rehabbing mtn bike
rehabbing mtn bike
hi hive,
hopefully this fits in this sub, as it's basically mechanics. so i have a trek antelope (not sure on size frame) that i want to turn into a commuter. i was hoping some of you might give me some insight into specific parts i could use to make it a better ride. specifically, what wheels/tires are out there that might be better for roads? are 26" rims available that would work with hybrid skins?? the other thing i would like to add are fenders, and preferable road/hybrid style and not the clunky plastic mtb fenders. any insight as to ones that would work with the brakes on that bike (butterfly)?? thanks for any suggestions!!
Quoted: 4201 Post(s)
Liked 3,857 Times
Your answers are from doing nothing but riding the bike as is to whatever you want to change.
Tires are a big factor is the feel of the ride. Many will suggest smooth treaded tires with a flat protective belting. Retaining the full aprox. 2" width or reducing down to about 1.5" wide can depend on road/path surface and the load the bike will carry. I like the 1.5" tires. leave the wheels as is for now till you get more preference decided. In enough time commuting will likely kill the rear wheel anyway Fenders, rack, lighting, bags all yes. If you find a sleek 26" fender set that are about 45 to 50mm wide do let the world know. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1188 Post(s)
Liked 1,154 Times
Schwalbe big apples, SKS Bluemels fenders, job done
well, i had to get new wheels anyways since he old ones were pretty much shot and i was tired of twisting spokes to get them to stay true. plus i needed new tires, so that means news rims also, right??!! and a new cassette?!
also, since i got a new cassette i figured i might as well replace the crank, which also means a new hub. hahah, funny how i went from new tires and fenders to basically everything. keeping the derailers since those work fine and are in good shape. i almost, almost, popped on a new headset too, but i figured i would wait on that one.
i have a rack which is already on the bike and bags which work with that rack. do need to get some lights tho. as was rec'd below i got some sks bluemels fenders. hopefully they will work with the brakes, but i guess we'll see. i'm sure i can get a bit creative with the files if i need to.
if you can't tell i've been waiting and saving for awhile to do some work on this bike and now it's gonna happen as soon as a-zon delivers my stuff!! then i'll go to the lbs to find tires and get a new chain. i can't wait to get her in top shape again!!!!
That is a very good (albeit heavy) tire. If you wanted to save some coin, I think you can find Pasela Protites for about 1/3 the cost (I just bought some for $15 each on Amazon for example). Otherwise, if it has a compact chainring, I'd consider finding an old MTB standard (usually 28/38/48) and some friction shifters.
(tried to post of pic of the bike from a couple years ago but i can't till i have 10 posts.) oh well, i'll post back with some pics of it as i start working hopefully next week
Likes For travgott:
Quoted: 2338 Post(s)
Liked 2,822 Times
check out this thread for ideas https://www.bikeforums.net/classic-v...nversions.html
other than that..... clean lube. Biggest bang for the buck will be putting non mountain bike road tires on. huge increase in speed and efficiency.
and of course lots of lights
yes, that is definitely gonna happen. i need to de/regrease headset and bearings, and completely clean the der's. i can't wait till the weather finally turns and i can sit outside in the sun and start tearing her apart!! ahhhh, dreaming of bike work getting me through my workday hahahahah
Quoted: 1819 Post(s)
Liked 1,693 Times
I am not sure about this statement "twisting spokes" means. Wheels are trued by tightening or loosening spoke nipples. A properly trued wheel can provide sometimes years of reliable service. New tires do not necessitate new rims as long as they are not radically narrower than the ones they are replacing. Cassettes,(or freewheels which is what your bike may have) need only be replaced if they are badly worn. Wheels are a major expense when you are refurbishing an older bike. Be sure about what you have before you spend on something else. This also goes for other relatively expensive parts like cranksets. Unless your bike has mega miles on it(20,000+) your chainrings are probably not worn out
Liked 1,154 Times
And get your Schwalbes out of Germany, cheap as chips! The normal BAs aren't super heavy for a durable tire, but the green guards are.
haven't bought tires yet. gonna wait on those until i get it guilt up and then i'll go to the lbs for those and the chain. after that it's all about riding. oh, and maybe a new brooks!!!! black, b17, copper rivets, not that i've been thinking about it or anything
ooooooooooooaaaaahhh, parts are starting to arrive! i love that feeling
and the sun is shining, so maybe i can start wrenching later, idk
hope ya'lls are are having fun with your projects
got some nice weather yesterday and, well, here it is with all the new parts i've gotten so far in the mail. still waiting on the wheels. thanks for the fender rec, the bluemels fit perfectly with zero fiddling! new crank and hub. can't wait to get the wheels and fw put on, then i'll be pretty much done. reading those drop bar mtb conversion threads is making me what to do more :0
