CAAD8 Tire Clearance
Hey guys. Will a 28c fit my CAAD8? I still got the stock RS3 wheelset. Will be replacing my 25c tires soon and looking to try either an Ultrasport or Gatorskin 28c if it won't cause tire clearance issues.
Also, will my current 18-25c tubes be ok on 28c tires? Or do i need to buy new tubes as well.
28s likely wont fit. I had a blue CAAD 7. In that time period the standard was 23 and the bikes could take 25s but that’s about it. You really want to put Gatorskins on a bike that stiff? There are so many nice tires that are puncture resistant but much faster and more supple. Plus Gatorskins are a nightmare to mount.
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times
My CAAD5 fits Conti GP5000 28c tires just fine. FYI.
Likes For Mulberry20:
I get it but race tires are not the delicate unreliable creatures they use to be. If you have to fix a flat roadside I would rather have to remove and remount the Vittorias or Pirellis roadside any day of the week.
Quoted: 1455 Post(s)
Liked 1,477 Times
How much room do you have around the current tires, and what kind are they?
Not all tires are true to the labeled size, so it depends. Knowing your current tire clearance with 25mm installed will tell you if you can fit 28mm tires or not. You generally want at least 3mm of clearance on each side of the tire. Your brake caliper may be a limiting factor as well.
You don't really need to worry about the tube size. I've run 18-25c tubes in 28c tires for years and never had a problem.
I'm not a fan of Gatorskins. They have great puncture resistance, but they're heavy, slow and stiff. IMO the Conti GP5000 is one of the best road tires available and is far superior. I've never had a problem with flats on them, and have used both the tubed version (in 28mm size) and the tubeless version (in 32mm size) and ride in the city all the time.
Likes For msu2001la:
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Try Schwalbe Durano Plus. Pretty light, but durable in my experience, and the 28mm is not too puffy- they fit on my 80s Cannondale SR900. (Definitely not designed for big tire clearance)
Quoted: 4559 Post(s)
Liked 2,802 Times
I really like Conti GP Classic skinwalls on a couple of my road bikes, but I'm a sucker for skinwalls/gumwalls. These have a reddish brown translucent sidewall. Remarkably durable, grippy and puncture resistant for more than a year on chipseal and bad roads. And a nice ride, not a bit harsh. Price is usually somewhere between Conti's least expensive (Ultra Sport, very good cheap tires) and the GP5k and Gatorskins, usually around $30-$35 each. These are 700x25 only and may be a tight fit under some rear brake bridges.
Likes For canklecat:
Likes For iamLefty:
Liked 2,802 Times
I forgot to mention why the Conti GP Classic is an odd fit, despite being a 700x25 like the Conti Ultra Sport II that clears easily.
The Ultra Sport II is a slick and easily clears the rear brake bridge on my '89 Ironman, which was originally fitted with tires in the 700x18 to 700x20 range. Only problem with the Ultra Sport II is I need a Kool Stop bead jack for installation. US2 tires are incredibly tight fitting.
But the GP Classic has a raised center rib, so it stands a bit taller. It just barely rubs the rear brake bridge on my Suntour GPX brake. I haven't tried that bike with another brakeset so I'm not sure whether that would be a problem. I don't want to modify the brake so I'll wear down the tire a bit on the indoor trainer, or just live with the slight rub until it naturally wears down. It's only a problem when I ride through a puddle and pick up a bit of debris.
Now that I've ridden a set of GP Classics for a year, I'm going to move the front tire to the rear, and put on a new GP Classic up front. Problem solved as long as I stick with that routine.
And I can install the GP Classics with my hands, much easier on the road.
https://www.excelsports.com/main.asp...jor=1&minor=27
The Rubinos are a steal at $26 each.
Mulberry20 Thanks!
