Pedal question(s)
Pedal question(s)
So I started with mtn bikes & used Time Atac pedals. When I bought my first road bike, I just put Atac's on the road bike and used the same shoes. Never saw a reason to change, and the Atac cleats are recessed up in the sole of the shoe so no contact when walking.
I just bought a new (to me) Specialized Tarmac from and individual and it had SPD pedals on it. I removed them and put on Atac's.
But...
Is there a good reason to try the SPD's? I mean, cleats are cheap for a try out, I just don't know what if any, advantage I'd get from the SPD's over the Atac's. IS there an advantage? Endurance? Stiffer? Better power transfer?
But...
Quoted: 1074 Post(s)
Liked 295 Times
SPD-SL - ”road” or regular SPD ”MTB”?
Staying within the family of recessed cleats - MTB pedals - I wouldn’t expect much difference between brands from a strict ride perspective.
It’s usually more about mud/snow clearing, ease of clicking in etc than actual pedalling feel.
Well, possibly if you’re one of those needing a certain amount of float not provided by the brand you’re about to try.
With good shoes I don’t notice much difference between road SPD or MTB SPD either.
But flexy shoes on MTB SPD can be a bit uncomfortable.
Can your shoes take road SPD cleats?
Humm, probably not. I believe they only have two mounting screw holes. SPD road cleats have three don't they?
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Probably no reason. There are more SPD-type pedals on the market, including titanium road. Just more common.
Results matter
Results matter
Liked 295 Times
By all means, try the other pedals. Cleats don’t cost much.
You might find you prefer the engagement/disengagement of one brand ahead of the other. Or the float. Or one might make better contact with the sole, offering more sideways stability.
Or something.
But unless one of these things have bothered you before, don’t expect a huge change.
LET'S ROLL
Been using using SPD on roadbikes and folders for a while. No problems over the years.
Tried out MKS' version of ATAC; couldn't get used to the entry. Plus the cleat sticked out
more; I could feel it when walking. Sold them after a while.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Uber Goober
I've rode a gazillion miles on SPD Road pedals. The stoker on my tandem had ridden about two gazillion miles on SPD Mountain pedals. I have yet to see a good reason to switch around. If you like what you're using, go with it. If you're tired of 'em or like the color scheme from Brand X or whatever, switch, and it probably won't matter, either.
I do note that it's easier to find sandals and winter boots for mountain pedals, if that makes a difference to you.
Quoted: 539 Post(s)
Liked 44 Times
"clipless" pedals being better at power transfer etc is a bit of a myth according to studies on the topic. There may be an advantage there for things like top speed when sprinting, that's kind of another argument, but clipless is largely about foot retention not speed.
If both are mountain bike pedals (2 screws hold clip on the shoe and there's room for tread on each side) it's just nearly equivalent competing models. I prefer Time Atac's, they shed mud and snow better than spd's. Both are reliable (unlike oldschool eggbeaters). Mostly it's just a question of what's available to you and personal preference in how they clip in and out.
I wouldn't use different pedals system on different bikes, because I find it mentally easier to ride when it's always the same system (though nowadays I use flats).
If the spd's are the larger "road" kind (3 or 4 screws to hold the cleat on, cleat takes up most of the width of the shoe with no room for tread on the sides), they have somewhat better foot retention if you're sprinting throwing your legs around wildly to get to the max speed. For most of us it's a non-issue though, and not worth the trouble of having 2 pairs of shoes that clip in and out differently.
Bikes: caad 8 c'dale , trek madone 5.2
Quoted: 36 Post(s)
When I started riding again I went with mt shoes and clips on my road bike . After about 1000 miles I got another bike that came with road pedals so I decided to try that . Got new road shoes and clips . I like them for the bigger contact area and stiffer soles ,and maybe lighter weight
. Walking around is not really issue for me because my rides are mostly non-stop . I think that clipping in and out is maybe easier with the road pedals but not a problem with either style . I make the motion that the lingo be changed from " clipless " SPD , SPD-sl to saying road clips , mt clips , or good old fashioned toe clips . Oh yeah , and then there is speedplay but they are mo money than i want to spend to try right now . But , bottom line ,for now I prefer road clips and pedals .
But...
But...
But unless you're looking to change, I'd stay with the ATACs. Less aggravation. No real reason to change.
Based on responses and the fact I have two-bolt Mtn shoes, I think I will stay with what I know and works, my Time Atac's. Can't see I'd gain anything, especially considering a new shoe would be necessary.
Thanks for all the responses!
