Moving from 16t to 17t cog chain length question
No Excuses
Moving from 17t to 16t cog chain length question
How much of a difference would that cog jump make with my chain length?
Currently, I'm running 46/17. I ordered a new cog recently and overlooked possibly having to change my chain length. Right now, the back wheel is near the end of the dropouts. Will I have to get a chain breaking tool at the local LBS, or will the cog jump make a small difference?
Bikes: Schwinn, Bottecchia, Miyata, projects
I'm not sure if you're going from a 16 to a 17 as the thread title states, or if you're moving from your current 17 to a 16 as your post implies.
If you're far back in the dropouts and switching to a smaller cog, you'll probably want to remove a link or two. If you're going with a bigger cog, that'll effectively move you forward a bit in the drop outs, so there's probably nothing you need to do.
Your cog is slipping.
Dude wants to move his wheel closer to his seat tube by switching to a bigger cog. But - as TT said - going up one tooth isn't going to make a difference significant enough to need to shorten the chain.
OP - you could always remove a full link and get one of these:
Kilo TT
No Excuses
Haha just realized I did that with the title. I meant I'm going from 17 to 16.
But yes, I was thinking about going to a half link just to make things a bit less complicated..
Quoted: 11 Post(s)
The OP is trying to change gearing and is concerned about the resulting change in rear axle position.
TejanoTrackie says that upping the cog by 1 tooth with move the axle approximately 1/8".
OP will not need to lengthen chain if he or she has more than 1/8" available space.
Questions?
Questions?
No Excuses
Apologies for the confusion but scrod is more or less right. I'm getting a smaller cog and am concerned that the chain will be too long to stay on the dropouts.
After all of your help, I realized ill most likely need a chain tool anyways and a half link just in case anything goes amiss while removing chain links
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
there is waaaaay too much thinking going on here. Put on new cog, see what happens. Easy right?
No Excuses
yeah but i was trying to avoid having to buy any more things and messing up. Ended up buying a new non-heavy duty chain that works with most chain tools available. Worked out very well and now the bike runs nicely with my new EAI cog
johnyguy
Road Cycling
19
09-20-15 03:57 PM
plowmanjoe
Singlespeed & Fixed Gear
9
05-20-10 12:05 PM
