Riding and Maintenance tips
Old 07-12-10, 02:20 PM
stapfam
Time for a change.
stapfam's Avatar
Liked 5 Times in 4 Posts
Dare say you have a great many more but I am currently plagued with a problem when riding. Sweat rollling down into the eyes. I always wear a cycling cap under the helmet and this stops the sweat from rolling down the face and into the eyes. If it gets too hot- I just wet it from the water bottle and it will stay cool for a good while.
But listening to Sean on the TDF he came up with one that he uses. A smear of Vaseline above the eyebrows. He also qualified this with saying "Just a smear".In other words not a thick layer.
And Brake and Gear cables. My regular maintenance is to release the cables and washout the inners with WD 40 and then the cables are lightly lubed till the next Washout. My LBS told me to use "Dry" chain lube. It works just aswell and has the advantage of not attracting dust that then clogs up the outer cable.
So what can you pass on to Aid maintenance?
Spike Milligan
stapfam is offline
Old 07-12-10, 03:22 PM
The Weak Link
The Weak Link's Avatar
Bikes: GF Wahoo '05, Trek T1000 '04, Lemond Buenos Aires '07
Liked 7 Times in 2 Posts
Never pick your nose while you are re-greasing your hubs.
The Weak Link is offline
Old 07-12-10, 03:43 PM
zonatandem
zonatandem's Avatar
Quoted: 77 Post(s)
Liked 19 Times in 11 Posts
Run gear/brake cables through a block of parrafin wax before re-installing.
zonatandem is offline
Old 07-12-10, 04:12 PM
DnvrFox
DnvrFox's Avatar
Liked 12 Times in 10 Posts
Find a really good LBS with a great mechanic that you can talk to. Take your bike in regularly.
DnvrFox is offline
Old 07-12-10, 04:14 PM
RoMad
RoMad's Avatar
Bikes: Litespeed Tuscany , Lemond Poprad, 1970's Motobecane Grand Record
Quoted: 9 Post(s)
When I lube the cables on my bikes I hang the bike by the front tire and put the lube in every opening that is pointing up. I wait a little while, then hang the bike by the back tire and put lube in every opening that is pointing up.
RoMad is offline
Old 07-12-10, 04:30 PM
DX-MAN
My shifter cables are the only ones that have ANY exposure; I run full-length (XTR) brake housing front and rear. When I do anything with my shift cables, they get a LIGHT coating of Slick 50 One grease, and are usually good for a year or more.
DX-MAN is offline
Old 07-12-10, 04:37 PM
The Weak Link
Seriously, never assume that there is a task so simple that you cannot botch it up. Double-check everything. I almost met my Maker earlier in the year because I misinstalled a Shimano chain (not exactly mis-install, just thought I could get away with taking a shortcut having to do with not using a replacement pin).
Robert P
Bicycle Mechanics
8
05-15-17 12:31 PM
tyrion
Bicycle Mechanics
10
03-23-16 12:00 PM
SlimAgainSoon
Bicycle Mechanics
32
05-15-14 02:02 PM
banerjek
Road Cycling
34
12-18-13 11:31 AM
MNX1024
Road Cycling
13
06-10-11 07:25 AM
