Omnium crankset installation question
Hi. I tightened the 8mm hex bolt to the torque in the instructions (48-54 NM), and now the bearings are really stiff. When I try to spin the cranks, they move but they don't spin freely. Is that normal? Or should I just tighten them until they feel right, like with any other bearing assembly? Thanks.
I figured it out. It's because I was using a spacer on the drive side. My new question, then, is if it is possible to adjust the chainline with this crankset.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
one you shouldn't have to use a spacer unless your frame is weird
two the torque is a measurement of force not depth
three the bearing seals are extremely stiff on these cranks until you put a few miles on them
four try it without the spacer it will probably work fine
That's true, but I'm too neurotic to ignore it.
The omniums are designed so that the left crank arm butts up against the splined part on the spindle, so I don't see any way to use a spacer without putting too much pressure on the bearings.
Your cog is slipping.
Best of luck with your neurosis.
Still kicking.
That is the one advantage that I hadn't considered about square taper cranks, being able to change the chainline.
Still kicking.
It's the reason I won't run a truvativ/sram crank.
You have one size bearing in one cup, a different size bearing in the opposite cup, on a fixed application if you are a bit of an animal on the cranks the gxp setup will last 1/2 as long as a good quality square tapered setup. If you are lighter on the cranks it will last the same amount of time as a comparable setup, sugino 75/DA Track/Record Track.
Appreciate the old bikes more than the new.
