looking for help achieving proper chain tension
Quoted: 11 Post(s)
I'm working on a singlespeed conversion project right now with a cannondale touring bike circa '85. I am very limited on wheel options due to the 126mm rear wheel spacing (frankly I would rather not buy new wheels as I'm trying to keep it budget anyway) I put on a freewheel, which then gave me an awful chain line. I then installed a narrower bb, to bring the outer ring in. After finally fixing my chain line, I have found out that the tensioner I was planing on using will not work because it pulls the chain outward (away from bike) (gusset, similar to rennen i believe). The bike has diagonal (basically vertical) drop outs. I'm currently using a sram PC1 chain. I'm going to try to use a half link, but I don't think that will get it quite snug enough. Anyways, I was hoping to find out some alternate methods of chain tension adjustment if there even are any. How do the non-horizontal drop out guys get good chain tension?
I have 2 salsa chain rings (53t and 38t) that I would love to exchange for parts or service contributing to the completion of my bike. I am located in the bay area.
Quoted: 11 Post(s)
since nobody bothered to answer my post, I will answer it myself in case someone looks up this thread for their own research.
I put on a half link, which then allowed me to set the wheel fully in the dropouts, with too much chain slack. At this point I loaded up the dremel with the aluminum cutting/grinding barrel and went to town. I would suggest this technique to anyone with an aluminum frame, and enough drop out room to cut away up to 5mm.
Riding Engineer
Bikes: Kiyo Kiyo Kiyo
There is something called, chain-tensioners.
https://images.google.co.jp/images?hl...title&resnum=7
You shouldn't be drilling frames whether it is tampered steel or aluminum.
T
T
