Solar panel + external battery
Hi!
I dont know if this is the right forum to ask this question, but anyway...
Im wondering if it would be possible to charge a Anker Astro battery( https://www.ianker.com/product/79ANS1052-BA ) with a Voltaic solar panel ( https://www.voltaicsystems.com/6wattkit.php ) without damaging the battery?
Thank you!
Thank you!
Hi!
Thank you!
Thank you!
Quoted: 3458 Post(s)
Liked 1,465 Times
Looks like the panel output is slightly higher than the USB standard of 5V 1A. But as long as the USB port on the panel does not go over voltage, should not be a problem. Once the battery is full, it should stop taking more power from the panel. Due to the higher rating, I would not directly connect an expensive smartphone to it, but I often needlessly get overly cautious about that sort of thing.
I recently bought two panels at 2.4 watts each that I plan to use to charge similar batteries.
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
I never had much luck charging USB batteries directly from my solar panel (GoalZero Namad 7). The panel's USB port only provides 5V in optimal conditions and with lower voltages most batteries won't charge. You're best off with a battery designed to charge off the solar panel like the Voltaic V39.Personally, I'd suggest a dynamo hub but if you go with solar make sure your batteries will accept a trickle charge.
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 98 Post(s)
Liked 24 Times
Considering Voltaic V39 with either Voltaic 6w panel or the Goal Zero Nomad 7 panel. I don't suppose anyone has experience of using both together?
Thanks
Andrew
Thanks
Andrew
Quoted: 659 Post(s)
Liked 7 Times
solar panels generally..
.. may have to sit in one place in clear sky and keep chasing the sun angle as it moves across the sky
moving the panel, to keep panel perpendicular to the sunlight.
To hope to achieve the watts in the panel specs.
Bikes: Surly Ogre
Quoted: 19 Post(s)
I have tested the Anker Astro 3e 10,000 mah on my hub dynamo. It appeared to be working with the lights blinking. But after 8 hours of biking it still did not have any charge within it. My USB adapter is 5v 1a. I have also tested the Mophie Juicepack 4,000mah, which didn't work.
Unsure how much charge I can produce within 8 hours though, 3,000 mah possibly? Maybe the Anker just needed another couple hours to get over the edge.
Bikes: LHT + FreeRadical
I hacked together a usb solar charger for about $70 using this instructables as a guide (link). I did swap out the LiPo charger they recommended with a new product (link) from SparkFun that's supposed to optimize your solar output in non-optimal conditions. If you can solder (anyone can) you can do this on the cheap. Parts I used:
0.45W Solar Cell (link)
Solar Charger (link)
2000 mAh LiPo battery (link)
MintyBoost Kit (link)
The Instructables says 20 hours to charge the battery with this setup. You can spend a little more money to get a larger solar panel that will significantly reduce charge times - anything that sparkfun sells will work. The Battery is roughly the same size as your typical smartphone battery.
ghost on a machine
Bikes: Rivendell A. Homer Hilsen, Serotta Colorado Legend TG, Rivendell Roadeo, Surly Cross Check, Surly Big Dummy
Quoted: 7 Post(s)
I loke the Bushnell Solarwrap Mini. The battery doesn't have the capacity of the Anker but the solar panel is integrated and the whole thing makes a small package. In fact I carry two of them when touring, one being charged via the solar panel and one being charged from the dynamo hub through a converter while riding. Cabelas sells them for around $60.
