aero bar extensions, so many choices
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
sometimes lots of choices can suck...i am looking to get some clip on aero bars for my ride. not sure what to get regarding the extensions as there are so many designs that i am finding on the web. i am not independently wealthy enough to just go out and buy one, try it, buy another, try it... i am planning on putting my ride on the trainer with some home made arm rests in the approximate area and trying to measure what would be a comfortable wrist angle position.
hoping this will get me in the ball park but not sure if this will work so if anyone has another suggestion how i might attempt to figure out the correct or close wrist angle i'd appreciate it.
not looking for TT or aero per se, really just additional hand positions since on longer rides my hands do get tired.
looking at something like this...(probably)
https://profile-design.com/collectio...sonic-ergo-43a
Non omnino gravis
Likes For DrIsotope:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Liked 1,182 Times
Went the Airstike II route. put them on and rode on the trainer yesterday (way too much smoke outside). spent about 20ish min total on them here and there. sore in places i did not expect. thought it would be my neck but not so. more glutes and quads.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Liked 1,182 Times
So today i was blessed with smokeless skies and got to try out the bars out on the road. wow, that took a bit getting used to. having to shift took a bit of getting used to as well. i was able to spend a lot of time it them but neck really hurt. i ride with a base ball hat under my helmet. need to reassess that. i only wanted them for the additional hand position, would up being faster for a few segments. i could feel the drag when i got up out of them. glad i got them.
i got the air strikes with the flip up arm rests which is nice. but really, really loud on the crappy quality roads here (slurry seal). will look for some sort of solution to this unless someone has a trick up their sleeve. the noise just made me want to take them off at times.
Non omnino gravis
That comes down to how handy you are. Mine were horribly rattly out of the box-- turns out the little hinge pins that hold the armrests on were smaller than the holes in the bar brackets. I drilled both brackets out with a 3mm drill bit and replaced the stock pins with some 3mm R/C hinge pins, so the fit is tight. More importantly though (in my mind) I put 3mm shims on the hinge pins between the bracket and the armrest, which removed the fore-aft play in them. That pretty much eliminated any sounds from my bars.
Quoted: 2482 Post(s)
Liked 2,955 Times
If you seldom or never ride with your hands next to the stem, or if you're willing to exchange that hand position for grabbing the Airstryke's elbow pads instead, you can zip tie the hinged portions so that they're permanently in the down position. That's what several people I knew and I did with ours when the Airstryke first came out.
