Wahoo Bolt Sync Issue
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
First off, yes, I have reached out to Wahoo. That was the first step.
Lately some rides won't sync with the app on the iPhone. The ride appears, but the usual route graphic is a gray box and the sync never completes. As a result it never uploads to Strava, or anywhere else. Has anyone else seen this issue? I'm just wondering if it's just me or if this is more widespread.
Non omnino gravis
Is the Wahoo connecting to the phone? Like, your Bolt is showing up inside the Companion App? I've had to do the whole "forget device" procedure and resync the Bolt to the phone twice this year (which isn't that bad, IMO) and that has cleared up any connection-related issues for me.
I mean, the App still refuses to export activities to other apps automatically, so I have to do it manually-- on the upload screen from the activity, it always says "an error has occurred - retry" on every app that isn't Apple Health. They seem to be working on it, as I feel like I've done 3 firmware updates this month alone.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
This is an issue that has been known to Wahoo. Looking at the Wahoo Elemnt User's Group on Google, it apparently has been corrected. There were three to four daily complaints about this issue. Since the release of the last firmware and companion app there have been no more posting. I was also having that issue but have not noticed it since the upgrading to the latest firmware and companion app. Other than unpairing and repairing your Bolt and phone, I have not had the issue with the gray box in the route window and have no suggestion on how to correct it.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For dmanthree:
Quoted: 646 Post(s)
Liked 289 Times
FWIW, Wahoo responded quickly and here's their advice, for those who have this issue:
Thank you for reaching out and I am sorry that you are experiencing this issue with your ELEMNT computer. We are aware that a number of users are experiencing connectivity issues on iOS after the iOS 13.5.1 update and our development team is actively working on improvements to connection stability. In the interim, please ensure you are on the latest version of iOS (13.6) and the ELEMNT app via the Apple App Store, then follow the steps below to reset the ELEMNT's connection with the phone. Even if you have previously re-paired your device, please complete these steps exactly in order once again as the ordering is critical to resolving the connection stability
Step 1: Forgetting the ELEMNT Companion in the companion app
Should you experience connectivity problems after completing the reset procedure above the entire process generally does not need to be repeated, please attempt the steps below to restore the connection before repeating the process above.
- Open the companion app
- Select settings
- Scroll to the bottom and select Unpair ELEMNT
- Power on the ELEMNT Bolt
- Press the power button to bring up the menu
- Select forget phone
- Open the iOS settings app
- Select Bluetooth
- Under my devices, find the ELEMNT and select the info button on the right
- Select forget this device
- Repeat these steps for any duplicate listings of the device
- Important: Toggle the Bluetooth switch at the top of the screen off for 10 seconds, then back on
- Quickly press the left-side button on your ELEMNT to display the menu
- Scroll (with the right-side buttons) to either "PAIR PHONE" or "FORGET PHONE"
- Your device may reboot, displaying the QR code when it powers back on
- If the QR code does not immediately display on reboot, return to the settings menu on the ELEMNT and select "PAIR PHONE" - the QR code should now be shown
- Return to the ELEMNT Companion App on your device, then navigate to the settings menu to add the ELEMNT
- Make sure that once the QR code is scanned that you allow any requested permissions from the pop up dialog
- Once this is complete, go to Bluetooth settings once again, select the circled 'i' next to your ELEMNT in the list, and ensure that 'Allow system notifications' is enabled
- Toggle Bluetooth off in iOS settings for 10 seconds, then back on
- If this does not allow your ELEMNT to connect to the app, restart your phone and ELEMNT
