Will these panniers attach to the Tubus Tara rack?
on the hard road.......
Hey folks,
will these panniers fit on a tara front rack?
https://www.wiggle.co.uk/p/cycle/7/dh...rs/5360033205/
https://www.wiggle.co.uk/p/cycle/7/Tu...ck/5360025260/
maybe it's a dumb question but i was hoping for a simple hook at the bottom.
ah.... sure.
Bikes: Specialized.... schwinn..... enough to fill my needs..
Very similar mounting system to the Ortliebs. Should work well. So you should be able to make it work.
I say go for it. Look like pretty nice panniers for the money.
A quick email to Wiggle should also work. They do seem to respond in a reasonable time to questions.
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,093 Times
Hey folks,
Stuart Black
Stuart Black
Quoted: 4222 Post(s)
Liked 1,322 Times
The bottom "hook" (which would seem to rotate) appears similar to the Orliebs (which are "made" for the Tara!).
These should work fine on the Tara.
Thanks folks, i ended up goiing for the ortleib fronts instead, they weren't much more and just a bit larger, plus they look cooler
Bikes: 08 LHT and 13 giant defy 2 composite
You shouldn't have any problems the Tubus Tara racks are very pannier friendly and can accept many types of panniers.The lower mounts on the panniers you are useing are identical to my Carradice super c panniers with the c system mounts.The top mountings I cant say for sure but I don't see any reason they wouldn't work.Tubus makes good racks that you can mount almost any pannier to.
