Need a new bottom bracket
Bikes: 2002 Giant OCR 3, 2003 Giant OCR Elite, 2004 Giant TCR, 2004 Giant OCR Touring, 2003 Giant Iguana, 2004 Cannondale Ironman 800, 2005 Giant Trance 3
Where can I purchase just the bottom bracket? I am in the process of constructing a velomobile and need just the bottom bracket for the crank. I know I could buy a bike and cut it off to use, but there are few bicycles around in my area at pawn shops.
Would this be what I am looking for and it so, what size would I need to get? Thanks
Quoted: 453 Post(s)
Liked 104 Times
Your link isn't for a bottom bracket, but the center section of a HT2 Bottom BRacket.
You haven't said what type you need, there are Square Taper, Ocatlink, ISIS, HT2 and many others, you need to be more specific about your needs /type of crank you are using.
You have listed you are in Nashville, just Google searching brings up 7 bikes shops in Nashville; have you tried any of them?
Quoted: 2026 Post(s)
Liked 1,096 Times
Are you looking for a bottom bracket (spindle, cups and bearings) or a bottom bracket shell, i.e. the part of the frame the bottom bracket screws into? If you are looking for a bb shell, a local frame builder should have a source or look at the "Frame Builders" forum here for recommendations.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Probably simplest if you get one with English threads. I can't tell if that one's threaded or not.
Edit. 68 mm, English thread is very common.
Yep. So far, I have gotten the back axle connected to the seat, lower, and upper booms. I am waiting on the suspension springs, wheels, and now the bottom bracket shell to arrive before I can continue.
