Vintage bottom bracket on modern bike
Quoted: 118 Post(s)
Hey so the title says it all. I have a specialised sirrus which I am converting to electric for my job.
However one of the problems I have encountered is that the pedal sensor thing requires a semi sealed bottom bracket and my bike has a sealed bottom bracket. So I was wondering can I take the bottom bracket off this old falcon I have lying around and pop it in or would I need to find a modern bottom bracket which is semi sealed?
Quoted: 4206 Post(s)
Liked 3,870 Times
Not enough info to say yet. First what is a "semi sealed" BB? Do both bikes have the same BB shell design/spec? Are both BBs the same design/spec? Other then fitting a sensor does the E conversion deal with the crank set or BB? Andy.
Quoted: 18377 Post(s)
Liked 4,512 Times
What do you need for the pedal sensor that your current setup won't work with?
What gearing do you have on the rear of your bike? 8 speed?
Square Taper on the crankset, or something else?
If you have a square taper crankset/bottom bracket, then a good many bottom brackets will work. Just match the threading (probably "English"), length of spindle, and whether the spindle is offset.
Your Falcon BB may work, but the spindle length or offset may be different.
IRD makes sealed cartridge bottom brackets that come apart, with access to the spindle in the middle if needed for something, and you can replace just the bearing cartridges if needed.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I'm with Andy in that I don't know what you mean by a "semi sealed" bottom bracket.
But answering the original question in a general sense, you can take the bottom bracket off an old bike and mount it on a new bike if the frames' bottom bracket shells are the same type/threading. For example, if the old frame and the new frame both have English threaded bottom bracket shells, you can swap parts. If one frame has an English threaded bottom bracket shell and the other doesn't, you can't swap bottom brackets. (Well, not without an adapter, if one exists for your particular combination of bottom bracket shell types.)
Quoted: 2338 Post(s)
Liked 2,822 Times
you may also want to see what the electric bike forum has to say also. And put specifics, like what specific conversion kit you are using
Friendship is Magic
Bikes: old ones
Quoted: 26420 Post(s)
Liked 10,380 Times
Semi Sealed Bottom Bracket Cartridge 115mm Bike Cycle Road MTB New | eBay
To the OP, assuming your old school replacement package of cups, bearings, and spindle meet the same specs as the cartridge you are replacing (threading, spindle length, end taper), it ought to be possible. But there are a lot of spots you can go wrong, especially if you end up with an asymmetric spindle.
HooKooDooKu
Bicycle Mechanics
11
08-14-13 08:54 PM
cycleheimer
Bicycle Mechanics
11
05-01-11 08:55 AM
