More Brake Power needed.
Hey all, got an 05 base Rockhopper with the combined brake/shifter. I am over 215lbs and as I am starting to ride faster and harder I am wishing for some stronger brakes. Will an upgrade in just the v-brakes themselves to an avid single digit 7 or sram 9.0 give a lot of benefit if I use the combined shifter/brake levers or will I need to get a new set of shifters and brake handles to get real benefit? I do not have disc ready wheels. Thanks.
Throw the stick!!!!
You won't see a whole lot of a difference by just switching v-brakes.
Since you have combined shifters and levers you could always go to avid cable pull disc brakes. That will give you improved braking and save you some money since you can keep your current levers/shifters. The wheelset will still have to be upgraded though.
I may be fat but I'm slow enough to make up for it.
Bikes: 2000 Cannodale F2000SL, 2005 Cannondale R1000, 2010 Felt TK2
I just installed the Avid BB7 cable pull disc brakes on my bike. I haven't had a chance to ride on the trails yet, but just riding in the neighborhood, the brakes feel strong. A lot stronger than the CODA Expert disc brakes that were on there.
Time for a change.
Liked 5 Times
ALL "V" brakes work well, even the cheap ones if that is what is fitted to your bike. Badly set up brakes or maintained ones don't. Then there is the option of fitting an aftermarket block to your brakes, but that will now give you 500 choices as everyone has their own specific one that works and all others are crap. I just use the standard Shimano block and never have any problems.
Thanks for the advice. I try to keep them tuned up as best I can. I really do not want to fork out $150-300 dollars for disc ready wheels and a disc system, might as well save it up for another bike next year. I am just starting to learn what I like and don't like anyway so no reason to rush it. Besides, thats why I wear a helmet.
ODB to those that know me
Bikes: Gary Fisher Tasajara (undergoing a total rebuild), Giant NRS, Giant OCR C3
Are there larger pads available for v-brakes? Would that help?
Brakes are a waste, they only slow you down.
Sorry, I couldn't help myself.
Ankles Suck!
Bikes: 2005 Kona Stinky
UareFASTjustNOTfastENOUGH
Bikes: Scott Gambler, Scott Ransom, Bianchi C2C 928
You could get a set of these H33 Then you only need to get new shifters. They offer a lot more power then V's. I ran an older version for 8 years racing DH and I was 250lbs at the time and they had no problem slowing me down or stopping.
Other then those you will need to get discs to see a major differance in power.
Yeah but with mechanical disc I need a new wheel and at this point I figure every dollar I don't spend is a dollar better spent down the line. Brakes are uber important obviously, except for outdoorboy. If the only way to see a real improvement is to go disk then I need a wheel, or set, starts to add up quick. I am not cheap, I just hate to throw money at a problem if there is a better way.
Those hydrolic v brakes are pretty cool though, thanks for the link.
I'm in the same position as you...I want better braking but I don't want to spend $300-$400 (CDN) for the disc / wheel upgrade. Right now I have Avid Single Digit 3 that came with the bike.
The reviews of Avid Single Digit 7 on mtbr.com are universally glowing. A lot of people write that you get almost disc like performance, except in muddy or wet conditions. For $25 each on pricepoint.com they're a lot cheaper than discs and I'm sure will be much better than what I currently have.
I was lookng at the same reviews and was wondering the same thing about the avid 7's. I was almost hoping that the tree I just slammed into didn't just spin my brake shifter but broke it. Talk about taking the wrong line, I hit the brakes for an instant then just made sure I got both hands on the tree. Oh well, I might pick up something off of ebay, anyone have any advice on that?
though they are spendy the paul component v brakes have about twice the power of avid SD7's and are far nicer. though they cost 230.00 a very good upgrade one that helped me mout.
Knowing what the right thing to do is not the hard part, doing it is. I know I should just fork out $300 to get a decent set of wheels and brakes, but I have a hard time justifying that cost. I have found that I can usually get 70-90% of the performance with 10-30% percent of the cost if I gnore the hype and I am willing to put in a little leg work. JMHO. Besides, my ears would stop bleeding before my wife stopped *****ing about it.
Beside, thats what the point of this thread was, a good improvement without buying a new wheelset and matching brakes.
Originally Posted by outdoorboy
Those are cool! Anybody know how much? Just curious.
Well, I think I am going to look into building my own wheels. If I learn something while getting a better setup for disc brakes then I can accept the cost. That way I will not only have disc ready wheels but I will know how to do more of my own work.
Just set your brakes up properly, and spend a tenner on some new pads and cables. No offence, but you don't need discs. Just set up the brakes you have now properly.
I couldn't car less.
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Are there larger pads available for v-brakes? Would that help?.
https://www.jagwireusa.com/switchback.html Best made.
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
Who's the guy who's making a bike with 4 sets of brakes? 2 disc and 2 v-brakes?
What he needs is an endo button. One press and it locks up the front wheel.
Why Be Normal?
Bikes: 2005 Trek 4300
All v-brakes are NOT the same, and yes, you would notice a difference getting a quality set of v-brakes. If you are riding downhill for EXTENDED distances or ride in primarily sloppy conditions then yes, disc is the way to go. However, a decent set of v-brakes setup properly can offer outstanding stopping power.
https://www.bikeforums.net/showthread.php?t=120415
I have nothing at ALL against disc brakes but personally feel that 80% of the riders that have them don't need them. More than you'd think have them for "coolness" value rather than braking power. There's nothing wrong with buying them for that reason but if money is tight or you're trying to spend as little as possible it simply doesn't make sense to drop $140 on brakes when your riding conditions doesn't merit it.
Just my $.02.
Just my $.02.
