older mavic ksyrium or newer axis 2.0 ?
hey guys . need a bit of advice . have 2 wheelsets older mavic ksyrium ssc or newer specialized axis 2.0.
now normally id go for the newer less worn axis but the mavics are considerably lighter (about 350g for the pair roughly on kitchen scale but you can feel the difference by hand)
the hubs on both are smooth . they are both quite true the spokes tension is good .
the only real tell of wear on the mavics is the brake surface which is concave but not to a ridiculous amount tho its noticeable (id say roughly 15 - 20% concave wear ) wheres the axis is not worn at all (roughly 3 - 5% )
thanks
thanks
Quoted: 1461 Post(s)
Liked 1,485 Times
I might be missing something here, but if there's nothing wrong with the Mavics I'd ride those. I'm not really sure why you'd ride the heavier wheels unless there's some other benefit?
They look like they could use a good scrubbing, but otherwise those are a pretty decent wheelset. That valve stem though...
I think you'll find the Mavic's will stand a good bit of wear yet. Sadly you'll find that when they are too worn or if they get damaged Mavic won't have replacement rims for them. I've got an otherwise perfect pair where the rear one got damaged when I was rear-ended. Made me swear that I'd never again buy expensive wheels that couldn't be repaired. The Mavic freewheel unit, though, is still quite replaceable.
