Brake Pads
Roam
Bikes: 2003 Jamis Aurora 2013 Surly LHT 26" wheels
Brake Pads
What is the difference or what is better, the one piece brake pads like Kool Stops Eagle 2 or the cartridge refillable type?? I'm looking at Tektro's Oryx cantilevers and I've seen them with both.
Quoted: 128 Post(s)
Liked 12 Times
Kool Stop Salmon-colored pads use a special rubber compound that gives better stopping power. Black-rubber pads work fine too, just not quite so well.
"c" is not a unit that measures tire width
robhunterx
Bikes: Litespeed Ultimate/Kestrel 4000/GT Rage/Litespeed Unicoi/Litespeed Obed FS
Kool Stops are much 'kinder' to your rim braking surface. I'll never replace with Shimano pads again (but I still have a few on some of my other bikes that I will use until I see a problem). Just curious.......is Jagwire the same as Shimano? I heard that somewhere but I'm not sure.
Quoted: 2026 Post(s)
Liked 1,096 Times
I'm sure the Kool Stop pads of the same color are the same composition no matter what format they come in so either the shoes or cartridge refills will work the same.
Jagwire is a Taiwanese company. They may subcontract some components for Shimano.
I couldn't car less.
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Cartridge holders are the way to go for rim brakes. I run soft\wet compound front and black rear as I just drag the rear lightly\more often. Jagwire Tri-zone are probably the best pads made, better than red kools.
Mind you, my Jag wet block pads lasted a really long time. Slightly more carbon than kool reds, less than black.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
I prefer the cartridge pads because it's usually cheaper to replace just the pad.. I'm using Kool-Stop dual-compund salmon/black cartridge pads.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Bikes: Klein Quantum Pro
Check out Swissstop pads. Click here for a review.
