83 Bianchi Single speed build
Bikes: Giant TCR C1 - 16.5 lbs
Quoted: 13 Post(s)
Background:
Started with a low-end 83 Bianchi frame. It came with a after market steel fork. Based on suggestions from experts here about the quality of the frame, I decided to go with single speed build. I was able to install the Shimano UN-55 english 68mm x 110mm.
Making a slow progress. I've couple of questions:
Installed fork, headset and handle bar
frame with wheels
initial fit - Apr 17, 2020
Top view
Top view with slight angle
- Is the 110 mm BB right size for my setup? Look at the top view picture. I assuming that Crank should be in a straight line with the rear sprocket. Could you please assist me in how to align those? Please let me know if you need additional pictures or measurements.
- What type of brake lever do I need?
- Seat tube is 25.9mm and the seat post is 25.4. What's the best way to install? I'm afraid that Seat post would break, if I tighten the bolt,
frame with wheels
Top view
Cool, build. That will be a very rewarding ride once you're done with it! I dont know much about single speed set ups, so I cant help with the chain line alignment question.
As far as the seatpost diameter, I would highly recommend sourcing the correct post for your seat tube. Seems like a strange seat tube size to me, but if your post is too small, that's better than too big. Every once in a while in a pinch, I have used strips of aluminum cans as shims to help fill small gaps for equipment that is a few millimeters difference, but I dont know that I would highly recommend it, and I'm not suggesting that you do. Not as a permanent set up anyway.
One other thing I want to add is I've used the 3ttt version of those handlebars that you're using and it is EXTREMELY difficult to route the brake cables through those bars. Ive routed those bars twice and both times took several hours and several rounds of cursing and swearing. Although, I was routing with the shifter cable as well, so maybe you wont have that problem, since you just need the brake cable through. That being said they are some of the most comfortable bars I've ridden.
The Sram levers should work fine, you will have to get them right up to the holes in the bars to get them to fit right. Also, it looks like you are using a front brake mounted to the rear. You might want to mount it in front, as it seems to have a long enough bolt on it and it will give you more stopping power. Use the correct nut on there too, to mount it. The fork will probably take a recessed nut since it appears to be more modern.
Good luck with the build, and have fun!
Likes For celesteguy:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The right bottom bracket length depends on the crank brand/model and application. If you're going to use the outer ring of a double crank on a fixed-gear/single-speed, you'll want to use as short of a bottom bracket as you can get away with. For example, my FG uses an old Sugino GLP crank, and the chainline is almost perfect with a 103mm bottom bracket. It can take trial and error to get it right, good thing Shimano and Tange bottom brackets are inexpensive.
Here's how to measure chainline: https://www.sheldonbrown.com/chainline.html
Likes For ThermionicScott:
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
I'e never been a huge fan of measuring a seat tube with calipers. See if you can find a shop with a set of sizing gauges.
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxATEhUSEhAVFRUVFRUVEBAYFRcVFRUQFRYWFhUVFRUYHSggGBolGxUXITEhJSkrLi4uFx8zODMtNygtLisBCgoKDg0O FRAQFzcZFR0rKy0tLS8tLSstKy0tKystLS0rKy0rLS0rLS03LS0tNy03KzcrNy03LS0rLS0rKysrK//AABEIAJ0BQQMBIgACEQEDEQH/xAAbAAABBQEBAAAAAAAAAAAAAAACAQMEBQYAB//EAEUQAAEDAgMEBgYHBgYBBQAAAAEAAhEDBBIhMQUGQVETIlJhcZEyQoGhsdEHFBVTksHwIzNygrLhFhc0Q2LxwiREg6Kj/8QAFwEBAQEBAAAAAAAAAAAAAAAAAAECA//EACERAQACAgEEAwEAAAAAAAAAAAABEQISIRNRYYEiMUED/9oADAMBAAIRAxEAPwCyCMIAjCjQgiCFoRgIFARJAiAUChEkARAIORBcAihAiIBcAiARSJYSgJYUCJYSwlhAkJQEsJYQJCUBEAlhA EJYRAIsKAIXQjAShqBohJCdLUMIBhdCOF0IGyEJCcIQkIhspETkBRSpYQgo2hEAQgIT7mpshUNQkIThCGEAEICnSEBCAVyVKggBG EDU61UKEYC4BG0KBAEaUBEAg4BEAlARAIpAEUJQEcKAISwiwogEAhqIBLCIBFDhSwjhdhQDCWE4AlwoAAS4UYaihSw3CUNRSOaXE NM/JAEJQEYaTo0oxb1Yypz3ZpQaLU2WqbQs3uaHS0AgEEwMj4pz7NHGq3zB+CtCuhCXDiR5pzaFtSaW/tMWLIgTIPDXy8kyyi0kBrHGdBzjlzWtUCare0PihNUd/krKls+odLc+JgfFS27LuD6jG+0H4JqihzOjSkFCofUWmp7IrcajR4CUrNlAtxmuSImQOA1V1gZsWVXkEbbN/F4HktBTsbaJL3HSc8szAzAjVP07W1JhrcRzjN0Eicp9h8ilDLutDxq+X9kH1NnF7itPSr24AikwugHC2HQTENMgdaTpyBKfN7hLR 0EYjhaQDmc4iG8mk5wIjPlaRlmbPafRa+ecFR6tFzTDhBC2Au7iC7ogANQTBMBxMGcvVHHMk5hU+3KgeKb8pdTa5w4h0Zgjhr7km C1EQgITzk2QsKBciXIKxpTzFGa5SKZQPtCdaELE80IEASwjAREKKEBEAmzXYNXD4pDes7z7ED4CMNUJ1+ODT5oXbQdwAHilSLDCi AVQ7aDj64HhCaFzOrnHzKsYyWvckJrMHrBU1OoT6NN59nzT31W4JEUSNYJOWhPDwV6cpssTds5z7En1vk0/BQtn2lxVcGtLWyJ9E5DLWTlMyMs1fW+61U+nXPeAAPyV0NldTrvM9UCDGZTzD2qjW+0J6/2DSogufVBGI5uLswKZdh6umbTnnwyOistgbHtn0g80Wl0mSRI1MQdHZRmMj3aK6wWpLq5tw0xXDnZGBOgInu0Uuld0PVo1ncuphB PjC1A2ZQALRSYAQQeqNDkVV3eCcTajGy1tRodUIkADrPpQcYGActOGZUqCzNMVD6Nm7xe5c+hdBxcKFNowGQOsThzEDnmVeu2hRA k1WRwOIKFdbetAINZpzggZ5HJVLQ7OnXqEjpWgCMwzxECY5a6KcNku9au8+EBUdvvdbtfHRvwtlrX4pOGcuqTxgZ/JO1t96I9Gm4+JARblIrbGDIDXEyXDPERmcQnDoQJA8Z7lY7O2fSDGk0hiiC5zcyRlig6TE+1Ye/31qvc5rGhgOEiHGcpBzEd3kENpvhXYzCCCZmXCc/l8yhy9BvbdmA9UZdZsAek3rD3hVbrmgyqCC1pBnq0x6LgCA5zpMdeerGvisZcb33TgRjAnLIAaqlstoVXU2nETAwTxhpw/kkUlS9lqXlJvpVGDxcFGq7atm61mewz8F5Kaj+Lk1jPaV1Snpo3jtWYprF0mcmEcAOPh71BZvZa0xDG1HaZE8gBOZPABeeOeOaFz wrQ2z97qIPVt5zmXVHOMwBqfAJl2/Dx6FKm3lA5ZDisX0oSistUNXV30ujo4DwaFCrbx3bv913nGfsVK2uudcAcVaROrbQru1e4+0qw3fqOLziMjCcu/JZ03jeas93rwdKI5FTKOCPtfFNlOOTZXBsK5KuQUQcnqbzwaSoAetBb7r3T3BpeWSSMWHIBuKXSBpLY1nMcDKsRYYbcO5Dzn4JKl 44auA93xVq7cmk399tHxE/N/5KHtHYuzqLQW1nvdJkBocfRdGRgagcc9OMrUYQlq1+0B975Gf6U065GsOd7D+au9n17FrAX05diOvVETlAJ0jnmnbzeS0axwYymM jlqunThnZSUm1CYDM5AidCZiY00KnN2VcawB5qPW3np9LjxRhcS0NYB6RkjFOYPeEdffNp0Y73AKxjhH3KTOX5CZV2JVa3GXiJa3 MxDiY/NJs7ZlN4cXO0Iyk6EA+BHIjVUV5vTUeC0NbBGYOYMGcwVFbvHWAgOawcmgBLwhazlt6OxqPZlJe7PYcqLBhLQA5zgBHWBBEg8tJO U5Rngn7x1fvj7CoFTaOL0nOOZ4qdTH8hqP55vYRfW7AMVWk3mJBz4qNcb02jYitOYkAH0SYMd68jdft5HzTdTaAgwP0FJ/tM/UL0fL0S03ltKdXFhrVDpjc5umnqiYy4njOqnv+kBg9G39pK8u+vnuXfXj3LE5zP4vTh6Bfb71nl2BrWEhkECYwFx9YET1uXBM2++ N4AQ6tizmcLfLRYJ98cQOLgR8Pki+0h21LkrFs6+8l04513xyDiFUtuS8dYzBLcz2XGNfE+azztrN7SjM2qBizObpHtATlfi1wrn te9NXF0A09bTNZf7WB0BKB968ggUz4qUuzVOvGDiU07aDeSz4uKp9VIOmOpV+MFyt6m0P2gyHouHvC520Xdypn0Hy0zz94/snfqruabYwRawdfntJdk3nUInSo/8Aqn81AFoUFtTcC8Dt/ENSP6QmUWvTfDNMPvwq/A5CaR5q9VnVNdfJp96eajdCuFsToCVN5NYOm8PNJ9c70rdmVTpTd5FRL4CkYf6XYGZHjyS8ioSTeoHXZVHV2q+YbTB7pP5K82GKd ZpLiWOES2MQM8Qfmpchv6w5Wu7VVxrtE5QZ8vnCcOzKXBzj/LH5q63f2SGnpIgerPFZmZlWgJQFKShJRHJUK5UZeVXV9vVHOLo60ziJMyZ48fSKnkrC3l09r3NnQkeRVxmY+iYj9aV+1ax1eo9Xa Lic6h81l3XbuaA3HetfLufFo33o4kn2pp9+2FQGuk6Ypr5XaOy8+0hqgdtI8yqVtRyMBxUqDefyFm69P6KA3nh5qH9XfE5wpdLZR 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 8msd8UzW2xTiKezqbe91SrUd/UB7l3RoTTTYoydq3B9GlSZ4Uwf6pQm8vDrWI/hhvwUgMRBim0lIgZVcevUc7mC4qY+jRc1w6BuJ0dfUiJ7syiDUbQlyUgU9kU+/3D4BWuzbNjTk0CTJ7z3pGhTrJmagvrOgyPQb5BSimLXRPlVDTkiJyBUclQpUGSrFYfeGkRWceDgHD4H3hbWsVR7UtGvgnKJz7ipE 1JTJYEuBXT7a3aM3+WZjwnVCbvZ7RpVeeUtZ8MRXSOWVWKafp0ZUtm3LVo6tkHHtPe4jyGH4pW701R+7oUGfyNJ/+4cnCmqNqZOR5iBPcriz2PcPjBbVXTocB/JVj96b5xB+sYSJw4erE6xhIAUS52hcVc6ty93iZ/qlThWtqbuXAEVDRpTkekr0mH8LnA+5DT2fTDZqbQt2RlAFV7ssvVYR71kQ0HV5P83yRso0+Tfilx2VrKdxsxv7y9rPM+jTpNA8y+ fcgqbY2YCMFrc1YOrqwbI8BTy81nmYBy9yea9vMeam3gpef4kogg0dl0hHGo6o8+2Xx7k8N8b0fuqdvR/ho0gR/Nhn3qha9vMJwVW8x5ptK0tKm8W03zN7VAJkhr3ActAVXVKdR5l9Z7jxJcUrao5jzRis3mPNTaSjbdns4yfEp5ljTHqj25ohWHMea MVhzHmoUcp0WjQDyTwYmBWHMIxXHMKB4NRgKOK7e0PNGKze0PNA5CUBNGq3tDzRCo3tDzRTkLgg6Rvab5pDVaPWHmoHSFwTXSt7Q 80oqt7Q80DwQuTYrs7bfNc+qztjwz+SAwllRn3DBq4JPrbO18U5RKlKHKGbpvaSi4bzTlVlScrWzaqG2rtnMq9srhnP3H5JDMru2 0T5UOjds5+4p1t2w5YltBlAU4UBQCuXJUGNrKsuirGuVWXKxLUKepbue4hrZMTkmDspo1ozK02697TpVKrntxYqZa3LjIn3Ze1a2 y3jtRmaYaeOWKdYz9p1Xf8AlhExyxnLy1uxmTJtz5lSKW77Nfq5z0ku09i9cZvZacj4Yf7KFfbz0XVC5tJhBAGYy45ACO0dZXScI 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 mZ4xGQTtzvNSOAiXFuMDESIBeCx4IzLgGxwmTnzaFnmbtVeNMebfmlO7dT7v3tUBu9T/v3iNB1TJDXTJLeL8J7hITDt7apEB7pz6xwzMZGIgZ56HQJ0zZIvbB1IwRHdy7lEKmV9rNr4oc52Fres4QZmCTGXHgoZXOYqaaIuX JVBia4VbcBW9VqhV6SzMNQzte4NN0jiD8Qg+1nJd4qJAa7vIPtEj+lUWJbwqknJoBtYohtV36Kz7XJQ4rXCbS0H2q79FF9pmRr5r Pgnmik81eDeWg+1Hcz5pW7VdzPmqATzRNaeanC7yv27VdzKc+1ncys/TpuOikNsah/7UuF3ldja7ss1Ip7YPNZ87PeInmB55J0bMfzUvE2lft2y7mEVPbDpOY4fBULdmO5lEzZzpIk5R702guWjbtg8x+vaiftgwdND+tV 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 x9k2vaP69iX7Jte0f17E/0a7o0soI2Xa9op1lhbD1knRpRTQoVKzoAmHxnPDxUjoaPbUXo0vRIp6tRpR6fEH2go+ipfeKOKaIU1BIayl94ubTpST0mse5MdGl 6JBKDaf3iVzacfvOCi9Eu6JBNY2n94EWFn3ig9Eu6JBMLGSP2g0PHwRhjfvFA6MLuiQTwxn3iGmGxGMalQuiSdEoLA02/eBNYQfXGvuUM0knRKiw6NvbCA029sKF0S7okEwUW9sapOib2wofQpDRUEqrbAjJ4/soPQk6Qj6FJ0AVAi1Pckq0MLS5xAA14+QTnQomUyERlL/bVQegzCObhLvHkPeolptW4c4DHPOWtj3BbqrQDwA9oIGgwj5IKWyqAMiiyeeEStTMJSJRtnPYHRE8Pl3IXWTlq9m27eIBV3QtqYz wNnnAWVV+6uzDSplzh1n+5qvJQFy4FVB4lyCVyoo4QPCdQPVEOqFBrBWNQKJVYpKoWFNuapfRhC6mFFRcKWE90YS9GEDMJYT3Rru jQNQlDU7gS4EDQCUBO4F2BQNgJYTmFLhQNwuhOYUuFA3C4hOQuhA2GpYRwuhQN4V0JyEkIGyEmFOkJIVDeFdhTmFdCigwpC1Owkh ENYV2FOQuhA3hRBqcDUWFAAanWNSBO0hmgsbAK2oqstArKmtQzJ0JUIXKhVyGUqD/2Q==[/img]
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
If they do not line up at first, use spacers under the sprocket or bottom bracket fixed cup to move the sprocket or the chainring slightly outboard to improve the chainline.
Likes For JohnDThompson:
