Raise saddle after moving it forward?
Quoted: 6556 Post(s)
Liked 58 Times
I keep looking for the answer to this question, but all I can find is the reverse: the need to move a saddle forward to maintain knee position after raising it. That is not what I am asking. I want to know how much do I have to raise my saddle after moving it forward (for whatever reason). I'm thinking the reach to the crank will have been shortened as the saddle moves more directly over it, not much but some. Anyone have a formula for this? I moved my saddle forward 1 cm.
I did a really quick and dirty approximation that suggests the amount the saddle has to be raised x is about y(cos theta) where y is how much I move the saddle forward and theta is the seat tube angle. Assuming 73 deg I get roughly 0.3 of the distance moved forward (or backward and lowering the saddle). So for my 1 cm change, I would need to raise the saddle about 3 mm. Not only is that a very small amount, but my seat post is stuck, so I will likely ignore it for now. At least until I decide if I like the new knee position. I know the saddle height will affect this, but I will work it out as I go.
Nevertheless, I would be interested in hearing what other folks come up with.
Thanks.
Robert
Thanks.
Robert
Redefining Lazy
Bikes: 2013 Cannondale Synapse 5 105, 2013 Giant Escape 3
Quoted: 13 Post(s)
I do saddle adjustment by feel.
I do use the rail #'s as a reference, but mostly it's a lot of times in and out of the garage with a hex wrench.
S
S
Portland, OR, USA
Bikes: kona paddywagon, trek 2.1, lemond nevada city, gt zrx
id start with a baseline height using one of the popular formulas. i use the lemond formula (inseam x .883) to determine initial seat height (distance from top of seat to middle of bottom bracket). get that set first then do the fore/aft set up. feel pressure in front of your knees? move the seat back. feel like you are sitting on the narrow end of a 2 x 4? move the seat forward. make sure seat is level always. tah dah....
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6766 Post(s)
Liked 5,479 Times
I thought the OP was the authority on bike related matters.
Falls Downalot
Bikes: Now I Got Two
Quoted: 5 Post(s)
Are we supposed to be applying math to this question? If so, then of course I am of zero assistance.
However, I will rehash my Retul fit experience, wherein my saddle was moved one inch higher and almost an inch forward, resulting in optimized measured power output (still quite low by 41 standards). Therefore, according to my scientific sample size of one...ipso facto the ratio is 1/1....
Falls Downalot
Quoted: 5 Post(s)
Make the adjustment then post it in the "Hot r Not" thread. They'll tell you exactly the adjustment you'll need to make.
Quoted: 2952 Post(s)
Liked 3,106 Times
Rather than get out my TI-30, I just use a tape measure and measure from the center of the BB spindle to the center of the saddle rail. As I move the saddle forward, I have to raise it up so that it's the same distance.
Liked 58 Times
Artificial Member
Liked 5,479 Times
Not really. Just was surprised is all.
Liked 58 Times
Sure, the empirical method should have been obvious to me. I was just wondering whether there was an established formula for this that soneone could supply
Artificial Member
Liked 5,479 Times
"established formula" = x+y-r/2
Liked 58 Times
Liked 58 Times
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
STA is less relevant, as seatposts have offset. I would look at it as c=√(a²+b²). C is a constant, your leg extension, which does not need to be solved, as it will be the same before and after the change. If a is vertical and b is horizontal from BB, you now have √(a²+b²)=√((a+∆v)²+(b-∆h)²). Square both sides, use foil, and solve for ∆v.
Artificial Member
Liked 5,479 Times
Congratulations.
Now lets do the ceremonial cleaning of the chain.
Liked 58 Times
Speechless
Quoted: 163 Post(s)
Liked 39 Times
If you are going to use angles, I recommend switching to radians. If I get a choice, I love talking about pi rotating around my crank.
Liked 58 Times
Liked 3,106 Times
Speechless
Quoted: 163 Post(s)
Liked 39 Times
I'll second the motion provided you support my campaign to have "Iron Alloy Appreciation Week". I am still working on a pithy slogan like "Steal a moment for Iron Alloy" or "The irony of Iron Alloy" or "Iron Alloy: it is your father's alloy" or "Available for Centuries for centuries".
Speechless
Quoted: 163 Post(s)
Liked 39 Times
That looks completely correct. Is it not true that the trig approach I used inherently incorporates the formula you provided? You're right about the lack of need for using the STA, but I wonder if the use of it, just as an approximation doesn't simplify the whole process.
Liked 58 Times
Liked 58 Times
