Will I enjoy a heavy gravel bike?
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Hi all,
I have a decent road bike that I really enjoy riding, but which would barely hold 28mm tires, so I have no aspirations to gravel-fy it.
I also have a 1970's steel, lugged, heavy, but sturdy bike with plenty of tire clearance, but also heavy steel wheels, seatpost, bars, and components (Stem shifters). I purchased the bike for $15, stripped it to bare frame, cleaned and re-greased everything, and reassembled with new chain, cables, and 26 x 1 3/8 smooth city tires. It's nice for cruising around town.
Would I be able to enjoy much off-road (Gravel, trails, grass) adventuring with this bike if I simply got some more off-road tires, or would the very heavy weight (35-40 lbs, I assume, I really have no idea) severely limit my fun?
I know most even entry level gravel bikes are in the low 20's in weight.
Quoted: 5888 Post(s)
Liked 3,471 Times
Old Fart In Training
Quoted: 12 Post(s)
Liked 22 Times
If your not Into racing weight is less of a thing.
My Gravel bike stock was between 21 and 23 pounds or there about's, With the junk I've hung on it prolly 28 or 29 now, I don't care..
Get something that can take up to 35-40c tires with a little room to spare.
Any 2x drive train will be fine,,find a 3x, ride the 3X and no worries.
So while your bike is definitely no lightweight, depending on how you're measuring it, it might not be quite as much of a brick as you think. If it's 35lbs as pictured, you're nowhere near Varsity territory.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
I have a lightweight vintage bike that will see some gravel duty. It's excellent on smooth and firm gravel. However, a heavy vintage bike, like the one in your picture, would not be enjoyable. Get an aluminum Cyclocross bike from bikesdirect.com and you will have a much better ride for a modest outlay.
1) scuffing those steel rims for better braking in mud
2) replace the steel rims with aluminum ones for even better braking in mud
3) lowering the lowest gear
Quoted: 270 Post(s)
Heck yeah. You'll probably have lots of fun. If not, at least you didn't blow $2000 on a new bike. Those tires will be totally fine for exploring dirt/gravel/grass. I think the first upgrades for that bike would be:
-lighter road bike with 25mm tires vs heavy bike with wider 35mm tires.
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
It's a tossup as to whether the bike breaks first or you die in a downhill wreck due to extremely poor braking capability.
You could have some fun, yes-- cycling is fun-- but that bike is for rambling, not gravel road riding. In other words, you can ride dirt on it, but why would you choose to do that?
For the record, and I do hope you report back after some rides, I'm betting on breakages. Spokes, seatpost clamps, pedals, fork, frame...stuff like that failing quickly is my bet.
Quoted: 270 Post(s)
I took it down a gravel road (quite large, deep, and loose gravel, IMO...mostly downhill about 3-4% going down, then the same uphill coming back to the paved road) I felt like I had to really control the speed going downhill since I felt that any kind of turn at speed would wipe me out. I attribute some of this to having zero MTB experience, so any kind of skidding felt very unsettling. Coming back up, I definitely lost traction several times, and had to fight to keep the bike pointing the direction I wanted.
OVERALL VERDICT: The bike held up fine, as I exepcted it to. No punctures, and no falls, but I was pretty careful. I don't think I would call the riding experience "fun"...more of what I would call "can I do this without getting hurt?"
2. As for the Old Free Spirit...I hope to try it on the same road toward the end of this week, but I dont' expect anything to break, simply because the bike is so old and tank-like that if anything was going to fail in the last 40 years, it would have already. Having completely stripped the bike down to bare frame and built it back up, I would have found any failing parts. I did not mess with the spokes much, and they could all probably be tightened a bit, but they are all about the same tension, based on ear, and mostly true, and there are a LOT of them (36/wheel).
I have the feeling I could let this bike fall off my car rack at 20-30mph, and most of it would be just fine.
As for braking, I have replaced the brake pads on the bike, which are a big improvement over the 40-year old brake pads. :-)
EDIT: Maybe I'll actually get around to weighing this bike too!
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,017 Times
Do you know that you enjoy riding on gravel on anything? It's different from road riding and you may or may not like it. Take that bike out on some short non-technical gravel rides and see if you like the experience and see how well it handles. If that convinces you that you want to do more, then maybe think about another bike.
Quoted: 270 Post(s)
-Childhood bmx style riding around town
-Teenage mountain bike that I only rode on the roads (I lived in a downtown area)
(though I remember enjoying going fast on snow-packed roads and slamming on the brakes to skid for fun...)
-Adult: Commuting, group rides, and recreational rides on road bikes.
(no off-road experience or technical handling skills).
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Who knows, maybe the steel rims will prevent you from locking up the brakes in a panic on the descents, helping to maintain control. Certainly wouldn't be my choice for anything, though.
Quoted: 270 Post(s)
UPDATE! I rode about 3 miles of the gravel road today. (Same road I tried with my road bike (25mm tires) last week...mix of small and large gravel, anywhere from 1/2"-2" rocks, with a few packed down tire sections as well, but plenty of loose, deep gravel also). 1.5 miles of rolling hills trending downward, then back up to the paved road.
In a word, it was awesome! The 38lb (with fenders and rack), 40-yr old bike with 26 x 1/38 road tires worked like a champ! It was extremely confidence-inspiring by comparison. I immediately felt free to go MUCH faster, both on downhills, and even on turns. The ride even included a dog chase for about 30-40 seconds that got me really moving fast to get away, and I felt I was able to do it with this bike in a way that would have had me terrified of wiping out on the road bike.
Also, nothing broke, no flat tires, and even the lowest gear I had (39/28) didn't feel like it was excessively hard...I used it, but never felt like I needed another gear.
I could definitely see myself doing some gravel adventure riding or light gravel touring with this bike AS-IS. Any upgrades would just be icing on the cake, not necessities. Thanks for reading!
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
An old road bike is an awesome choice for a gravel bike, but I see at least two weaknesses with yours, and both relate to the wheels.
First, 26X1-3/8 (650A?) is not a common size so your tire choices are going to be limited. You may not have easy access to appropriate tires for the riding you want to do. You can surely find something decent online, but you might not have good luck at LBSs.
Second, steel wheels are much more easily dented than aluminum wheels, but more importantly is that brake pads on chromed steel rims generally provide the worst possible braking performance, especially when wet.
But if you already have decent tires, and you don't ride in wet conditions much (or you find a set of 26X1-3/8 aluminum rims for cheap) then there is nothing stopping you from getting out and ripping up the gravel roads.
Quoted: 969 Post(s)
Liked 1,632 Times
Find another ChroMo to gravel with, but a real good start is getting a set of good gravel tires. I don't really do gravel ridding but the back roads I ride are pretty rough in places and a good set of tires pays off big when getting through a bad patch. I'll vouch for Continental Tour Ride as they are cheap, fast, and durable.
https://www.biketiresdirect.com/prod...r-ride-27-inch
Quoted: 270 Post(s)
Yes, I've researched, and there is exactly ONE choice for 26" off-road tires close to this width...they are $30. Not bad. (The bike won't fit the more common 26 X 2" mtb tires)
However, as noted, unless I were actually racing off road, the tires I have actually worked great at 35psi. Where knobs would help would be if I were riding in mud.
Quoted: 270 Post(s)
Regarding brakes, slightly slower braking doesn't seem as big a deal on gravel as it would on a road bike:
1. You aren't usually bombing downhill at 40mph.
2. A fall on off road is usually softer than a fall on road.
3. The fact that ita harder to stop your wheels should actually help on gravel, since you don't really want to lock the wheels up anyway.
Randomhead
Liked 3,699 Times
my gravel bike is pretty heavy, but nothing like that free spirit. I don't really notice, except I had to hump it up some stairs and that got old really fast.
Your location is in Indiana. Around here, braking is key to staying out of the hospital. I don't know about Indiana, brakes might not be that important. In central PA and much of the northeast, there are big rocks everywhere and falling off of your bike is a really bad idea.
johngwheeler
84
12-29-18 10:15 PM
WalksOn2Wheels
3
06-22-16 02:15 PM
Noonievut
15
07-15-14 02:52 PM
