Kickstand on Long Haul Trucker
Quoted: 18411 Post(s)
Liked 15,531 Times
Bikes: 1982 Univega Gran Turismo
Quoted: 128 Post(s)
Wow, this is super lame of Surly. They completely ripped off this guy's design. He's been making those for a number of years now.
Kickstand install | Long Haul Trucker Build.com
Quoted: 2236 Post(s)
Liked 1,314 Times
Don't know about that. It seems there are only so many ways to design the retrofit piece needed. Sure that guy didn't rip his idea from some other thing he saw somewhere, sometime?
If you gave engineering students the task of mounting two plates across two hollow tubes many would probably come up with the same sort of solution.
In the end, unless that guy planned to mass produce his product, it seems Surly has addressed an issue.
Quoted: 5888 Post(s)
Liked 3,471 Times
I've never figured out a use for kickstands; there someone had to say it.
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
Great to see, I will definitely get one when I get my LHT.
Only stubbornness keeps them from just telling The company that actually makes their frames, put a Kickstand plate on it ,
instead of the chainstay brace tube.
Let the customer leave off the kickstand if they wish.
I upgraded to this one..
you can actually make its length longer [try that with a hacksaw, have it grow back]
That guy who sells kits on ebay is using a different design. I printed out his instructions to modify to make one for my Fargo, though apparently LHTs don't have the derailleur cable going through that area. Doh!
Sad that Surly has changed its stance on kickstands *
*just kidding, having the choice is nice
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I'm waffling over putting one on my LHT now. Part of me says how nice it would be to just use the stand to rummage around in my bags and such, and the other part says no - to tough it out and live in defiance.
Salsa Another QBP brand leaves the Max Way shop with a Kickstand mount
Trek 520D uses the rear stand with 2 small bolts holding it on a raised Tab, so even lighter and right under your pannier Load.
Ozark Hillbilly
Bikes: Long Haul Trucker
Quoted: 136 Post(s)
Quoted: 2604 Post(s)
Liked 1,928 Times
Why, that would add at least $2 to their cost!
I'll admit that their original "don't use a kickstand" blog post had me questioning the LHT design, build, and quality.
Liked 1,928 Times
They can buy a different brand bike ..
I expect Maxway TW is the factory making Salsa, Surly ... And Soma for the 2 different importers..
it's what they do..
it's what they do..
They had a relevant point to make. Crank down on the chainstays and they will crumple. They also at least used to prescribe to the philosophy that touring bikes don't need kickstands. I honestly can't see the point of kickstands myself. Extra weight for very little extra convenience and substantial added risk to one's bike/gear.
Posted here was a Fix.. Plug the chainstay tube from the BB shell end , fill the tube with Epoxy Putty ,
that gives you a solid filled area under the KS, that will not crush, so easily..
