View Poll Results: which finger do you use to pull brake levers?
index finger
12
13.19%
middle finger
6
6.59%
index & middle fingers
68
74.73%
middle & ring fingers
5
5.49%
Voters: 91. You may not vote on this poll
How do you STOP???
Bikes: Santa Cruz Juliana & Gunnar Roadie
How do you STOP???
Please help mediate a tiff between my riding pal (and teacher)...
i am female with small hands (not miniture but glove size is small and the fingertips rarely reach the end of the gloves) just got a new set of Magura Marta hydros (just a little side note: the gloves i happen to be wearing are winter type gloves with no little grippie things on the fingertips...will take care of this issue immediately!)
so i say to my pal "my only complaint with these brakes is the lever is SLIPPERY! and they may be a tad too far away" now...supposedly they can be adjusted but we have not messed with that yet...here comes the tiff...
while saying this i was showing him how my hands fit...i was using my middle finger to pull the lever. he promptly corrected me saying i am supposed to use my index finger...which is not long enough to stay on the lever on bumpy/bouncy downhill sections and it is just not comfy!!! my question to you all is "what finger/fingers do you use to pull the brake lever?"
thanks...and if i am wrong i chalk it up to being a noooobie
Still kicking.
I use index only, but two fingers are easily acceptable.
Appreciate the old bikes more than the new.
Fourth Degree Legend
Bikes: 2005 Kona Cinder Cone & 2010 Cannondale SuperSix
i use my index and middle together. it's just what is comfortable for me. i don't know that there is a right or wrong... just what works best for you.
eert a ekil yzarc
Bikes: many bikes
Asking which finger to use might give you the wrong idea. I can palm a basketball no problems, and still use my index and middle fingers. Its a habit from when I'd go dirt biking or three wheeling as a kid.
You mentioned that your levers are slippery. Put some sports cloth tape on the levers. I use the stuff in the winter. Yes it gets dirty, just change it out so often.
Bikes: '05 Yeti 575, , 01 Cannondale SI1000, 03 Felt F65, 07 Tarmac Pro
Here's another for the index only. But like's been said, whatever is comfortable to you is best. For me, my hands are cramping just thinking about using the middle finger only It's also a good excuse to give the finger to everyone ahead of you.....
Dean
Dean
one less horse
I typically use index fiinger only. If I start to get arm pump, I switch to middle only for some temporary relief.
Any of the first three options listed are common. Whatever works best for you is acceptable.
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
I ride with the index on the front lever, and index and middle on the rear.
Emondafied
Bikes: See sig
Quoted: 63 Post(s)
Hmmm, now that you've asked, I have no idea which fingers I use. I do for road, but not for mtn.
I'll have to hop on the bike when I get home and see what feels right, then I can answer the poll.
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 -AlpineStars Al Mega
Whatever is more comfertable! The muscles in your middle finger connect to your forearm muscles better, and thus stronger. In rock climbing, i was told to use my index finger and ring finger more because of this. You might get less fatigue doing it your way, since it is more comfortable. But personally, i use my index and middle for both hands.
With most levers(not sure on hydros though), you can adjust the lever inward(starting closer to the bar) if you need to. You will probably have to slacken off the brakes a bit. There should be a small screw at the back of the lever that when screwed in, pushes the lever. Basically you are taking up some of the lever travel though so you don't want to go too far and not have enough brake.
I like your user name. ;p
contrarian
Bikes: 80's ross road bike/commuter, 80's team miyata, 90's haro mtb xtracycle conversion, koga mitaya world traveler
Slowing: middle finger. Actual stop : index and middle.
Higher ground for the apocalypse!
Bikes: Too many to list!
I use only my middle finger to brake, and wrap the other 3 around the grip. I usually leave my middle finger laying on top of the lever when riding. I feel that this method gives me both a great grip on the bars, and immediate access to the brakes. Try it, you may just like it!
Lost in the Black Hills
index only here
Tomac Mountain Bikes | Light-Bikes l Magura USA | Industry Nine | Schwalbe Tires | Caffélatex
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
Index and/or middle depending on whether I'm trying to shift and brake at the same time. I'm using hydraulic discs, so I tend to use one-finger braking most of the time, whether it is the middle or index. Just do what feels right, and adjust your lever so it's easier to reach.
Bikes: Check signature
Index or if I'm doing some hard downhill where I need lots of braking then index & middle. Just middle feels weird as hell...
SNIKT!
Bikes: '06 Kona Dawg Deluxe/'06 Cannondale F400(frame)/'98 Cannondale SuperV1000
I like pie!
"The bright flicker of our television screens is the stolen incandescence of a thousand young minds." - Theodore W. Gray
"you taught us to fish while so many others were handing out tuna sandwiches" - Ziggurat
I like pie!
Bikes: 2004 Giant Iguana 2005 Specialized Enduro SX Trail
I have always used index and middle. I don't feel as secure if I only use one finger.
Bikes: Devinci Guzzler, 04 Canadian version
middle finger only for better modulation, unless Im in " uh oh,oh crap" mode then its all available fingers. I dont have small hands( XXL glove with fingers touching tips ). when I had cable breaks I used 2 or 3 fingers but since switching to hydros the "bird" gives me the best modulation to strength ratio and is most comfortable
Karldar your avatar is way cool I say once more
Bikes: '06 Trek 4500, 2004 Trek 4500, 1998 Diamondback Topanga
I usually use the index and middle fingers, but sometimes on light braking I use just the index.
Bikes: specialized hardrock
I use index,middle,ring. That's just how I do it for some reason, I'm surprised some do it with just one finger.
Bikes: 2006 Fuji Roubaix Pro, 2003 Specialized Stumpjumper FSR
I use the middle and ring fingers, don't know why, guess its just what is comfortable.
SNIKT!
Originally Posted by Siu Blue Wind
I use my index and middle to rest on the lever. I guess it's from my motorcycle days of always covering the brakes.
I like pie!
I like pie!
