Racer Tech Thread
#351
Bikes: Canyon Aeroad, Ridley Fenix
Quoted: 22 Post(s)
i've been on this saddle the whole season on my clown car bike (see race bike thread). no comfort/discomfort issues - i race almost exclusively crits and my longest training rides are about 4 hours on a weekend. really the main thing initially is because its not padded the saddle is a little slick and you slide around at first which can take some getting used to. but that's not an issue anymore.
as you know, saddle comfort can sometimes be individualized, so TMMV in terms of comfort. but that would be true of any saddle.
#352
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
Opinions on S-Works chainrings vs. others? I work in a Specialized LBS, so I can get them relatively cheaply. I want to try 52/36 rings on my Ultegra compact crankset.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#353
Quoted: 693 Post(s)
newer style is nice but overpriced...even at dealer cost. they don't shift as good as shimano rings. highly recommend 7900 on an otherwise specialized crank, though i'm not sure 52/36 is an option.
#357
Quoted: 19 Post(s)
Sizing question for all the experts here. I'm looking at some new frames and I want to make sure I get the correct stack for my fit. My current bike is a 58cm Jamis with a 58cm stack height and a 180mm HT length. I have 3cm of spacers from the top of the head tube to the bottom of the stem. Do I just add this 3cm to to the stack height to get my actual number or is there more involved? Doesn't seem like there should be more than that but I'm not 100%.
This is the bike and you can see the spacers. I really don't want more drop than this, I'm just not flexible enough.
#358
OMC
Quoted: 461 Post(s)
Liked 116 Times
TR - I guess this is the older style, they're the less expensive version.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#359
Bikes: i may have bike(s)
Quoted: 46 Post(s)
It looks like I may be upgrading my wheel set soon. I have been torn over wider rim clinchers versus tubeless. I am thinking a new PowerTap will go on the rear too. I am wondering what you guys might recommend although I know that there are not a lot of adopters yet. These will be my do everything wheels and as such I am willing to sacrifice tire life for a bit extra grip. Plan to spend ~$2000. Or best to just have a talk with the chaps at Fairwheel?
#360
Bikes: Yes
Quoted: 9 Post(s)
Ex knows a bit about tubeless as do the cross heads. I recently went 11 speed and wide for both race tubulars and training clinchers. I got both sets for well under your budget. Once you go wide, you should stay wide, as, at least on my frame, requires a lo tof brake readjustment. Once it is set up though it's easy to swap. One thing with wide (both of mine are 27mm) is that 10psi makes a huge difference in ride quality without an almost imperceptible difference in speed.
#361
Quoted: 46 Post(s)
Hmmm....Thanks. I definitely am going wide no matter what. @shovelhd are you saying that you are riding tires with a width of 27mm?
The ride quality intrigues me when it comes to tubeless but I am leaning more that way because of the reduced likelihood of catastrophic failure (at least in theory). After reading about clinchers failing mid turn in a crit, I want to lessen my chances. I train several days a week on the local mtn where it is no problem hitting 45mph+ on the descent. So I want that extra assurance on my training wheels.
#362
Quoted: 693 Post(s)
avoid.....ESPECIALLY in 52/36. they made them light, but a larger ring with smaller BCD exacerbates the problem. if you're going to go 52/36, you want stiff rings.
#363
Quoted: 693 Post(s)
Teton, would this work: Chain Keeper Direct from Paul Component Engineering
the bolts mount perpendicular to the bike axis; with other derailleurs/moutns, the bolts are parallel to the bike axis.
#364
Quoted: 693 Post(s)
worked pretty quickly but methodically. ~13.5# so far, but lots to add...rotors, cassette, chain, crankset, pedals, tape....and fluid in the brake lines.
#365
Bikes: Yes
Quoted: 9 Post(s)
#366
OMC
Quoted: 461 Post(s)
Liked 116 Times
TR - Thanks, this is the info I was looking for. This is a "sometime this winter" project, so I'm in no hurry. Looks like either Praxis or maybe a 5800 or 6800 crankset at this point.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#367
Quoted: 46 Post(s)
No. The rims are 27mm at the outer edge. I am currently using 23mm sewups and clinchers but the clinchers are really 24mm (GP4000s). One thing you will discover as you shop is that everyone's definition of wide is different. I did a ton of research to end up with what I have.
#370
Quoted: 46 Post(s)
I think that I found the answer but want to confirm:
1. One can run a dura ace 7800 or 7900 crank and chainring with 9000 everywhere else, correct?
2. Can the 9000 chainrings be installed on the 7800/7900 crank?
From my understanding, the chainring spacing on the 9000 is slightly closer, on the order of a few tenths of a mm.
Thanks.
Thanks.
#372
Quoted: 46 Post(s)
Got a used pair of Conti Comps on a pair of tubulars.
Previous owner used Tufo tape, I'm using Mastik One.
Tufo Tape came off clean, basetape looks good, but has a bit of tack (just like if you peeled tape off of anything).
1. Is it worth trying to clean off or can I put a layer of glue overtop?
2. If the answer to #1 is clean, how to clean?
