do you think you'd want? Remember with the Bolt you can zoom in/out on the fly changing the number of data fields and making them bigger or smaller.
No - I don't use a lot of data fields - just need the occasional navigation to tell me where the turns are for the infrequent routes that i often use.
my theory is that for something small like the Bolt monochrome should work better- provided the TBT's prompts are clear too. I mean you'll want to be able to easily see the TBT's countdown to a turn. From what i gathered the TBT countdown's font cannot be enlarged.
I want something much lighter than the Cycl505 to use and yet still provide navigation. So i'm looking at the Bolt or the new (not out yet) edge 520 Plus. I wonder if the Bolt's monochrome would still have the better readibility screen over the newer Edge 520 Plus.
#93
Fred
Bikes: Specialized Tarmac Comp, Trek 4100, Specialized Allez Elite, Kickr Snap
Quoted: 24 Post(s)
I have 56 year old eyes and I generally don't have a problem with the display. Can I see everything on it? Well, not really. But the turn prompts are easy to read and they are reinforced with both audio and LEDs. The audio is different for left turn, right turn, and straight ahead, and the LEDs flash in a pattern that makes the direction of the turn clear.
#94
Liked 2,086 Times
Actually I have 63 yr. old eyes and 95 yr. old ears, thus the audio prompts on all these devices are wasted on me.
Likes For Steve B.:
#95
Liked 406 Times
https://www.sweetwater.com/store/det...throne-thumper
https://drumsonsale.com/pearl-throne-thumper.html
#96
Quoted: 95 Post(s)
Liked 9 Times
Not owning it yet but there's quite a few things i already like about the Bolt already:
- the ability to switch off the back light completely
- ease of zooming (maps and data) - this is a big plus
- monochrome screen - i believe this is a huge factor in the readibility of the screen in all conditions while on the bike. Color screens are over-rated on the use of the bikes
#97
#98
Liked 406 Times
Do understand that if you have your phone, you can select a new point (poi, address etc...) and force a rout to that point which is then instantly pushes to the Wahoo Elemnt or Bolt. It’s pretty much the same as rerouting on the bike computer in most cases but you don’t need to suffer through the insanely frustrating process of entering text on the bike computer itself.
#99
Liked 2,086 Times
As well, I find the Wahoo maps to be road centric, no ability to load a Topo maps is a huge feature to me when I explore gravel roads, that in some instances are not in the Wahoo map. Garmin gives you more flexibility in their respect.
#100
Quoted: 1814 Post(s)
Liked 923 Times
Recently got a Bolt, & I'm having trouble with the app.
It struggles & crashes on my iphone 6. It worked at first, then worked when getting best cell reception.
Now, not really, even after rebooting phone, unpairing/repairing head unit, & uninstalling/reinstalling app as recommended by Wahoo support.
I have little other stuff running on the phone.
Suggestions?
Suggestions?
